Hi all...
I contacted the owner, he came over,, I gave him the wire wheel and pointed to the RH door sill and said " go for it"... and you wouldnt of guessed.. More bog covering rust holes.. They didint even attempt to fix.
I then pointed to the RH cowl end.. At least they tried to fix this . shit job and all.. They did leave holes..to be expected... I then said to do the LH one... even worse... They didnt fix the inner seal..
Do u like how they shoved a piece of metal in the LH cowl end and welded it up... Lucky we got to it as it would of been a mess in a few years... The RH cowl end seal has a hole in it as well.. water leaking everyware in the car me thinks.
Any way the good news is that we had a GOOD look throught the car, top and bottom.. inside and out.. took ages.. with a torch, scraper and a scrib to poke. No rust.. a little surface, thats to be expected..
The rear end is fine.. They put a new boot floor in and did a good job..They didnt do it
. Rear beaver is fine.. infact the whole rear end is ok.. wont need touching, The guard bottoms have been done properly.. Alls good there.
I advised him to dig out ALL the old seam sealer and sandblast/por 15 inside the wheel arches to outer panels.. its cracked.... he will...
The RH door sill will need replacing as the pics show..holes and bog..
The LH door sill is ok..will need a internal blast/clean and por 15/oil...its in ok condition... wont have to come off....
The inner door sills to floor pan are good.
So all told.. Just replacing the WHOLE RH door sill from rear wheel arch to sill end.. As I have done before and clean inside rear panel area..
He has a donour for a cowl.. I will take off whole cowl, sandblast/por 15 in the wet well, seal up the inner seal properly then spot weld the new cowl on... Wont even know its been done.
So not too bad really... Im happy that he has agreed to get right... Ill do it properly for him I dont and wont cut corners. I was prepared to give him his deposit back and put back together if he was wanting me to do a "bodge job"...Im not interested in cutting corners for a dollar.. and think of the next guy... Its not me...
.... It wont be too hard and wont be too expensive...
He has agreed to do some dirty work... Brings the cost down..
I braced it ready to do the work Monday.. should take about a month..
Just another Torana to repaire really...
I have fixed/saved/restored 5 Toranas since I finnished the repairs on mine..... Maybee Ill get time for mine.. One day
But Im happy keeping people happy ![]()
Mike
Edited by mikecatts, 12 July 2013 - 05:53 PM.
