'HOLDEN FLAT or V12'
153 replies to this topic
#1 N/A-PWR
Posted 04 May 2013 - 06:50 PM
I have always wanted to put two red sixes together too create a Red  V12,
it would be called a XU4 as a XU1 is a 6 cylinder and a XU2 is an 8 and a XU3 would be a 10 so a XU4 would be a 12 Cylinder.
This would fit in the LC / LJ Torana and would be a lot of fun.
Tilting the red six so the cam is at the centre of the ''V'' the other half can use the cam.
There would be the case of recreating the Block, but all parts would be the same after that.
I have seen the almost use of the Holden prototype V12 using two V6's, but to no avail in the Prototype Car.
Any thoughts anybody on the Holden V12 ideas. Dave I
#2 _Bomber Watson_
Posted 04 May 2013 - 07:20 PM
Might wanna investigate a bit of crank work to mate....
#3 _missrb30_
_missrb30_
Posted 04 May 2013 - 07:25 PM
It would only make it twice as slow.
A v8 is 1.5 times or thereabouts slower than a straight six.
#4 N/A-PWR
Posted 04 May 2013 - 07:26 PM
Hi DJ,
The opposing piston would share the same journal
#5 N/A-PWR
Posted 04 May 2013 - 07:31 PM
Hi Chloe,
Great Information there, where I did not know that, but in saying that, cubic inch has a play, also short stroke and big piston diamenter does as well. Dave I
#6 _missrb30_
_missrb30_
Posted 04 May 2013 - 07:50 PM
Perth guys seem to have small pistons, you too Dave l ?
#7 N/A-PWR
Posted 04 May 2013 - 07:53 PM
nice
#8 _Bomber Watson_
Posted 04 May 2013 - 07:56 PM
Hi DJ,
How much do you think you will be able to thin the big end of a rod untill its not gonna work anymore?
#9 N/A-PWR
Posted 04 May 2013 - 07:57 PM
with better materials like Titanium
#10 _oldjohnno_
_oldjohnno_
Posted 04 May 2013 - 08:10 PM
No-one's ever gonna accuse you of not thinking outside of the box, Dave :blink2:
#11 N/A-PWR
Posted 04 May 2013 - 08:14 PM
Great Man Oldjohnno,
I have too keep it Holden one way or another. Dave I
#12 yel327
Posted 04 May 2013 - 08:37 PM
Correct, XU2 is a V8 (SLR5000), but XU3 is firstly a neutral headlining (up to HQ) and later (HJ on) either a 6 or V8 (14.5cwt Sandman). XU4 is a 6 or a V8 too - XU4 is a 10cwt HJ-HZ ute or van. XU6 is a V6 HSV abortion.
#13 N/A-PWR
Posted 04 May 2013 - 08:43 PM
Damn - XU4 is already taken.
We will have to make it a XU12
Edited by TORYPOWER, 04 May 2013 - 08:47 PM.
#14 rodomo
Posted 04 May 2013 - 10:08 PM
:spit:
Fireball XL-5 is also taken Dave. http://www.youtube.c...h?v=6ifS2nP53Zs
Edited by rodomo, 04 May 2013 - 10:10 PM.
#15 Ice
Posted 05 May 2013 - 02:59 AM
You must be hangin round the wrong blokes chole.
#16 _Bomber Watson_
Posted 05 May 2013 - 08:14 AM
How did i miss this??!!??
If it wasnt for the RB30 part i think i'd marry you :P
#17 Peter UC
Peter UC
  • 771 posts
Posted 07 May 2013 - 06:50 PM
Would you have all the exhaust and inlet ports in the V or everything on the outside?
#18 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 07 May 2013 - 08:16 PM
Reverse fit one head, problem solved.
#19 _Gunmetal LH_
_Gunmetal LH_
Posted 07 May 2013 - 08:31 PM
:threadjacked:  http://ls1tech.com/f...-ls1-build.html
#20 N/A-PWR
Posted 07 May 2013 - 09:37 PM
Hi Peter UC,
I think the Exhaust and Inlet manifold would be on the outside as the Cam is in the center of the 'V' and the Distributor, Spark Plugs and Oil Pump needs to be in the Centre from the Camshaft.
All a bit wrong but could be done. Dave I
Hi Vick,
Yes turn One Head around. Dave I
#21 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 09 May 2013 - 08:14 PM
Start reading the above thread Dave.
#22 _Lazarus_
_Lazarus_
Posted 20 June 2013 - 08:20 PM
Damn Gunmetal LH, you kind of beat me to it. I was going to suggest putting them end to end for a Straight 12.
Engine bay... ? You didn't say it was going in a street car now did you... ?
You'd never get the V one regoed anyway.
If you want capacity stick a big turbo on a 202 with 28 PSI boost.
9.9 litres is more than enough for any man.
#23 _Bomber Watson_
Posted 20 June 2013 - 08:51 PM
Unless your used to 10L :tease:
#24 WhaleOilBeefHooked
WhaleOilBeefHooked
  • 1,675 posts
  • Car:LJ GTR
Posted 20 June 2013 - 09:34 PM
What sumfin like this Bad Boy ??????
#25 _Bomber Watson_
Posted 20 June 2013 - 09:46 PM
Oh my frOcking god. ONly thing better than twin Holden sixes is twin chev sixes.....
Bet the owner of that thing has to show up to the strip a week before the race meet to collect his car from the return ramp, would go that frOcking quick the world would spin backwards and time would reverse.
