Totally awesome mate, totally awesome. You looked like a kid let loose for the 1st time ever in a candy store.
Dave.
Posted 25 October 2014 - 11:25 PM
Dave.
Posted 25 October 2014 - 11:34 PM
Posted 26 October 2014 - 01:37 AM
Posted 26 October 2014 - 05:34 AM
After that first run we ran it again with the revs up to run the cam, sounding great and smoke all gone, then the water started coming out the overflow radiator pipe. Shut it down, also found an oil leak at the rear of rocker cover. Pulled that off, looked like even oil flow over rockers, cleaned gasket and head and sealed gasket and tightened tight this time.
Next start up, radiator cap on and running to check temperature, temp kept rising and thermostat didn't want to open so we shut it down again. No oil leaks.
Removed thermostat says 180 tested it, opened under boiling water from kettle, think I'll get one that opens earlier and try that.
Fantastic day, the engine was cranked over for about 30 seconds with no plugs until the oil pressure started rising. Then plugs in but no lead to coil and crank it with pressures, still sounded good. Then apply the spark and what you see in video, she fired straight away.
Marty,
with the temp i have a similar problem. i tried all the thermostats x 3 - ended up with a triden high flow.- but this was not the problem.- there was no problem at all in the end It was as below.
took the gauge out and got tested with the sender - there was an error with the sender Vs gauge and to adjust the gauge needed to put in a 10 ohms resistor - didn't do it yet.
check the water temp with a multi gauge if you have one and run with the radiator cap off and you can see flow.
well done man - I'm stoked for ya
Posted 26 October 2014 - 07:20 AM
Posted 26 October 2014 - 07:29 AM
Well done Marty
Mission almost accomplished.
Looks and sounds awesome.
Posted 26 October 2014 - 07:45 AM
Posted 26 October 2014 - 12:34 PM
Posted 26 October 2014 - 12:35 PM
this was a good day, got home smelling like a torana owner who has been out in the shed...
my LJ is slowly moving on, engine rebuilt... rust repairs just started.. then paint then trim...
it may not be a show pony... but it will run like a thoroughbred...
ps will need a *complete* heater assembly for LJ... anyone know of a good alternative or a complete set that can be rebuilt...
Posted 26 October 2014 - 09:50 PM
Posted 26 October 2014 - 11:11 PM
Posted 26 October 2014 - 11:42 PM
Hi Marty,
IT'S ALIVE !!!
I was smiling too and so happy for you too,it sounds surpurb.
Regards John.
Posted 27 October 2014 - 06:10 AM
Awesome work Marty, not long now until the first drive !!
Posted 27 October 2014 - 07:57 AM
Two thumbs up.
Love the bit where you are clapping like a seal...lol
Posted 27 October 2014 - 07:59 AM
Two thumbs up.
HaHA
Posted 28 October 2014 - 06:30 PM
Posted 28 October 2014 - 10:20 PM
Posted 28 October 2014 - 10:36 PM
Posted 28 October 2014 - 10:40 PM
Posted 28 October 2014 - 10:47 PM
Posted 28 October 2014 - 11:05 PM
just off topic a little Martin, but just curious as to what screws are used to bolt in the fuel tank and what sealer if any was used around it? by the way it all looks great, love the interior. Greg
Posted 02 November 2014 - 10:14 PM
Edited by sibhs, 02 November 2014 - 10:15 PM.
Posted 02 November 2014 - 10:53 PM
Its gonna be a shame to drive it and get it all messy but I bet you can't wait!
Posted 03 November 2014 - 10:52 AM
Posted 03 November 2014 - 12:47 PM
