I heard he was using 2 Starfires and a V8 crank to make a boxer flat 8. That is why he trimmed the chassis rail.
Hey hey, this is not the "shit Torana owners never say" thread...
Posted 10 February 2015 - 01:28 PM
Posted 10 February 2015 - 09:42 PM
So this is why my Build Threads end up with so many bloody pages hahaha
Had to clean up this repair section from the previous owner and butt weld it in properly:
This probably doesn't even look as good as before, but in my mind it's a more robust repair as there aren't little flat cavities for moisture to sit in. My aim is to grind the relevant welds fairly flush so that the water can flow (for the most part) freely down across them towards the drain areas rather than sitting against a big ugly butt weld from the MIG. Even grinding the repairs isn't all that easy though...
Can't help but feel curious about how long it takes other people to do repairs like these... obviously I haven't done this kinda work much before but jesus christ it takes a while. You'd hate to have a short attention span!
Edited by Heath, 13 May 2021 - 05:53 PM.
Posted 10 February 2015 - 09:44 PM
While your in there, brush some of this shit over it and forget about it forever.
http://www.ppglic.co...tic EMH-375.pdf
Posted 10 February 2015 - 09:49 PM
Posted 10 February 2015 - 09:56 PM
Sneaky beak, been meaning to get one myself.
Posted 10 February 2015 - 10:01 PM
Posted 10 February 2015 - 10:06 PM
For those who dont know what were cranking on about, heres a pick of the one Ruts used in his how to fit flares thread.
Not sure what the cheapo ones from bunnings are worth, never looked, but you can get a good trade quality one now days for $250-300, one of the next things on my shopping list.
Posted 10 February 2015 - 10:13 PM
Posted 10 February 2015 - 11:32 PM
Posted 11 February 2015 - 05:45 AM
That's why my projects always take so long... :-(You'd hate to have a short attention span!
Posted 11 February 2015 - 06:32 AM
Posted 11 February 2015 - 08:27 PM
Hi Heath looking good mate.....
Get yourself one of these
Right angle die grinder with a 50mm ROLOC attachment then buy a box of these
these are 36 grit roloc discs
and also a box of these.......50mm roloc coarse linishing wheels
also use 40 grit flap discs on your angle grinder to knock the welds down fast and then use the die grinder with 36 grit to level the weld down to a flat surface.....followed by the coarse linishing wheel and you will have an almost invisable weld line.
Of coarse use the finger linisher in tight corners as well.
Just another note....the coarse linishing discs are excellent for removing old paint around areas like door apertures and plenum areas....they wont take any metal off and they leave a perfect finish.
The above is what I used on my entire car
Posted 11 February 2015 - 09:23 PM
Very expensive and slow way to do it ^ ?
Posted 11 February 2015 - 10:56 PM
I used these to strip the engine bay in my red torry.
They are suprisingly quick & excellent for nooks & cranny's!
Wouldnt bother to use it on larger panels but!
Plenty of faster ways for larger areas!
Posted 12 February 2015 - 05:52 AM
You know in all honesty, I thought I would scream if I seen another torana in undercoat but it is clear this one is not another tin of bog flashed with 2k.
Heath, just to try gauge man hours myself, how many hours do you honestly think you would have spent on the engine bay?
Posted 12 February 2015 - 06:39 AM
Posted 12 February 2015 - 06:42 AM
Posted 12 February 2015 - 06:56 AM
Maybe 150-200 hours between starting to strip it in December and now? I guess it doesn't really matter how long other people would take but I'm somewhat curious.
Thank you, I was sure I'm not the only one spending over 150hrs on an engine bay alone.
It's not hard to clock up those sorts of hours, especially when you think about start up and finish times, like if you have to get everything out, put everything away, clean up etc etc.
Posted 12 February 2015 - 09:15 AM
Posted 12 February 2015 - 12:33 PM
Edited by Swarbs, 12 February 2015 - 12:40 PM.
Posted 12 February 2015 - 12:37 PM
Good and proper work takes time...think that is why you still see plenty of dodgy done stuff out there, as people start something thinking it will be a quicky deal and get frustrated so just hack it together and keep going, lol. (seen plenty of it over here at least)
Posted 13 February 2015 - 09:51 PM
Posted 14 February 2015 - 09:35 AM
hi IMORAL, heath has been a great help to me with my build and we spoke about this exact topic. I was having a big problem with taking too much out and causing blow throughs. he told me his preferred method is to knock it down with a grinding disc then finish with a sanding disc.
thanks again heath for all the great advice, looking forward to seeing more progress.
Posted 14 February 2015 - 11:00 AM
Posted 14 February 2015 - 11:19 AM
I just leave the weld there in its entirety and smother it in bog.
