Home Improvement
#51
_cruiza_
Posted 14 August 2012 - 09:21 PM
DJ finally has a girlfriend
#52
Posted 14 August 2012 - 09:22 PM
aimlessly pushing a trolley round the place
#53
Posted 14 August 2012 - 09:23 PM
What are there modular kitchens like?
Cruiza, way off mate. The reason i can afford to do this stuff is cause i dont have a gf.
#54
Posted 14 August 2012 - 11:56 PM
they kinda look and feel cheap to me
besides you can stain and varish wood,change knobs
and bunnings do laminate bench tops/sinks etc fairly cheap
#55
_nial8r_
Posted 15 August 2012 - 08:18 AM
What happens when it dry's out?
the shit sets rock hard
#56
_nial8r_
Posted 15 August 2012 - 06:53 PM
on the outside i think i would tile and not paint as the paint will were and you might end up with track marks in ya paint work?? maybe the shit they use on shed floors might be the go if you are going to paint ??
#57
Posted 15 August 2012 - 08:02 PM
Compactor hired, dirt organized, were getting there.
#58
Posted 15 August 2012 - 08:09 PM
#59
Posted 15 August 2012 - 08:19 PM
#60
Posted 15 August 2012 - 08:32 PM
#61
_nial8r_
Posted 15 August 2012 - 08:40 PM
amuter...you byo......
couple of coldies in a six pack esky for when you get there lol
#62
Posted 15 August 2012 - 08:56 PM
#63
Posted 16 August 2012 - 07:09 AM
hey bomber always go to the tool section and see what in the bargin / marked down section. Picked up some good stuff over the years
#64
_nial8r_
Posted 16 August 2012 - 08:15 AM
I can just see us having australia wide GMH-Torana-Home Renovator-Forum meet and greets at bunnings on a saturday morning with beers in hand lol.
#65
_nial8r_
Posted 16 August 2012 - 08:21 AM
lol I have done the "beer at bunnings" too
yep hit tool world in Bunnings they always have something marked right down, i picked up a Bosch hammer drill marked down to $15, said on the box faulty not working, thought what have i got to loose, got it home pulled it apart and wall'a the brushes were missing. rang up bunnings and ordered 2 new brushes that cost me $1.60
#66
_nial8r_
Posted 16 August 2012 - 08:31 AM
The track marks is hwat has me worried and makes me think its worth spending a copule of k tiling.
it doesnt take long once you get the ball rolling and start seeing results and finish before you start planning your next project
#67
_Inj gtr202_
Posted 16 August 2012 - 10:11 AM
Where you are laying the pavers may require a bit of cutting rather than filling.
The finished height of the Pavers should be at least 75mm below your slab height (of your house) and as stated should slope either to a drain hole or away from your house. By the time you put rubble down (which getts compacted hard) add about 20mm of soft sand (the stuff you screed and get nice and flat) and the thickness of the pavers/bricks (usually between 50mm and 70mm) you need to start with a flat area at least 150mm below your door step.
A laser level or at least a meter long spirit level should give you a good idead about the lye of the land, you don't wan't water pooling next to your house or have the bricks/ paver too close (in height) to the floor height of the house. Things will rot and termites love it.
Good luck with it, the end result is always worth it
Edited by Inj gtr202, 16 August 2012 - 10:12 AM.
#68
Posted 16 August 2012 - 07:33 PM
Cheers for the advice, i may hae ordered to much dirt, but i will find somewhere for it.
Can you use cracka dust in cement instead of aggregate? Whats the difference?
_nial8r_
Posted 16 August 2012 - 08:01 PM
#70
Posted 16 August 2012 - 08:04 PM
Need to get onto the boss tomorow, figured i may as well just use old garnet instead of sand, more or less the same and its freeeee
Posted 18 August 2012 - 08:33 AM
hope your up... Cuppa in hand surveying the works your about to begin....
Another morning ritual for members of the "Brother hood of Bunnings"
#72
_nial8r_
Posted 18 August 2012 - 04:48 PM
Hey DJ ITs the weekend.
#73
Posted 18 August 2012 - 07:31 PM
Had my first Saturday off since easter today, and man am i frOcking rooted.
Headed to work this morning and grabbed two 44's of garnet, about a tonne, to use in the place of sand, cause im a tight Daisy Chain.
Then got stuck into it.
I had a massive pile of blue dirt infront of my shed, two big drums of red dirt down the side of the house, a compactor, and a cup of coffee. This is about the time Jim posted in the thread hehe.
I did have to back cut around the shed door a bit, but that was easy enough
I really had no idea what i was doing, so while i was fresh i just wheeled a shitload of blue dirt around and dropped it in the holes.
Kept running the compactor over it, and kicking out bits of brick as they appeared to be in the way.
After a while i was getting no where, needed to figure out some way to get it level, so i invented a tool.
I call it a stick, or more likely a bit of old gal water pipe.
After a bit of using that, i decided crawling around on my hands and knees was stupid, so i went into the shed and invented a better tool.
I call it a stick stuck to a stick. Or more precisely another bit of gal pipe welded to the first bit.
It worked really well at first, then it got a bit to heavy to work properly as i started to get some form of shape, but meh, i have a new tool.
I swapped to a bit of 1.6m long 25x25 rhs.
After many hours of bitching and screaming at it, i had this
Then i layed out my Garnet and started putting the pavers down. The garnet was a bit wet which didnt help, but seems to have worked fine as a base for the pavers.
This is what i had at about 6pm
Now, obviously im not finished, BUT. The old ladie out the back came and had another long drawn out bitch session, and asked if i watned to go halves in a colorbond fence. This i do, so im not doing anymore untill i sort that out. May have to dig my pipe back up, but meh.
Its gonna be so funny to see tradesmen tromple on her garden, it will be worth it
After todays long drawn out bitch session i do regret taking the tree branches i cut off her tree's that were in my yard to the dump as a gesture of good faith though, such things in the future will be javelined over her fence. Should have also thrown the rat eaten macadamia nut shells and tree leaves used as a rats next over her fence. Might send her a bill of say $100 for removal of the branches and her shells/leaves etc actually....After the fence is sorted
_tryhard_
Posted 18 August 2012 - 07:36 PM
#75
Posted 18 August 2012 - 07:39 PM
