Sunbird build thread
176 replies to this topic
#51 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 13 June 2016 - 05:09 PM
Some small progress recently.
Fitted the UPC 287mm kit which was a success but won't fit with the Walkinshaw wheels I was hoping to use. Not sure if I will get new wheels or will try and find a different brake setup so I can use the Walkinshaw wheels as I really like them. The Walkinshaw wheels have a strange webbing on the back of each spoke that hits the hub and caliper. Once I tried to fit them I did find a thread I wish I found prior about them not fitting with a Hoppers kit,
http://www.gmh-toran...ls-on-my-torry/
I recently moved the car from my mates place so had to get it rolling for the 1st time in about 18 months and now at least it is at home but still have not found much time to do any work on it.
Looks good with the Walkinshaw wheels, shame it won't stop.
Attached File  P1110108.JPG   162.64K   18 downloads
Attached File  P1110115.JPG   162.27K   17 downloads
Attached File  P1110119.JPG   162.19K   19 downloads
#52 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 24 July 2016 - 07:52 PM
After finding the Walkinshaw wheels don't fit with the UPC brake kit and some more site searching also found the wheels won't fit with the Hoppers kit either I was looking at new wheels which was going to cost a bit to get some 16" wheels and keep my new tyres or get new wheels and tyres in a different size. I did some more googling and came across the McDonald Bros HQ Wilwood kit
http://www.mcdonaldb...frontbrake.html
after seeing this kit I contacted them to see how far the caliper protruded from the disc face and it was only 42mm which I thought would clear my Walkinshaw wheels if I used the VL-VN disc. Ray from McDonald Bros was very helpful on the phone and said if I sent them the stub axle, disc and steering arm they could make me a caliper adapter bracket.
The caliper adapter with bolts made to suit my combination was $225, cheap as far as I am concerned and I bought a set of calipers and pads and the total was $950 including delivery to Sydney and I fitted it today and it looks good with the 290mm VN vented disc. Can't see any clearance issues and the wheels fit which I am very happy about. Very happy with the help from McDonald Bros!!
Attached File  P1110229.JPG   161.97K   17 downloads
Attached File  P1110253.JPG   157.89K   17 downloads
Attached File  P1110259.JPG   143.64K   17 downloads
Attached File  P1110263.JPG   153.61K   17 downloads
#53 _LS1 Taxi_
_LS1 Taxi_
Posted 24 July 2016 - 08:37 PM
Very very nice!
#54 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 24 July 2016 - 08:48 PM
Thanks Darren, I am very happy with the outcome.
Should add I have UC upper control arms and steering arms so have good clearance to the tie rod end which Ray said might be close and require putting the callipers on the rear and swapping the stubs side to side.
#55 Heath
Posted 25 July 2016 - 12:05 PM
Could also perhaps opt for an upper balljoint with an extended 'pin'? Arguably the better way to achieve clearance as it also increases negative camber gain on bump.
Nice outcome with the brakes so far, McDonald Bros priced that very fairly in my opinion.
#56 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 26 July 2016 - 08:38 PM
I had thought about the extended ball joint when trying other callers but with this set up have lots of room.
Steering rod end ball joint or tie rod end is closest clearance issue but still clear.
Very good price considering it is pretty much a one off
#57 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 18 October 2016 - 07:12 PM
In July I bought a LittleJohnpaint tank and it looked pretty good, welds are nice and neat. Pretty simple design and after some mods to the mount straps and the rear mounts on the car it fits and looks good. Has to come out again to fit the pump back into it, just wanted to see if it would fit with some clearance to the diff etc.
Attached File  P1110389.JPG   156.33K   17 downloads
Attached File  P1110393.JPG   157.24K   17 downloads
Attached File  P1110394.JPG   155.73K   16 downloads
#58 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 07 February 2017 - 08:08 AM
Don't feel like I get much time to work on the car but got a few little things done last few months.
Bled the clutch, took the tank out and fitted the pump and put the tank back in hopefully to stay. Will still need to fit the fuel pump somewhere and think it will probably go just forward of the passenger side lower trailing arm mount.
I did make a new gearbox cross member using an T350 one I had as the T56 one hung very low and I didn't want it in the way of the exhaust. Bought a tailshaft and fitted it and used the Tremec toolbox app to do the alignment.
Fitted a Vintage air unit under the dash and trimmed the glove box down and squished it in. The air con unit still needs plumbing buy it fits ok.
Attached File  P1110618.JPG   159.52K   19 downloads
Attached File  P1110630.JPG   178.09K   19 downloads
#59 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 24 February 2017 - 04:00 PM
Had a few hours to spare early in the week, fitted some fans to the cheap alloy radiator and put it in on rubber mounts.
I am going to put an air con condenser in front of it, should I mount the condenser directly in front of the radiator or leave a gap?
Attached File  P1110635.JPG   172K   17 downloads
Attached File  P1110638.JPG   142.9K   19 downloads
#60 Bigfella237
Posted 25 February 2017 - 12:19 AM
I wouldn't mount it directly to the radiator, some of those alloy radiators tend to crack around the mounts as it is, so the less weight hanging off it the better. But the closer you can get it the better too, it doesn't have to be air-tight but the fans will need to be able to pull air through the condenser when the A/C is running so you don't want too big of a gap.
I notice you have a large gap between the radiator and the support panel too. If you can find some way to seal that as best you can it will allow less air to escape around the radiator (meaning more air must pass through it).
One last suggestion is that you make sure the radiator is well earthed to the body, you can often actually read a voltage between the coolant and ground (that's a bad thing especially in an all-alloy application)!
#61 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 25 February 2017 - 11:13 AM
Thanks Andrew,
All good points, I have an idea to seal the gap with insulation. Gap was so I could use rubber mounts which are 20mm tall.
Also planning on earthing the radiator and I might run some extra earth wires throughout the car to eliminate the chance of bad earths and avoid having to sand painted sections to get a good grounding point
#62 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 07 May 2017 - 06:47 PM
As always time to work on the car is scarce but slowly I have been trying to fit the exhaust past the gearbox cross member and work out where to fit the 4" diameter cats, hasn't been going well but to make it easier getting past the gearbox cross member and keeping the pipes and cats away from the ground I modified the cross member and think it will fit a bit easier now
Attached File  P1110749.JPG   152.7K   25 downloads
Attached File  P1110755.JPG   152.15K   26 downloads
#63 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 18 July 2017 - 08:52 PM
Made this piece of exhaust recently, uses a Pacemaker crossover pipe thing and gave it a coat of that exhaust paint in a spray can which looks much better than I thought
Attached File  P1110826.JPG   154.86K   20 downloads
Attached File  P1110830.JPG   155.01K   18 downloads
#64 _duggan208_
_duggan208_
Posted 19 July 2017 - 12:41 AM
Woof , where is that frocking bone. Looking good.
regards
#65 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 23 July 2017 - 06:46 PM
Thanks Jon, rare I get time to make a little progress lately. He is a little dog but always seems to be looking for something to eat.
Added the mufflers today and changed the park brake setup. The way I had got the cables through with the CRS chassis kit was ok but not great and needed something better, I bought some sliding door rollers from Bunnings and moved the cables to above the CRS chassis rails instead of below and it looks a lot better. Rollers are rated to hold 30kg each, am hoping it is enough and they have a bearing in the middle.
Also fitted the speedo cable and pass through sensor, had to point the cable out the back of the gearbox but it is still long enough to reach the dash.
Attached File  P1110849.JPG   156.43K   18 downloads
Attached File  P1110843.JPG   160.14K   17 downloads
Attached File  P1110846.JPG   156.07K   17 downloads
Attached File  P1110855.JPG   155.35K   17 downloads
#66 Slack
Slack
  • 63 posts
  • Name:mick
  • Car:6/76 lx hatch 75 lh sedan
Posted 23 July 2017 - 09:10 PM
gday Tom, What part number vintage air unit did you use, so many choices on the net but none close by to physically look at. thanks mick
#67 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 27 July 2017 - 10:22 PM
Hi Mick,
It is the Gen II mini VA66005-VUZ-A
I have not connected it and had it running yet but it fits under the dash ok
#68 _LS1 Taxi_
_LS1 Taxi_
Posted 28 July 2017 - 08:11 PM
Great progress! Keep at it :)
#69 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 29 July 2017 - 10:01 AM
Hi Tom
Just read start to finish and looking good
Had to smile with the crossmember as i just went through the same thing but with a T10 box
Looking at the yoke going into the extension housing it seems it could need to go in a bit more but not sure if the photo was taken with the car suspended
Normal rule of thumb is with the cars suspension under compression you push the yoke fully in until it stops then withdraw it round 3/4 to an inch for full spline engagement length
Just seems you have a fair bit of the yoke still out of the box - hate to have looked at a potential weak spot in the driveline and not let you know
Cheers and love your work
#70 _SQ5_
_SQ5_
Posted 29 July 2017 - 07:43 PM
What make is the LittleJohnpaint tank?
regards
#71 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 30 July 2017 - 08:16 AM
he sells them on ebay
uses a commodore fuel pump, cuts the legs and rotates the base 180degrees from the top so it will fit. looks successful but i havent tested it yet. there would be other ways of putting pumps in the tank like the holley hydramat too
http://www.ebay.com....XUAAOSw-CpX~ZU4
#72 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 08 September 2017 - 08:09 PM
Moved house recently so the car had to move, I pretty much threw the wiring in and got it running and drove it with an unregistered vehicle permit to the new house.
Was great to get it running and drive it even though it was only 450m, had some issues getting it started as I didn't know how the Torana ignition switch worked.
The trouble shooting instructions that came with my loom from Ultimate Conversion Wiring had the answer and after bridging the wires from crank to ignition it fired up, thanks Justin for making a good looking neat loom and all the help you have provided on the phone too. Great to hear it running in the car, bit loud without tail pipes but very enjoyable. Everything worked and I took it down the street into it's new garage. Brakes worked at the other end too. The engine bay is a bit of a mess and I don't like my coil mounts but will change that when there is time. Had the ECM, fuses and relays just sitting on the floor in the car as there wasn't time to mount it all.
Although I didn't have a dash I could see the speedo cable wasn't turning which was a bit of a concern as I immediately thought the worst and it might have been a problem in the box but I took the cable out today and found after putting the 90degree and pass through sensor back in it works now. I ran the car today in the garage with the wheels off the ground to test the speedo and also waited till the fans came on switched off, happy all that should have worked did.
Lots to do yet but nice encouraging progress.
Attached File  P1110887.JPG   152.61K   28 downloads
#73 Bigfella237
Posted 08 September 2017 - 09:21 PM
Nice one Tom, that should re-energise the itch to get it on the road!
#74 _LS1 Taxi_
_LS1 Taxi_
Posted 08 September 2017 - 10:54 PM
I'm expecting to look over this sunchook at toranafest.
A few sleepless nights coming up!!
#75 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
Posted 09 September 2017 - 08:56 PM
Sure will Andrew, somehow I will have to make more time for the car. Bought an old house and it needs lots of work. Garage required a half rebuild before the car could move in.
Unfortunately Darren I have to disappoint you as the chook will still be in the coop and I will be away for work so won't even be going to spectate,
