DIY tools
106 replies to this topic
#101 claysummers
Posted 08 January 2021 - 04:54 PM
What do people use to pull banjo pinion flanges? I was thinking just use steering wheel or damper puller with nut and bolt through opposing u bolt holes. Just swapped from 3.89 to 3.36 in the 186 fb ute and its leaking from the seal by the looks.
Edited by claysummers, 08 January 2021 - 04:57 PM.
#102 claysummers
Posted 08 January 2021 - 05:38 PM
Never mind. Came off easily. Dont think it was torqued to 120lbft.884c0e6a1aefcf6d8df6305a41f29344.jpg
Possibly the nut has been reused.
Edited by claysummers, 08 January 2021 - 05:39 PM.
#103 yel327
Posted 08 January 2021 - 08:26 PM
Chances are it will be noisy, from memory there is a collapseable spacer in there that may not like being retensioned. I remember doing what you are doing with a 3.36 Salisbury once and it was quiet afterwards but a 2.78 banjo I also did was noisy.
#104 claysummers
Posted 08 January 2021 - 09:57 PM
I remember something about replacing the spacer and retensioning according to tourque setting required to turn the pinion.
#105 rodomo
Posted 08 January 2021 - 10:10 PM
Yes. If the diff was growly then it's game over/rebuild time. If it was a leaking pinion seal only then the dealer method was to mark the pinion, flange and nut before dismantling. Replace the seal and do the nut up a bit past the marks to crush the tube a tad more.
#106 claysummers
Posted 08 January 2021 - 11:29 PM
Not noisy, just leaking. I was referring to FB workshop manual, which says use a new nut, apply bearing grease mixed with white lead and retension to 120 lbft. Not an FB diff of course, but I don’t have a later manual.
#107 claysummers
Posted 09 January 2021 - 11:40 AM
Back together torqued to about 80 not 120. No noise. Should hold oil.
