* * * * * 4 votes
LX GTR Hatch
turbo awd
817 replies to this topic
#676 Heath
Posted 13 May 2019 - 09:24 AM
Awesome Glen.
#677 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 25 May 2019 - 09:34 PM
Looking awesome mate
#678 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 24 July 2019 - 06:50 PM
A little different but this reminded me of your build
https://www.holley.c...373c3-264233089
#679 Indy Orange
Indy Orange
  • 2,987 posts
Posted 24 July 2019 - 09:59 PM
How dare you suggest that Torana's were once treated poorly Brad. :)  The exhaust on this XU1 was glowing right to the end of the muffler. It was held flat for minutes.
Thats not at Scarborough Beach is it Laurie?
#680 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 27 July 2019 - 07:55 PM
Update time. Having the shell dipped has turned out to be more work than I thought.
About 14 holes have been drilled in the shell that they never told me they were going to do so these had to be welded up.
Yes that is a hole drilled in the middle of the roof skin.
 Attached File  A9X_0404_resize.JPG   106.52K   13 downloads
Holes drilled in the wind screen channel and the top of the dash.
Attached File  A9X_0406_resize.JPG   193.31K   12 downloads
I was surprised at the amount of rust that started to form under panels, I had tack welded the sill panel and two extra roof braces on to the shell and removed them when I got the shell home.
 Attached File  A9X_0412_resize.JPG   107.69K   11 downloads
Attached File  A9X_0386_resize.JPG   209.6K   11 downloads
There are also spots where it looks like acid is still leaching out of the seams.
Attached File  A9X_0399_resize.JPG   189.13K   12 downloads
Attached File  A9X_0400_resize.JPG   213.49K   12 downloads
I was also surprised at the amount of body deaden-er and seam sealer that was still in the shell.
The black shape in the middle of the photo is one of the many big chuncks of body deaden-er.
Attached File  A9X_0401_resize.JPG   133.04K   17 downloads
#681 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 27 July 2019 - 08:03 PM
I have had to strip and clean and sand every part of the shell so finally got the inside and underneath painted with KBS.
 Attached File  A9X_0414_resize.JPG   285.81K   22 downloads
One coat of silver KBS, still need to seam seal then a coat of black KBS.
Attached File  A9X_0418_resize.JPG   233.63K   22 downloads
Attached File  A9X_0424_resize.JPG   282.63K   18 downloads
Attached File  A9X_0425_resize.JPG   269.09K   19 downloads
Edited by turbo76lx, 27 July 2019 - 08:03 PM.
#682 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 27 July 2019 - 09:00 PM
Attached File  DSCN0462.jpg   124.49K   13 downloads
Attached File  DSCN0453.jpg   131.03K   14 downloads
Attached File  DSCN0456.jpg   124.81K   14 downloads
Thats disappointing Glen,
your body looks like mine did after they dipped the car the first time, it still looked rusty and crap was coming out of it.
After the second dipping the shell was spotless and there was nothing left in the box sections that I could see through holes.
The box sections were all rust treated as well as the rest of the car, and finally a sealer was applied to everything.
#683 Bigfella237
Posted 27 July 2019 - 11:53 PM
I assume all the holes they drilled were to let air bubbles escape when they submerged the shell in their bath?
That kinda sucks.
You'd think it'd be worth them building a rotating cradle similar to a rotisserie so they didn't have to do that.
I have had to strip and clean and sand every part of the shell ~
That almost seems to defeat the purpose of dipping if you still have to do all that work afterward?
I hate the idea of that rust starting again in all the cavities you can't get to. Sounds like there should be a second stage dipping in some kind of rust prevention treatment?
#684 _Lazarus_
_Lazarus_
Posted 28 July 2019 - 07:53 AM
I guess you should just be thankful that it wasn't Heath on the drill
#685 YELLAcakeu308
YELLAcakeu308
  • 723 posts
  • Name:ben
  • Car:A10X
Posted 28 July 2019 - 10:22 AM
Pm'd
#686 Cook
Cook
  • 1,535 posts
Posted 28 July 2019 - 11:47 AM
One thing I would do before you weld up the holes is pump them full of cavity wax (or the like) especially if they are hard to get at areas.  I would have thought there should have been a final process of spraying a rust inhibitor. Cheers Ron
Edited by Cook, 28 July 2019 - 11:52 AM.
#687 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 13 August 2019 - 08:22 PM
Got the sill put back on and a coat of epoxy on it and the rest of the engine bay.
Attached File  A9X_0428_resize.JPG   277.9K   19 downloads
Attached File  A9X_0431_resize.JPG   182.39K   20 downloads
Attached File  A9X_0435_resize.JPG   257.63K   22 downloads
#688 arrimar
arrimar
  • 3,134 posts
Posted 14 August 2019 - 07:47 AM
Looking good.
#689 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 19 August 2019 - 07:40 PM
Got the inside of the shell painted.
Attached File  A9X_0437_resize.JPG   274.69K   17 downloads
Attached File  A9X_0438_resize.JPG   279.64K   17 downloads
Also pulling the running gear out of this to get another car out of the back yard.
Attached File  A9X_0436_resize.JPG   297.73K   22 downloads
#690 Heath
Posted 06 September 2019 - 06:01 PM
Big stuff Glen. Always a pleasure to get up to date on this.
Can't say it makes me super keen to have a car dipped though. At least you're well qualified to deal with hurdles though, lol.
#691 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 07 September 2019 - 08:40 PM
Started trowelling on the bog and sanding it off.
 Attached File  A9X_0445_resize.JPG   270.28K   29 downloads
#692 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 21 September 2019 - 07:16 PM
Got filler on both sills and quarters and fitted the flares to check the gaps.
Attached File  A9X_0448_resize.JPG   237.48K   27 downloads
Attached File  A9X_0449_resize.JPG   92.76K   21 downloads
#693 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 22 September 2019 - 06:47 PM
Nice fit
#694 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 30 September 2019 - 07:47 PM
Got some filler on the roof and in the engine bay.
Attached File  A9X_0453_resize.JPG   241.3K   11 downloads
#695 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 05 October 2019 - 07:54 PM
Put a quick coat of epoxy/prime over the filler to seal it up.
Now need to take it off the rotator and do around the tail lights.
Attached File  A9X_0454_resize.JPG   276.06K   12 downloads
#696 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 13 October 2019 - 07:21 PM
Started fitting the spoiler, the LH side was ok but the RH needs a lot of work.
Attached File  A9X_0459_resize.JPG   143.93K   9 downloads
Attached File  A9X_0458.1_resize.jpg   130.42K   9 downloads
Almost had to cut the whole side off and re-fibreglass it back on.
 Attached File  A9X_0462_resize.JPG   139.16K   9 downloads
Also had to build up both sides of the centre piece.
Attached File  A9X_0464_resize.JPG   192.18K   9 downloads
Now just need to file and square up the gaps.
Attached File  A9X_0469.1_resize.jpg   144.76K   10 downloads
Attached File  A9X_0470.1_resize.jpg   158.93K   9 downloads
Attached File  A9X_0471_resize.JPG   218.45K   9 downloads
Got a lot of holes that need to be filled in the hatch.
Attached File  A9X_0467_resize.JPG   208.22K   13 downloads
#697 Rockoz
Posted 13 October 2019 - 08:12 PM
Get the spoiler nice and neat then take moulds and make a motza selling a product that actually comes close to fitting.
#698 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 21 October 2019 - 07:32 AM
Almost got the gaps sorted.
Attached File  A9X_0474_resize.JPG   179.03K   12 downloads
#699 Shiney005
Posted 21 October 2019 - 09:50 AM
Better than anything done at the factory.
#700 myss427
myss427
  • 1,636 posts
Posted 22 October 2019 - 09:21 AM
Worth the effort, only way to get great gaps, looks good.
