XU1 Retainer plate
92 replies to this topic
#26 rodomo
Posted 13 May 2014 - 12:47 AM
No, relieved on the trailing edge of the blades...........to miss the bolts....................as per the pic.
Edited by rodomo, 13 May 2014 - 12:49 AM.
#27 _LONA-CK_
_LONA-CK_
Posted 13 May 2014 - 05:53 AM
if you use a lc fan you want need to cut or shave anything.
cheers gong
#28 Ice
Posted 13 May 2014 - 08:51 PM
Ok so the bolts i got with the retainer plate are little loose in the holes should i get correct bolts size to suit the holes
#29 N/A-PWR
Posted 13 May 2014 - 09:01 PM
Hi Gene,
You need a Bolt with a small shank near the Hex Head that is exactly the same size as the Holes,
so when the XU1 Retainer is fastened up tight, the Retainer is running True. Dave I
I can Make 3 for you
#30 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 13 May 2014 - 10:08 PM
Gene by memory 1/2 x 3/8 UNF bolts ? , they will be all thread as they are short
Don,t forget to put a star washer on each bolt
And just check the diameter of each hole if the bolts are loose as you said , should be a snug fit , seems strange as my initial thought holes were drilled out too big on the plate ..
#31 Ice
Posted 13 May 2014 - 10:13 PM
Thanks guys yes Shaun there is a little play with the bolts in not much but its noticeable
should they be high tensile bolts
#32 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 13 May 2014 - 10:28 PM
gene , I like to use high grade bolts , I try and buy grade 8 if possible , if not settle for next lowest your bolt shop carries ....
#33 Ice
Posted 13 May 2014 - 10:37 PM
Grade 8 its is then
#34 _Skapinad_
Posted 14 May 2014 - 06:19 AM
I thought you had the motor out already ?
#35 Ice
Posted 14 May 2014 - 07:44 AM
Just about
#36 _Skapinad_
Posted 14 May 2014 - 07:48 AM
so you have disconnected the battery ? :)
#37 S pack
Posted 14 May 2014 - 09:16 AM
I used the supplied bolts without issue.
#38 Ice
Posted 14 May 2014 - 05:53 PM
Yes its all ready to lift out
The engine that is
#39 A9X34
A9X34
  • 30 posts
  • Name:Mark
  • Car:Garry Rogers group c a9x and 1972 lj gtrxu1
Posted 14 May 2014 - 10:31 PM
TIP: If you file or scribe a line on the face of the retainer in line with the timing mark you can tell in future if the outer ring slips.
#40 N/A-PWR
Posted 14 May 2014 - 10:36 PM
Great Tip Mark
Thank-you
#41 _macdou_
_macdou_
Posted 21 May 2014 - 08:16 AM
PM sent to rodomo
#42 _macdou_
_macdou_
Posted 21 May 2014 - 04:28 PM
Can someone please post some dimensions of the retainer plate as I will try to reproduce one for myself. Wall thickness and weight would help as well. Thanks
#43 N/A-PWR
Posted 21 May 2014 - 07:46 PM
Well, if nobody puts up the Measurements Ken,
I will measure Up Gene's, to the 10th of a mm, and put up here in the next few days. Dave I
#44 _macdou_
_macdou_
Posted 22 May 2014 - 08:10 AM
Thanks Dave that would be great. Cheers
#45 N/A-PWR
Posted 22 May 2014 - 09:34 PM
I now have Gene's XU1 Harmonic Ballencer Retainer Plate,
will measure it up and put the information on here Friday Night. Dave I
I recon they are a Stuffed Ballencer Detector
#46 N/A-PWR
Posted 23 May 2014 - 09:03 PM
Here you go Ken,
Attached File  XU1 Ballencer Retainer 001.jpg   223.13K   3 downloads
#47 rodomo
Posted 23 May 2014 - 09:22 PM
Dave, I only did technical drawing until year 10. Maybe things have changed? Can you explain the 51,104, and 114 measurements please?
#48 N/A-PWR
Posted 23 May 2014 - 09:38 PM
Great pick-up Rob,
That's the pop-out part of the pressing, in not so many words,
So when looking at the Retainer from the side and where the Retainer bolts to the Harmonic Ballencer,
the pressing starts to curve at 104 diameter, and straightens up at 114 diameter at 5.7 off-set to the greater 139.9 diameter at the outside, and the 51 is the inside diameter as shown in the bigger diagram. Dave I
so in a nutshell, this is a side cross-section of the top half of the drawing,
I really should of put in the A-A marks to explain where the section is taken from, oh well.
also the blank bit to the left of the 104 number, is the 9.5 hole in the Main picture.
so if you drew a line from the inside through a hole to the outside, that is the section
Well, we need Gene to take a 3D shot so we have a different angle to look at hey
Edited by TORYPOWER, 23 May 2014 - 09:53 PM.
#49 rodomo
Posted 23 May 2014 - 09:54 PM
So.................how far is the 9.5 hole from the center of the 51 hole?
#50 N/A-PWR
Posted 23 May 2014 - 09:55 PM
Gene, can you weigh it to please
I didn't put the bolt hole P.C.D. till I got the exact measurement from Holden
Edited by TORYPOWER, 23 May 2014 - 09:57 PM.
