The Marty Report
LJ GTR Build
1095 replies to this topic
#351 _Agent 34_
Posted 22 January 2014 - 07:04 PM
Yep, Marty you are now suffering what they call
" post traumatic badge drilling stage fright"  or PTBDSF for short.
It    happens to most people trying to re locate the correct boot badge GTR location . I went through the same thing, I'm in recovering through !!
the therapist says " just dont look at the badge too much" , just walk past and "don't look down" , Its work in progress but i'm recovering .
Mate, you will not notice it once you are driving that car, although Gene will point it out every time.
looks fine to be, just elongate the hole a bit,  put a bit of bog over the hole ,, re drill in the correct position then you will have the correct hole.
Just drill the hole a bit bigger as when it's painted you don't want to file through the paint if the holes are tight on the spigot  with paint.
go bro go
#352 sibhs
Posted 22 January 2014 - 07:30 PM
Thanks Grant, my heart sank when I read John Gong's post.  It's a big thing getting it right.  I'll have another go at it tonight. I was going to weld hole and re-drill but your idea sounds better. Also I'll make the holes a bit bigger to allow for paint.
The badge comes with speed nuts and spigots, I suppose you use one or the other, nuts sound better for taking badge on and off, say when polishing, but spigots are factory look.
As much as it hurt, thanks John and Adam for pointing out the crooked badge.
Perth in a Heat wave at the moment, looks like Monday is a good day to do more Hi-fill.
#353 sibhs
Posted 22 January 2014 - 09:35 PM
Used my square to get badge straight to RH edge.
Patched old hole after redrilling. Was about 3mm out. (Spot on Gene)
Badge fitted AND IT IS PERFECT.
Masked out a few more areas in readyness for Monday.
Edited by sibhs, 22 January 2014 - 09:41 PM.
#354 Ice
Posted 22 January 2014 - 09:38 PM
See i tod ya 3mm
Told to
#355 _markm_
_markm_
Posted 22 January 2014 - 11:43 PM
What happens Monday mate ???
#356 Potta
Posted 23 January 2014 - 12:02 AM
PAINT?!?!?!!?!?!?
:party:
#357 sibhs
Posted 23 January 2014 - 08:27 AM
Monday is a full coat of acrylic primer/high fill over everything that'll be Tangerine.
#358 sibhs
Posted 23 January 2014 - 08:03 PM
Engine update pics.
Starfire rods cleaned.
Block honed.
Head cleaned and ready for mods.
Crank balanced and machined.
At this rate it should be ready in a few weeks.
#359 eyepeeler
eyepeeler
  • 1,963 posts
Posted 23 January 2014 - 10:26 PM
I love the work you have put into this Marty, great job. It's been good to watch.
#360 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 23 January 2014 - 10:32 PM
Martin you should make a template for the badge so the next person can get it correct straight up.
#361 sibhs
Posted 23 January 2014 - 10:42 PM
Cheers, hopefully catchup on a run one day.
#362 sibhs
Posted 23 January 2014 - 10:45 PM
Yeah it's been a brain strain. I'll update my other thread on badge position and hopefully make it fool proof.
#363 N/A-PWR
Posted 23 January 2014 - 10:52 PM
Call it a GTR Badge Drilling Jig Marty,
Place the Jig on corner of Boot Lid and clamp, then drill the holes through the hardened guide bushes. Dave I
'TRADE MARKED by MARTY'
#364 Ice
Posted 23 January 2014 - 10:54 PM
Plus 3mm lol
#365 Potta
Posted 23 January 2014 - 10:58 PM
Plus 3mm lol
Marty you should know better than to admit that Gene was right  :P
#366 Ice
Posted 23 January 2014 - 11:17 PM
What you talking bout potta hahahaha
Told ya never fear genes here
#367 sibhs
Posted 31 January 2014 - 07:41 PM
Penned on the silver lines.
Acrylic primed last week and have been rubbing it back.
Still finding the odd dent. Too shallow to bog so they get high filled. I've used a different colour so the viewers at home can see.
Any holes or scratches get sprayed and rubbed back.
Also have to re-prime edges where I rubbed through.
Tomorrow is final rub then high pressure clean room and hopefully Sunday morning the car will be white.
I'm really happy with how the body is looking, every layer of paint it just gets smoother and more betterer.
Using acrylic is a dream. Flows smoother, dries in a flash so you can sand and move on real quick. Left over paint can be kept too.
Edited by sibhs, 31 January 2014 - 07:42 PM.
#368 Potta
Posted 31 January 2014 - 08:53 PM
Look forward to seeing the white mate.
When are you doing the flares?
#369 sibhs
Posted 31 January 2014 - 09:25 PM
Hi Craig, this is not a genuine GTR like yours so the flares will be left
If it looks good in white, might have to make if a Glacier like Genes.
#370 Ice
Posted 31 January 2014 - 09:26 PM
Stick to red goes faster
#371 Potta
Posted 31 January 2014 - 10:27 PM
Thats not what you told me Geno
#372 Ice
Posted 31 January 2014 - 10:31 PM
Your right white is faster craig lol
#373 Potta
Posted 31 January 2014 - 10:34 PM
It don't matter cause green is faster than white anyway.
#374 Ice
Posted 31 January 2014 - 10:38 PM
Really beg the differ that
#375 sibhs
Posted 01 February 2014 - 11:52 PM
High pressure cleaned room ready for tomorrow.
