Bosch electronic distributor
54 replies to this topic
#26 _LHSL308_
_LHSL308_
Posted 27 July 2014 - 06:47 AM
Just be aware that tacho will not work unless modified and that costs about $200
Thanks mate I had no idea. What about if I install an aftermarket tacho with say a shift light, would that sort of tacho work after the mod?
#27 _Muzzy_
_Muzzy_
Posted 27 July 2014 - 08:21 AM
Thanks Muzzy. Is it still the same coloured wires that need to be bridged? I havent heard of doing it this way before, all I am after is 12 volts at the coil. Certainly dont want to stuff anything up as the engine runs perfectly but I think it would benefit from a bit extra spark.
As mention take the wires to run to provide a relay trigger, I have done this, have a good 12v at relay, running a bosch elec dizzy and bosch electronic coil on my 6 sweet as 1.5mm gap plugs
#28 _LHSL308_
_LHSL308_
Posted 27 July 2014 - 08:52 AM
So I guess thats a yes to the wires that need bridging at the plug near the booster being pink and yellow.
#29 Dr Terry
Dr Terry
  • 3,359 posts
Posted 27 July 2014 - 06:11 PM
The wires to join together are at the ignition switch, not at the booster.
Access is gained simply by dropping the steering column.
The procedure of removing the steering wheel & pressing a clip is to remove the ignition lock barrel. not the switch. The switch is located further down the column & mounted on the top of it.
Dr Terry
#30 _LHSL308_
_LHSL308_
Posted 27 July 2014 - 07:26 PM
Ah ha. Thanks Terry you've been a great help. Can you confirm for me that my standard Torana Tacho wont work after the mod? I am looking at buying an aftermarket tacho with a shift light if indeed it does.
#31 rodomo
Posted 27 July 2014 - 09:19 PM
We need to go back a couple of steps here with your mod. Is your ignition points or electronic?
Edited by rodomo, 27 July 2014 - 09:24 PM.
#32 _hutch_
_hutch_
Posted 27 July 2014 - 10:10 PM
I'm a bit confused here too,if the car is an LJ the ign switch is on top of the column as stated and you need to bridge the pink and yellow,and if your running a Bosch dizzy the tacho will work
#33 _LHSL308_
_LHSL308_
Posted 27 July 2014 - 10:25 PM
No LH guys with electonic ignition.
#34 UCSLE
UCSLE
  • 740 posts
  • Name:troy
  • Car:Goggomobil
Posted 28 July 2014 - 12:40 AM
Edited by UCSLE, 28 July 2014 - 12:40 AM.
#35 _Muzzy_
_Muzzy_
Posted 28 July 2014 - 07:06 AM
Lost me, the starter of the thread has electronic dizzy, now we are taking Kettering?
#36 _LHSL308_
_LHSL308_
Posted 28 July 2014 - 07:45 AM
You lost me with Kettering Brian lol.
I know what I have to do the only question I have is. If I bridge the 2 spades at the ignition switch will my tacho continue to work?
Edited by LHSL308, 28 July 2014 - 07:56 AM.
#37 TerrA LX
Posted 28 July 2014 - 08:07 AM
Ignition wires and tacho wires are on two different circuits, whether your tacho functioned before and/or whether it will function after the ignition mod is besides the point.
#38 _LHSL308_
_LHSL308_
Posted 28 July 2014 - 08:32 AM
Excellent thanks mate. It always pays to confirm something these days before going ahead with it.
#39 _Muzzy_
_Muzzy_
Posted 28 July 2014 - 05:51 PM
Coil negative always goes to Tacho in parallel except in the case of old smiths tacho, they go in series
FYI Kettering is a system fitted with points
#40 rodomo
Posted 28 July 2014 - 09:22 PM
"Kettering"...............blast from the past? Never heard that term before? Well, maybe? But I've probably forgotten?
Here's one for you...............FAIRCHILD.
#41 _Muzzy_
_Muzzy_
Posted 29 July 2014 - 07:03 AM
Fairchild
Would that be aircraft or engines?
Or the actress
#42 _Lazarus_
_Lazarus_
Posted 29 July 2014 - 12:57 PM
Fairchild eh ???
That would be the Twin Point System I would think -
#43 _J.A.W._
_J.A.W._
Posted 29 July 2014 - 01:18 PM
Morgan? aint that some ancient wooden junk..
I 've  got  a factory built lump from 1974 that was stock -  with crank reader electronic pick ups & individual coil packs,
how long did it take bloody GMH to start fitting them?
#44 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 29 July 2014 - 03:27 PM
Twin point Fairchild? Too much plastic!
#45 TerrA LX
Posted 29 July 2014 - 04:03 PM
Not exactly concourse but I'd own it.
#46 _J.A.W._
_J.A.W._
Posted 29 July 2014 - 04:08 PM
Be a case of takin' it for a good hard test thrash before you buy it, I'd reckon
 & make sure you check the body out - in hard daylight, since that photo might be 20 years old..
#47 rodomo
Posted 29 July 2014 - 10:06 PM
http://www.fairchild.../AN/AN-8208.pdf The basis of electronic ignition as we know it today.
#48 _Lazarus_
_Lazarus_
Posted 29 July 2014 - 10:46 PM
Glad to see you're keeping abreast of this Rob.
#49 rodomo
Posted 29 July 2014 - 10:49 PM
I do my breast to keep in "touch".
#50 N/A-PWR
Posted 30 July 2014 - 12:57 AM
breasts are good
especially electronic ones
