772 replies to this topic
#126 _Agent 34_
Posted 25 February 2015 - 05:52 AM
Racing / regularity always brings out issues with cars, this meeting Brakes seemed to be issue. In the background i have been working on getting a 4 spot caliper set up for the car and have found and cleaned the volvo calipers.
I now just need better brakes on the car.
also the ball joints were rooted - so also need to split the front end to replace.
So it's at the shop now and in a few weeks ( due to everyone doing their bit) we will have new brakes.
other little things that happened over the weekend
broke the accelerator arm - vibration
the castor nolethane bush disintegrated
always carry a spare set of brake pads
things that need to happen between races tighten nuts
  • rocket cover nuts
  • side plate
  • engine manifold - carby - exhuast
  • tension up wheel nuts
  • general check of engine area for oil leaks - loose stuff
double up the accelerator arms off the main rod  and put a bolt through as they vibrate and crack.
Log Book - Nc
I have also decided that whilst the car is in there I will change over the gearbox to the aussie from celica and get it passed for group NC spec car. this just gives me some ability to have a go an NC when and if i feel the need. It's an itch i need to scratch.
I'll miss that celica box and not looking forward to the aussie oi oi oi
So the changes i need to make for log book;
  • aussie 4 speed
  • interior
  • back seat
will post up some photos as we go.
also need to upgrade my license
Edited by Agent 34, 25 February 2015 - 05:54 AM.
#127 darway43
darway43
  • 215 posts
  • Name:David
  • Car:LJ 2 door
Posted 25 February 2015 - 06:27 AM
Great work Grant, some good advice there too. Sounds like the development of the car is really coming along. Awesome stuff and keep it going, enjoying the read.
Dave
#128 _Agent 34_
Posted 04 March 2015 - 06:10 PM
Update # OK i'll start at 10
Well i have been sorting out some issues with the car and last episode at the track it was not " where's wally " it was " where's the brakes" !
so i have been sort of planning the 4 spot conversion for awhile and was lucky enough to find a set of calipers , and one spare ( 3 in total ).
Getting them clean was a job in it'self and removing the pistons from the housing.
to do this i used a 10mm cup head bolt and then ground it down till it was a knock in fit to the piston cup , I then put a flat bar across and then put a nut on which i wound out.
some come out easy and others were a bit harder - but the came out.
A bit of bling.
I bought the mylar strip for the windscreens and made up a tool to put in. Can recommend that you used the joining clips in the rares pack as any other clip is too wide and dosen't sit right.
I made my own mylar strip installer out of a piece of welding rod - took a few attempts but go there and works a treat .
Stripped the front end and next week will have all the items to go back together
still need the calipers re built which will happen next week as well.
modified the stub axles to take the new calipers + also adjusted them so that CAMBER is now built into the stub axle rather than running a heap of shims.
1 more mill.
G
#129 Davis
Davis
  • 343 posts
  • Name:Drew
  • Car:LC 2 door
Posted 04 March 2015 - 08:07 PM
Nice work....
Curious to see the stub axle mods for fitting the 4 spots and increasing the camber?
#130 SmacT
  • 1,026 posts
Posted 04 March 2015 - 09:03 PM
+1^ and cool job on the strip tool. Coolness. :-)
#131 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 04 March 2015 - 09:19 PM
Thanks for the pics of the insert tool
will give it a go as am in the process ATM myself
#132 RallyRed
Posted 04 March 2015 - 11:01 PM
Nice work Grant...following the brake job with interest
#133 _Agent 34_
Posted 17 March 2015 - 06:49 PM
update #11
what a head F#%$K but i'm there with the brakes.
  • all the parts are at the mechanics.
  • new disks
  • new calipers
  • new pistons
  • new - off camber stub axels
  • stub stiffeners
  • new master / reco one sitting in garage
  • new moog ball joints in.
driveline;
  • cross member in
  • tail shaft in - or we have one their
  • bell housing in and clutch re hooked up
I am still chipping away at the roll cage issue with CAMS and also the eligibility officer at  HSRCA.. Let me say that  it's pretty disjointed process.- but quietly hopeful
gear box off to JVR tomorrow for a rebuild  to XU1 ratio HOWEVER you now cannot by the 899 cluster as there is a copy right and it's now a NEW NUMBER LOL !
slowly slowly catch the monkey  !
#134 SmacT
  • 1,026 posts
Posted 17 March 2015 - 07:02 PM
Cars are just one big headf^%#$^%$ aren't they?
But you might like this: http://sydneymotorsportpark.com.au/
Went live this arvo mate, thanks again for your help. Keep at it!
#135 _Agent 34_
Posted 18 March 2015 - 05:16 PM
Cheers Sam for that, I would never had thought that the car would end up there on the front website of ARDC  - so thanks for the opportunity and also the other photos you sent. Although 52 is not my number LOL!.
OK so a little bit more of catchy monkey
the roll bar is an early 1970 ish  ( no later than 75 ) one and its a 1 3/4 quarter aluminum grade. There is a difference in the rear strut thickness and after speaking with bond roll bars he can generally tell who made the bar by different welding and brackets also by the type of aluminum. very interesting conversation indeed.
The roll bar is the issue now which will be the major NC issue with CAMS, but am working through this slowly. BUT the bar is certifiable and also has stickers. The funny thing is that a car in NSW which had a roll cage fitted could then move to another state and the following could happen;
smash - re shell - which is acceptable
smash - no tags new inner guard - which is acceptable
CAMS looses records or poor records exist back to this time  - won't admit or records not kept correctly
log book gets lost - human error owner
Cams recorded the log books by chassis or VIN ( to the best of my knowledge ) and being race cars both of these identifiers were easily lost or damaged.
It seems at this ERA there were only a few roll cage builders
I was amazed that after a review of the detailed  photos of the cage he was able to tell me a lot more of the specific time and who made the cage - to the point where by he said X made the cage and then Y welded it because X was a shit tig welder  - HA!
so a bit more.
Edited by Agent 34, 18 March 2015 - 05:19 PM.
#136 SmacT
  • 1,026 posts
Posted 18 March 2015 - 07:09 PM
Half the fun of cars is the story around them. Good stuff on the cage.
And yeah, 52 is because your car represents the ARDC, been around since 1952. Cool shot, though, and I'd take the Torrie over the Ferrari any day... Speak soon.
#137 _2ELCS_
_2ELCS_
Posted 18 March 2015 - 07:19 PM
Spending up at Keiths again Grant ?
#138 RallyRed
Posted 18 March 2015 - 08:45 PM
nice pic at SMP/ARDC Grant!!....
p.s. I knew him before he was famous!
#139 _Agent 34_
Posted 27 March 2015 - 05:16 AM
yes Wayne - he's off to Hawaii on a boat, thanks to the axle making episode 26 at last count, last time i was there his missus sat me down and thanked me took me heart beat and checked my blood pressure, just to make sure that i could keep bringing work to keith before she planned another holiday LOL
I only have one more thing for Keith to do and that;s the rose joint  linkage arms for the Aussie Box - which I will get done later in the year.
update;
well brakes are all together, pick up the box today - found a tail shaft - So next week we will do the Castor and camber again then off to bond roll bars.
Col " only in my own little lunch box"
I have much better pics that SamT sent across at Hi Res which i will try to resize and upload later.
#140 _Agent 34_
Posted 31 March 2015 - 06:36 PM
1) box in and done
2) tail shaft in and painted new uni's.
Were done.
sorry not many pics on this but will update when I get the car done.
also getting a blue slip as well - not sure how but it's happening - " i didn't ask too many questions" - so i can get a historic plate as well.
slowly slowly catchy monkey !
#141 _Agent 34_
Posted 25 April 2015 - 05:09 PM
Well this week hopefully have the inspection for Log book and whilst my fingers are crossed for the cage, it's not a done deal until I submit the paper work to CAMS.
Was hoping to run @ retro speed fest but at this stage will likely be running in regularity again but will be awesome with new brakes and new box so it will hopefully go smoothly.
Getting a medical for Tuesday.
Then will do my license upgrade @ friday practice at Retro. At least i will have the license sorted out.
found a new engine builder last week through referral.
I walked into his little shop and there was pictures of his racing black LJ and all other matter of racing material.
Dead set he has a Wall 1.5x 2 with all bent conrod's busted pistons snapped cranks with a sign saying " offering to the gods" underneath it !!
A bit more.
#142 Dodgey
Dodgey
  • 437 posts
  • Name:Steve
Posted 25 April 2015 - 06:51 PM
Grant. Do you already have a HANS Device & appropriate helmet. If you are doing the research, I would be interested in what you choose and where you buy.
Steve
#143 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 25 April 2015 - 07:54 PM
How are the new brakes going?
#144 _Agent 34_
Posted 26 April 2015 - 06:30 AM
Steve
HA - Steve funny you should mention this as when i was a bathurst i spoke at length to the " frontal head restraint device" , HANS is a brand of front head restraint !- to which he kept reminding me of.when i kept referring to his simpson product as HANS !
I have only tried the " simpson" product and it's got the clip around your chest like a harness, it seemed pretty comfortable and then all that happenes was that the clips then went onto your helmet. It seem to leave your neck area and also your shoulder areas  quiet free to move.
There are only two models in the " simpson" and this really only relates to the " material type " being " plastic and carbon fiber " V shaoe which sits between your shoulder blades.is made out of + the more expensive one has padding.
From memory it was $900 and $1200 between the two. ( without helmet)
I have not tried the HANS but the opposing sales rundown I got off the " simpson" bloke is this;
1) it hard to get the correct fit unless you by the super dooper expensive one which is dearer than the simpson top line
2) they are quiet restrictive with the frontal restraints and un comfortable - but yet to try
3)poor range of movement once on
base model one $600 and then it right upto fully adjustable $1600( without helmet)
so you can really see based on price why the lower price hans one is popular so for  around $1100 you get a " frontal head restraint device and also a new helmet"
I really need to go and try back to back and have a another chat to a few blokes - HANS seems to have the market due to being the FIRST maker in the industry  and you can get your helmet on and off without with what seems like less intrusive effort as the brace is attached to the helmet, The simpson bloke did say that this can also happen with his product.
I didn't mind the feel of the Simpson and will probably do some more homework at retro speed fest.
Steve with all the other stuff going on i totally forgot about the helmet that's why i decided to  take a back step with my entry. Getting this inspection for NC has been difficult to arrange and also the work to the car at the shop was delayed as he was running in Bathurst which stuffed up completing the works.
James - had to put some spacers on the front as the wheels were hitting.  The cars complete it just has to stay at the mechanics till the NC inspection. Hopefully this week
Edited by Agent 34, 26 April 2015 - 06:33 AM.
#145 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 26 April 2015 - 07:14 AM
The Volvo calipers are a very snug fit. I can fit sprintmasters over mine without spacers but have to use very thin weights for balancing otherwise they get knocked off.
#146 _Bomber Watson_
Posted 26 April 2015 - 09:48 AM
What levels are you looking at racing in?
Fhrs are only required in state level race events or national level tarmac rally events (targa rallies and ralleysprints) according to the manual of motorsports 2015.
Interesting side note I just found, don't get a sfi 38.1 only device, as they are only allowable untill the end of the year. Make sure its fia 8858-2010 or fia 8858-2002. If its either of the fia standards and the sfi standard then that's fine.
#147 _Agent 34_
Posted 26 April 2015 - 05:20 PM
NC state level - but am intending. to do a Bucket list of tracks over the next 10 years.- which may include National events.
there are also National events in NSW.
After retro I'll be a bit better informed on the HANS branb.
#148 Dodgey
Dodgey
  • 437 posts
  • Name:Steve
Posted 26 April 2015 - 05:27 PM
Thanks Grant & Bomber. Appreciate the comprehensive update. I'm keen to see where you go with a FHR Grant given your desire to race in Group Nc. Not sure if I will venture beyond Regularity, Sprints and Targa Touring but FHRs are a valuable safety device that reduce the likelihood of head and/or neck injuries and may well be worth wearing irrespective of the category competing in.
#149 RallyRed
Posted 26 April 2015 - 06:09 PM
Thanks for doing the homework guys,
Like Steve I have been pondering too.....
it's not a cheap thing...but in time I guess it will just be like seatbelts and roll cages.....we'll look back on pics of people without them and say WTF?
#150 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 29 April 2015 - 02:14 PM
Before you go WOT FOR... bed in the brake pads/shoes! I fitted new rotors late last year, the pads are only just right, and the new rear shoes still need time.
