* * * * * 9 votes
Heath's Hatch
2140 replies to this topic
#1576 LXCHEV
Posted 20 December 2021 - 09:32 AM
That finished airbox is a work of art - absolutely stunning. I'll call it out as one of my favorite parts of your car - and something that adds a nice unique element when the bonnet is popped. Well done. Hopefully that air cleaner should flow plenty for you. Being a K&N job, I'm sure it will.
#1577 ReplicarSLR
ReplicarSLR
  • 518 posts
Posted 20 December 2021 - 12:45 PM
Hi Heath, such an awesome build.
One question, you stated:
“Then I cut my trumpets down in a bit of a 'staircase' to give them breathing room under the scoop, but still have them all poke a touch through the bonnet so it looks good with the scoop removed”.
I’m no fuel injection expert, but aren’t all the trumpets normally exactly the same length for balanced air flow reasons etc?
Keep up the good work, top stuff.
#1578 Heath
Posted 20 December 2021 - 02:26 PM
Cheers mate!
Yeah, I think the slight difference in length thing is sometimes practised on overpowered cars to broaden the torque curve to make it more tractable (giving it more than one 'hump' to spread the power band a bit rather than make it really peaky if it's just going to lose traction at that point anyway), but generally the easiest tune etc. would come from having them all the same. And then they all peak at the same time (certainly ideal performance if you are capacity-limited with a close ratio box).
But the desired characteristics of my motor benefit from an approx. 450-500mm trumpet at least... which is longer than I can fit in. So I just made them each as long as I could without the bellmouths being masked by sticking up too close to the underside of the scoop. And when the scoop is removed, I want them to all be visible because looks are also a massive factor (let's be honest, spending five figures on stack injection is for the look, the sound, and vibe, the street cred, whatever... it's not really about the power.).
Keep in mind this intake length is the best part of 400mm from the back of the valve. Proportionally, the maximum difference in length is under 10%. So they're not like half length and stuff. I expect they will still behave "similarly".
It is a form of compromise but I don't know that I'll experience any tangible negatives from it.
I am very sure that the difference in runner length of my Tri-Y exhaust manifolds is a lot more dramatic and that would have a greater (negative) effect than the slightly staggered trumpets.
#1579 axistr
axistr
  • 1,239 posts
Posted 20 December 2021 - 03:14 PM
I cheated with the master cylinder Heath. I removed the peddle assemble from the BA peddle box. It was an easy fit to the Tornana and only had to extend the length of the pedal to line up with the brake pedal. As you say it light because I extended it giving more leverage, but I knew the ratio would be right because its sized to the concentric bearing system. Take up point is 60-70% of the travel from the floor(perfect).
Axistr's Father & Son LH SLR Project. - Page 6 - Members Projects & Plans - GMH-Torana
#1580 Bigfella237
Posted 20 December 2021 - 03:16 PM
Thanks Lenny. The pedal weight basically just ~ comes down to pedal ratios and master size. If you used a really long stroke you could make it feel a bit lighter.
By shear coincidence the lads at BOM have just tackled their version of this problem in the latest installment of Project Binky... with a uniquely "Nick" solution!
#1581 hawk
hawk
  • 2,222 posts
  • Name:steve
  • Car:UC Torana
Posted 21 December 2021 - 08:05 PM
Awesome work as usual, Can't wait to see it in the flesh. Last time I saw it, it was pretty much a bare shell.
Good to hear the motor is now sorted.
#1582 Heath
Posted 04 January 2022 - 11:05 PM
POPULAR
Nice one Lenny. I didn't realise you actually used the Falcon pedal box. That seems like a good solution.
Andrew, I did watch that latest episode of Project Binky - one of very few forms of mental relief at the moment hahaha. I must admit I have not yet studied what Nik did there, it gave me a huge laugh but I had my own mechanical problems sucking up my attention so I didn't spend more time on it. I cannot quite understand if you have the same pedal movement and need the same hydraulic effort (displacement + pressure) how you can radically lighten the pedal input, unless you're playing with the curve so it has better leverage where the pressure plate needs the most force applied. I need to study it more or have someone explain that to me.
Anyway, a lot has happened on this project... Generally the last 6... well probably more like 18 months during all these lockdowns have been pretty consuming and I've been pretty single-minded about the car.
The last few months are just a blur of work on this car with my focus on very little else. Sacrificing the rest of life for the car basically 100%. Working to a deadline has helped the car's progress but some days it has come with a pretty high cost. The hours are huge and the hurdles it has thrown at me have been really hard to take. You put your heart and soul into things over time expecting good results and they just totally go wrong and weigh on your conscience heavily until you resolve them. And no, I certainly have not resolved all of them. Not even close.
But skipping all the details, I drove it to dinner last night. And that was really special for me.
I wanted you guys to be able to have a quick geez before its debut event, which is Summernats.
Tomorrow, it will become a trailer queen for the trip to Canberra, of course I would prefer to drive it, but it just isn't quite ready for that.
If you see me there, come and chat. Don't expect anything near perfection on the car. It isn't finished yet, and the paint & panel isn't quite showcar level, haha. It's alright but I need some more time to get it a bit better.
I look forward to seeing some people enjoying it, though.
#1583 rodomo
Posted 04 January 2022 - 11:11 PM
Well done grass hopper  :spoton:
#1584 Holdenbn74
Holdenbn74
  • 152 posts
  • Name:Brendan Nichol
  • Car:LH
Posted 04 January 2022 - 11:24 PM
Very, Very nice 👍
#1585 V-SLR5000-P
V-SLR5000-P
  • 1,325 posts
  • Car:L34 x 2
Posted 05 January 2022 - 07:27 AM
Epic Heath. Unless you have read all 64 pages of this post it would be impossible for anyone to appreciate all the custom fabrication and modifications you have undertaken.
#1586 Bullet
Bullet
  • 217 posts
  • Name:Mark
  • Car:LC 2 Door S
Posted 05 January 2022 - 09:02 AM
Congrats Heath, it must be very satisfying to drive it on the road finally.
It’s an awesome car with the attention to detail second to none.
Enjoy the wind in your hair through the moon roof
Cheers Bullet
#1587 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 05 January 2022 - 11:05 AM
I will keep an eye out for you tomorrow and come say hello. A job well done young man :-)
#1588 SHEEL
SHEEL
  • 353 posts
  • Name:Daniel
Posted 05 January 2022 - 11:31 AM
INCREDIBLE!!!!
Looks so delicious.
the styling of the whole car is so on point, stance/fitment, colour, your choice on window blackouts/chrome trims, injecion stacks... everything is so good.
Hope you get heaps of attention and satisfaction at summernats!
#1589 jeffblanco
jeffblanco
  • 391 posts
  • Name:Mando
Posted 05 January 2022 - 03:30 PM
Congratulations Heath,
cars looks stunning and sits beautifully on the road, well done.
Regards Mando.
#1590 Pallbag
Pallbag
  • 105 posts
  • Name:Paul K
  • Car:LX SLR5000
Posted 05 January 2022 - 07:10 PM
Faaaaaaaaark, nice to see the whole thing in its entirety. Looks great!
#1591 Zook
Zook
  • 1,536 posts
Posted 05 January 2022 - 07:35 PM
Well done.
#1592 Ice
Posted 05 January 2022 - 08:38 PM
Looks awesome son  :clap:
#1593 LXCHEV
Posted 05 January 2022 - 09:48 PM
Massive congrats mate - damn it looks the part! Enjoy Summernats - I hope you get to enjoy it.
#1594 Adam77
Adam77
  • 24 posts
  • Name:Adam
  • Car:LX sedan
Posted 05 January 2022 - 10:27 PM
Pat yourself on the back,awesome job.
You should be proud of the work you have achieved.
#1595 RIM-010
Posted 06 January 2022 - 06:41 AM
Skid vids don't seem to be loading?
#1596 christolx
christolx
  • 184 posts
  • Name:Chris
  • Car:1976 LX SL Coupe
Posted 06 January 2022 - 11:15 PM
Awesome work Heath! I know you put many many hours in, must bring you great pleasure to have the car at Motorvation! well done  :clap:
#1597 Shiney005
Posted 07 January 2022 - 08:52 AM
Motorvation. Now us Sandgropers would love to see you and your hatch over here Heath.
Attached File  MV36_slide.png   400.49K   22 downloads
#1598 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 07 January 2022 - 01:45 PM
Hell yeah ^^... Long drive though!
#1599 skap
skap
  • 1,161 posts
  • Name:Skap
  • Car:Mighty VN
Posted 07 January 2022 - 01:57 PM
Great work Heath, well done.
#1600 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 07 January 2022 - 03:20 PM
Looks shit hot H
