* * * * * 9 votes
Heath's Hatch
2140 replies to this topic
#1401 Ddstoys
Ddstoys
  • 49 posts
  • Name:Daniel
  • Car:Lx
Posted 24 July 2021 - 10:48 AM
Everytime I read your posts I’m blown away by something if not everything you do
#1402 Heath
Posted 27 July 2021 - 11:09 AM
Thanks for the kind words gents.
So I've never made a single hard line for anything before, but obviously need to make some brake lines for this car.
I started by ordering some fairly standard replacement braided hoses from stedzlc on here:
Then drawing a schematic of the system, and went around and started identifying all of the threads and then trying to work out what adaptors were available/suitable to suit all all the space available.
The brake line I ended up using is a 3/16" double annealed 316 tube from Prochem in Dandenong. It does have a thicker wall section than some of the others available, but I actually had issues with the Aeroflow one cracking when I did a double flare.
I started work by removing the diff:
The Wilwood Dyna-Pro brake calipers (which I have on all four corners, although the pistons are different sizes front to rear) have a 1/8" (-27) NPT thread, there's no cone, so you can't just screw a flare nut into them. I used these 90-degree NPT to AN-3 adaptors.
Note AN is only 37° and normal OEM brake stuff (even the Wilwood master & prop valve for example) are 45°.
So... I bought some tools including a double flare tool to cater for both taper angles.
My plan was to use this standard brass T-piece on the diff which I'd made a nice bracket for in the past:
But the thread has no bloody engagement, and the cones weren't looking brand new either.
I decided to cut my losses on that and buy a Brake Quip SS56 which is a stainless product that'll do the same job, and without welding, I made a little ally bracket and riveted it onto the base of the bracket (cut the rest off). This fitting attaches with a stainless bolt into a nutsert.
That'll do.
I also got a bit spendy and had Chris from Shockworks come around and we measured up a set up custom made dampers for my car... a few months later:
Sexy big body monotube damper goodness. Should belt the frOck out of the old Koni Reds I had in this car when it was last on the road.
The Pedders ones in the photo were just shitters I had for mock-ups, but decent for a comparison of size & finish.
#1403 76lxhatch
Posted 27 July 2021 - 11:21 AM
Ooh, I have always wondered how well the car would perform with a truly good set of expensive custom dampers. Don't know much about Shockworks but very interesting.
Didn't realise that AN fittings generally used double flares, other than being more difficult to make I guess there's no reason why not. NPT at the calipers isn't ideal but not much choice there. Looks like your flares are quite long in the tubing area which would be why the limited thread engagement in the original brass block.
#1404 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 27 July 2021 - 11:46 AM
 Heath , bloody great job you are doing , looking awesome mate ... thanks for the tip on the brake line connection , i also tried the original T piece to braded but didnt work ..
#1405 Heath
Posted 27 July 2021 - 12:56 PM
Thanks for the kind words, fellas.
Tim McAmis did a video on stainless hard lines and he reckons single flares are fine for them because the material is stronger (I assume he was using AN fittings, can't remember), but I still wanted to make mine the way that brake lines are supposed to be done in Australia, which is with double flares. This is a new area for me as I said so I don't have many strong opinions. It is true that the stainless double flares are not as compact as a lot of normal bundy tube flares, but those brass blocks have seriously shallow threads, I have heard others complain about them in the past and I wish I just listened at the time rather than having to re-hash it at the last minute.
Shockworks are a good local brand, they are very well reputed in Australia for doing good quality coil-overs for the Jap scene. Anything with a big body (Bilstein etc.) has the potential to work wonders on a car with high unsprung mass in particular, which is part of the reason I sold my Koni reds and made a proper investment in this area. I like the fact that I could develop them with Chris and he's going to tune the suspension of the car around the Dandenong ranges, so I'm pretty happy about that.
Also... wheels. I bought some Panasport G7 C5R wheels that were in stock at Barrel Bros in Sydney.
Bought a scrappy 16x10" single C5R off Yahoo Japan and imported it to do some mock-ups. Testing brake clearances, suspension arm clearances, (permissable back-space on a 16" on the front end isn't that massive), spent a long time with tape measures and no springs in the car going through the movements of the wheels to measure up what I can get away with. Finally rested in some suitable hotboi specs as you'll see below.
Measured up my floater hubs so that any of the new wheels could bolt straight onto the rear of the car if needed:
The new wheel centres before and after being set up on the lathe and machined to suit the drawing above:
Vapour blasted centres awaiting new spun barrels:
Confirmed colour with a spray-out:
NOS centre caps with suitable Jinglish text:
Vuola!
Fronts are 16x10" +4
Rears are 17x12" -31
(the fronts will get a small hubcentric slip-on spacer once I adjust camber and ride height, this will push them out and make them positively located on the front hubs so it'll be more aggressive than +4)
They should fit super tight. Absolutely minimum clearance is the aim of course.
#1406 SHEEL
SHEEL
  • 353 posts
  • Name:Daniel
Posted 27 July 2021 - 02:50 PM
whoa
  • Attached File  jimp.jpg   33.97K   22 downloads
#1407 Mitchyboy
Mitchyboy
  • 390 posts
  • Name:Mitch
  • Car:Lh torana
Posted 27 July 2021 - 03:12 PM
Also... wheels. I bought some Panasport G7 C5R wheels that were in stock at Barrel Bros in Sydney...
Unreal progress. Bet you can't wait to drive it now dude.
#1408 skap
skap
  • 1,161 posts
  • Name:Skap
  • Car:Mighty VN
Posted 27 July 2021 - 03:25 PM
Nice dish :)
#1409 Ice
Posted 27 July 2021 - 06:56 PM
frOck me they look awesome
#1410 Hatchback13
Hatchback13
  • 193 posts
Posted 27 July 2021 - 11:12 PM
Wow so much thought goes into everything and part you do, I thought I had dish, those rears look mental. Every step closer. Cheers
Edited by Hatchback13, 27 July 2021 - 11:12 PM.
#1411 sibhs
Posted 27 July 2021 - 11:34 PM
Faark me Heath.
My brain hurts looking at all those numbers and my mouth drools seeing the new wheels.
You are in a league of your own. Keep up the amazing work.
#1412 Heath
Posted 28 July 2021 - 09:39 AM
Haha cheers Marty!
Haha they are out of control hey? When I did the calculations and worked out the outers were going to be >6" wide, I knew they were going to be pretty striking (exaggerated by the step lip as well) but seeing them spun & polished... Jesus Christ lol.
You can find big diameter wheels, like 20" wheels with reverse drop-outs that have this size outers, but the step lips have a way different look that I'm so happy with.
Regarding how much thought goes into everything, yeah honestly I attribute that to the slow rate of progress. I wish I could make decisions a lot more quickly.
Spending time agonising over everything like I do probably avoids some mistakes, but I still seem to make a lot.
Nice to slip them over the studs and confirm that I do in-fact know how to use a tape measure.
#1413 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 28 July 2021 - 10:06 AM
Coming together nicely.
Love the fashion pack interior, and everything else.
#1414 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 28 July 2021 - 11:28 AM
Looking forward to seeing tyres on those rims, great look.
Regards Mando.
#1415 LXCHEV
Posted 28 July 2021 - 01:46 PM
Looking mad brother!! That last side-on shot looks awesome - even without the rubber!
#1416 RIM-010
Posted 28 July 2021 - 04:06 PM
How are you planning on properly rotating the tyres with different sized wheels? I think you'll find that your rear tyres will wear out a lot quicker than the fronts.
#1417 Indy Orange
Indy Orange
  • 2,987 posts
Posted 28 July 2021 - 07:18 PM
Wow this is just awesome! Aussie talent and ingenuity .
#1418 claysummers
Posted 28 July 2021 - 09:29 PM
Move on
early Holden nut
#1419 Heath
Posted 29 July 2021 - 11:32 AM
That will be a considerable challenge. I'll have to take the front flares off and drive it along a straight road with the rear wheels on the back if I want to rotate them? lol
I anticipate rear tyre life to be a problem, and the thought of this excites me a lot.
#1420 MRLXSS
Posted 29 July 2021 - 03:22 PM
Killer mate - Keep it up! Keen to swing past the workshop soon and check it out now we're out of lockdown again!
#1421 Adam77
Adam77
  • 24 posts
  • Name:Adam
  • Car:LX sedan
Posted 30 July 2021 - 10:12 AM
Awesome work Heath love the colour.
Who did you get to make the barrels?
#1422 Heath
Posted 30 July 2021 - 10:42 AM
The wheels were actually built by Barrel Bros in Sydney.
https://www.barrel-bros.com/
The barrels are from Whitehorse Industries.
I didn't buy the barrels directly in this instance.
#1423 skap
skap
  • 1,161 posts
  • Name:Skap
  • Car:Mighty VN
Posted 30 July 2021 - 06:31 PM
chrome bumper to match wheels?
#1424 clarky9999
clarky9999
  • 121 posts
Posted 30 July 2021 - 07:39 PM
Looking great mate normally grab a beer and read on the latest info for the hatch, bloody looking good.
#1425 rodomo
Posted 30 July 2021 - 11:07 PM
Lillydale?
