Hey Sam long time no hear.......any progress mate.
#126
Posted 30 August 2015 - 08:31 PM
#127
Posted 30 August 2015 - 09:13 PM
You may have seen the car in the latest Unique Cars - I know the editor so he asked for a balls and all account of what building a car takes, and he got it! Ha ha.
Funnily enough, I gave the panel work a miss for a bit - it was shitting me - and started the wiring instead. FFS, I don't know which sux more...
#128
Posted 31 August 2015 - 09:14 AM
Sam wiring it all is the fun bit, testing and seeing all the circuits working when its all finished is satisfying, especially when the battery is finally connected and no fuses pop or smoke appears.
#129
Posted 31 August 2015 - 11:01 AM
#130
Posted 31 August 2015 - 12:59 PM
Thanks fellas. I actually draw alot of satisfaction from both when it works - and the engine wiring was sorted a while ago - but the wiring for the chassis is all over the place. I went through and identified most wires on the weekend, but still not sure what one lot does and can't find it on my wiring diagram. I suspect it's for something non-standard.
I bought some trailer cable (7-core) to extend wiring, etc, so have done most of the hard bit, I just have to connect it all up now.
I'll stick it up later as I am sure someone here will know.
Should have the sills finished this week, have ordered my lower door replacement panel, too and getting there. Just needed some deep breaths... :-)
#131
Posted 09 November 2015 - 09:11 PM
Nearly Xmas 2105, and still no finished Torana BUT it’s still going along at a pace. Just not a very fast one...
Repairs to guards (files finished some dents from where I knocked it off the car with my shorts a while ago), nose cone (welded up badge holes and some minor repairs) are now done. You can see how tiny my shed is, had to push the car outside to do a few panels...
IMG_4586.JPG 82.56K
7 downloads
IMG_4772 (1).JPG 119.83K
5 downloads
The last big panel job was the near-side front door. Thing was a mess, but with file finishing of the metal (check out this short video here – see if you can spot when Hammo farted), a lower replacement panel from Rust a Part on eBay, the removal of all rust and epotech applied, as well as a generous skim coat, it was almost ready to hang and gap for poly over the entire car.
FullSizeRender.jpg 103.49K
7 downloads
IMG_4561.JPG 87.06K
6 downloads
IMG_4832.JPG 95.96K
5 downloads
Instead, I stripped the back of the corners, which were already “done”, to find filler sitting in rust holes… It didn’t take long to fix and treat, now I just need to strip the back of the door, then epotech it and on it goes.
IMG_4831.JPG 69.92K
6 downloads
Next is to either gap the last panels and poly the entire car OR pull the engine and box, complete the little bit of dummy wiring required, then epotech the bay. I think the latter.
So, the longest effin’ build in the world is continuing at a pace, just not a very fast one.
#132
Posted 10 November 2015 - 12:18 PM
#133
Posted 10 November 2015 - 07:36 PM
Thanks Al. Your definition of "slogging away" and mine differ a little, but yes... :-) Hanging for your next update. Can you or anyone else tell me what size bolts they used for the bonnet scoop. I want to go a size or two smaller than the flare bolts (not the A9X original screw kit from Rares, I want stainless allen cap bolts), but wondering what everyone else used?
#134
Posted 12 November 2015 - 07:31 AM
#135
Posted 03 September 2016 - 02:35 PM
Christ this is dragging on...
Following the door repair, we fitted the door and realised why you should finish the door edge ON the car... We stuffed it. So a bead of weld on the door edge, fitted the door, ground the edge, some filler to finish, and now it's actually done. There were some little things to fix on the nose cone, too.
File_000 (4).jpeg 183.01K
7 downloads
I had then found a problem with the guard - a big crack that was too hard to fix properly. So I bought another one, stripped to metal, welded up the old flare holes and re-drilled new ones, file finished and finally epoteced. It was the straightest panel I had to deal with, so it went well.
File_000 (3).jpeg 145.09K
7 downloads
Kids, business and life has been taking priority lately, but finally all the big panel work is done (I seem to remember saying that before). I now need to finish the flare work.
How have people prepped their fibreglass flares after fibreglassing to clear wheels etc? Is standard filler ok for the small imperfections, or should I use fibreglass filler? And is epotech ok for the finished flares/spoilers? Hopefully this next section doesn't take 12 months...
#136
Posted 03 September 2016 - 04:26 PM
Glass in areas for strength, bog for show.
#137
Posted 30 September 2016 - 07:57 PM
Actually spent some time on the car today, blocking back the Epotec - two guide coat's worth of blocking with 180 and it's starting to look straight. It's getting polyester next, though I have the roof and front panels to do yet. The Epotec blocks so nicely, much faster than I thought it would be.
File_000(2).jpeg 193.77K
7 downloads
Got a weird problem (as usual) though. The flares are in the same spot, the front guards are gapped and all lovely. However... The passenger side wheel is clearing the front of the flare, and I have cut the rear, ready to glass up, for clearance. Seems good.
File_001.jpeg 165.58K
6 downloads
The driver side wheel, however, is tagging the front of the flare and doesn't need much cutting, if any, to clear the rear of the flare. It all points to the crossmember not being in straight (it has new everything, bushes, etc), however I thought there isn't much movement in that area. It seems the passenger side wheel is an inch or two further back than the driver side. Any ideas?
File_000(3).jpeg 212.7K
6 downloads
Anyway, today was a big step forward, feels good!
File_000(1).jpeg 239.46K
6 downloads
#138
Posted 30 September 2016 - 09:00 PM
#139
Posted 30 September 2016 - 09:18 PM
It really does, doesn't it... I had planned to build a stunt bike before a car - probably should have! Ha ha. Thanks Gene.
#140
Posted 01 October 2016 - 06:01 AM
Beyond that sometimes the top arms get bent when bushings are replaced, they can generally be bent back safely (bottle jack from the firewall is good for moving them forward, obviously something different required to move them back).
There may also be a little movement available in the final positioning of the subframe too.
It will all come out in the wash, looking good.
#141
Posted 01 October 2016 - 06:18 AM
The upright part of the K-frames tend to twist over time too, especially with repeated hard-braking events, this tends to remove positive caster (or add negative caster as the case may be).
In any event, don't change anything until you find out where the problem is, it's pointless modifying a flare if the problem is gonna change with a wheel alignment for example!
#142
Posted 13 October 2016 - 05:15 PM
Had a similar problem with mine Sam.....I set the flares up while the original K frame was still in the car and hadn't been touched yet so I assume the caster and camber was relatively close to where it should be.
I then removed the k frame and overhauled the lot...put it back together and stored it away while the car was on the rotisserie.....got the body finished and painted and installed the flares... all good until the engine install......lifted the car over the engine and k frame and dropped the body on and bolted it all up.......chucked the wheels on and all of a sudden the wheels where hitting the flares just like yours.
The problem was during the k frame overhaul the new bushes and the fact that I didn't take note of the shim positions, tie rod positions so all added up to very bad alignment.....caster was extremely bad so after a few adjustments and a wheel alignment the wheels moved back to there original position and problem solved....it had me worried for a while but after thinking about it I realized what I had done.
#143
Posted 14 October 2016 - 03:15 PM
Thanks Al - I actually measured everything and it turned out it was the flare that was out, it's fixed now, I had to move the flare forward 1.5cm. I answered on another thread, I should have updated here, too. It was a pain, literally, because I was holding a piece of brass behind the hole I was welding up and somehow ended up with burning hot mig wire right through my finger! In one side, out the other. How does that even happen? It cauterised it, so didn't bleed. Bit weird... First time I've hurt myself on the car, I'm pretty careful, but yeah...
File_000 (2).jpeg 133.15K
6 downloads
File_000 (3).jpeg 175.29K
4 downloads
Anyway, flare on right now, so time to cut. Once I have fibreglassed up the cuts, I am just going to fill some small imperfections with fibreglass bog, but then what? I only have epotech, not primer, should I just hit the fibreglass with that? Or use ReFace polyester? I don't have a gun for the latter, but have a panel beater mate who could lay it on for me, then re-fit the kit to stop it drying out of shape.
Also, in the second pic, you can see the front of the spoiler sits out from the nose cone, rather than flush - the rest is fine - I was thinking of taking out a slice to allow it to sit neatly. Any other ideas, sing out!
#144
Posted 14 October 2016 - 06:02 PM
keep going Sam is all a big learning curve to try our patience, don't let the car win and get the better of you. when its all done its the satisfaction of knowing you have done your best and learnt lots of new skills along the way. The pure driving experience in the end will all be worth while.
#145
Posted 14 October 2016 - 09:33 PM
Thanks Lenny, I'm actually as keen as ever! Just have to stop welding my own finger and I'll be there... Need to keep reminding myself it starts and runs, etc. It really isn't too many man-hours and frock-ups away. :-)
#146
Posted 14 October 2016 - 10:23 PM
#147
Posted 14 October 2016 - 10:25 PM
#148
Posted 15 October 2016 - 05:40 AM
go bro go
#149
Posted 15 October 2016 - 08:06 PM
Thanks for the advice on the flares too, grumpy. Epoteced now, I'll let them dry for a few hours then re-fit so they stay in shape as they totally dry.
Unfortunately the passenger side door has some issues, so not sure what to do there. Thinking of starting again. Sigh. Nose cone got blocked back though and it's perfect, so that's great. Two steps forward, one step back as usual. :-)
IMG_6699.JPG 177.95K
6 downloads
#150
Posted 15 October 2016 - 08:09 PM
