14:1 Compression Pistons for 202 to 210
#26
Posted 23 December 2012 - 08:33 PM
#27
Posted 23 December 2012 - 08:39 PM
No arguement there, it was more a reply to the following comment:Thats because of the very different characteristics of methanol, nothing to do with the octain number or compression ratio...
as High Compression creates Hotter water
#28
_tryhard_
Posted 23 December 2012 - 10:32 PM
#29
_ljxu1torana_
Posted 23 December 2012 - 10:53 PM
my turbo 186 torana has 14.1 cr on full power.methonal will run on anywhere from 10.5 till as much as you can create in a holden six, 14 to 1 I think your dreaming with a standard stroke 202. I fitted 245 hemi pistons into a 202 back in the 80's had to mill 135 tho of the top of pistons, bore the eye of the rod out .we shaved 235 tho of a 149 head fitted bedford truck valves ran a waggott 41 / 78 solid with a set of 45 webers and only had 13.5 to 1.
#30
Posted 23 December 2012 - 10:55 PM
#31
Posted 24 December 2012 - 02:01 AM
So now we have more information on the 14:1 CR subject to debate, as I see it now is if the original question was 14:1 cr static or dynamic compression pistons?
My guess it was static as the turbo-ed 186 proves the 14.1:1 dynamic cr at full power with the duration of the cam.
With the previous links to high cr's state to have a cooler combustion temperatures using cooler fuels, coated ( valves, combustion chamber and pistons ) which helps to keep the detonation further away, having said that, static 14:1 cr could well run on 98+ gasoline with the XU1 Cam's duration could well bring the dynamic cr to 9:1 ( that was a guess ).
I would also say that I achieved 250psi cylinder pressure using a 41/78 solid cam I bought from Rare Spares at the strathfield branch.
So here we are attempting to have a normally aspirated engine with a new comp high reeving 41/73 cam duration at a dynamic 9:1 cr.
If the cr was a dynamic 14.1:1 ( be like driving with a Turbo or supercharger on boost all the time ) then the static cr would need to be 17:1 or so which would need some serious components.
Now as questioned earlier, 14:1 static cr is difficult to achieve or was that 14:1 dynamic cr difficult to achieve?
I say this, if we had no combustion chamber and the cam had a short duration, the static cr would be through the roof.
So in saying that the static 14:1 cr is achievable somewhere in between. Dave I
#32
Posted 24 December 2012 - 08:06 AM
#33
_gmlj6_
Posted 24 December 2012 - 11:46 AM
#34
_tryhard_
Posted 24 December 2012 - 03:16 PM
#35
Posted 24 December 2012 - 05:31 PM
I remember some ... OK, a lot, of years ago, I was inquiring info on plugs. A mate of dads had a book on plugs and stuff, as he was an old mechanic. The book said the 202 XU1 ran at 210 degrees, with Champion N11YCs. I'm using the equivalent of N9s, but I found N7s are better for performance, however... since fitting the HEI, the plugs I was told to use may be too hot as well.Hi Dave6179,
Yes, when I was reading the High Compression article I was thinking there is a lot of components to improve on,
and by the sounds of reducing the water temperature,
as High Compression creates Hotter water your engine should be at the right Temperature, if that makes sense. Dave I
#36
_stretchlc_
Posted 24 December 2012 - 08:03 PM
I think Jason was refering to the comp ratio being increased under boost Bomber, after all thats pretty much all a turbocharger does really!......
Edited by stretchlc, 24 December 2012 - 08:04 PM.
#37
_ljxu1torana_
Posted 24 December 2012 - 09:39 PM
you are a good man there stretch.I think Jason was refering to the comp ratio being increased under boost Bomber, after all thats pretty much all a turbocharger does really!
#38
Posted 25 December 2012 - 01:05 AM
Hi lcxu105,look at jag xjs lumpy tops and 253 lumpy tops as we looked at them years ago and they would fit but we never got around to building it.
Great info there, I had a look around on Google with no direct results yet.
Thank-you gmlj6,
I guess I am seeing what the enginners were up to in the late seventies.
Great Idea's there tryhard,
I may not blow this thing up.
Yep Dave6179,
I just used N9Y's in the 186 head, but we are entering into a new field now - I had a Champion spark plug Mentor as he worked for them for the later part of his life - has passed now.
Great inputs here, now we need a strong bearing set to go with it. Dave I
#39
Posted 10 January 2013 - 10:09 AM
I have come across this Write up Link about Compression if You would like to comment on:-
http://www.popularho...io/viewall.html
As it tell us more about compression in different ways.
ie - How good does your compression seal etc. Dave I
#40
Posted 11 January 2013 - 10:06 AM
#42
Posted 11 January 2013 - 10:38 AM
p.p.s. I heard the Aluminium Radiators are not good for cast iron Engines because of the Internal Flakes.
#43
Posted 11 January 2013 - 12:01 PM
P.S we also cliped the blades of the water pump to slow down the flow and only used a restrictor plat insted of a thurmostat.
#45
Posted 11 January 2013 - 12:51 PM
a filter would stop that
http://www.tefba.com/
#46
Posted 11 January 2013 - 12:56 PM
#47
Posted 12 January 2013 - 11:04 AM
I do have a brand new V8 rad, had it in for a while to check it's performance... didn't make much difference. It's screwed to the shed wall at the moment, but after making more changes recently I might chuck it back in.Hi Dave6179,
Great to see part of the Heating sorted, do you have a triple core radiator?
I use the V8 HQ as it has the hoses in the right place for the Six. Dave I
#48
Posted 25 May 2014 - 06:02 PM
Just Found these High Compression Piston Gems:-
$_57.JPG 230.99K
3 downloads
http://cgi.ebay.com....em=281344861249
I wonder if we can use them in a 208ci as the Rods would need to be different. Dave I
#49
Posted 25 May 2014 - 06:53 PM
Have you considered 253 lumpy tops Dave?
#50
Posted 25 May 2014 - 06:57 PM
All New to me Jonesy,
I would LOVE to have Lumpy's in a Red 208. Dave I
or a Blue 208 Short Motor even
just need to know the How Too's
