Fact or Fiction.
768 replies to this topic
#351 _sstorana_
_sstorana_
Posted 19 August 2015 - 05:12 PM
HEy Dr Terry,
quick question..
Why did some of the Engines go to an "X" prefix?
couldn't see anything in your book.
Mick
#352 yel327
Posted 19 August 2015 - 05:55 PM
That's an easy one Mick. It is for ADR27A auto 6cyl Holden (as in HX-HZ) engines used in LX and UC. The X was stamped at the assembly plant to show it was going into an LX (later UC). Exact same principle and the 11, 12 or S prefix used for engines into Statesmans. The manual versions remained as Torana engines and didn't need the X.
#353 _sstorana_
_sstorana_
Posted 19 August 2015 - 09:52 PM
Thanks Byron,
any idea why the engine prefixes changed in Sept 78?
Mick
#354 S pack
Posted 19 August 2015 - 10:01 PM
Thanks Byron,
Mick
HQ engine number sequence reached 999,999 during HZ so new prefix required for number sequence to start over ie: ZL1001
#355 Dr Terry
Dr Terry
  • 3,359 posts
Posted 20 August 2015 - 08:18 AM
HEy Dr Terry,
quick question..
Mick
Byron has explained why, but these prefixes are all listed under their respective model applications.
Dr Terry
#356 _sstorana_
_sstorana_
Posted 20 August 2015 - 08:40 AM
Dr Terry,
Why was there a change in the engine prefixes on the 1 Sept 1978?
Mick
#357 yel327
Posted 20 August 2015 - 09:36 AM
There wasn't for Torana engines Mick, they continued with H prefix and their own sequence. Only the auto 6cyl engines changed inline with the chance from Qx to Zx in HZ but it wasn't September it was closer to December.
#358 Shiney005
  • 10,029 posts
Posted 20 August 2015 - 10:45 AM
In one ATCC race, the HDT placed 1st, 2nd, and 3rd.
Fact or Fiction.
#359 yel327
Posted 20 August 2015 - 11:34 AM
Fact or Fiction.
Wanneroo Park 1978?
#360 _sstorana_
_sstorana_
Posted 20 August 2015 - 12:06 PM
Byron,
Torana Engines for LH, LX and UC were as follows;
LH
2.85lt Hi Comp     (LD1)    -  HD Prefix,
2.85lt Low Comp  (LD2)    -  HE Prefix,
3.30lt Hi Comp     (L20)     -  HL Prefix,
LX (prior to 1 July 1976 (ADR 27A))
3.30lt Low Comp  (L23)     -  HM Prefix,
LX (Post 1 July 1976 (ADR 27A))
2.85lt Low Comp  (LD2)    -  XQE Prefix (Auto Trans),
3.30lt Hi Comp     (L20)     -  XQL Prefix (Auto Trans),
UC (prior to 1 Sept 1978)
2.85lt Hi Comp     (LD1)    -  XQD Prefix (Auto Trans),
UC (post to 1 Sept 1978)
2.85lt Hi Comp     (LD1)    -  XZD Prefix (Auto Trans),
2.85lt Low Comp  (LD2)    -  XZD Prefix (Auto Trans),
3.30lt Hi Comp     (L20)     -  XZL Prefix (Auto Trans)
Edited by sstorana, 20 August 2015 - 12:08 PM.
#361 yel327
Posted 20 August 2015 - 12:58 PM
That cannot be correct Mick, as Z prefixed engines didn't appear in cars until around Nov-Dec 1978. They may have started stamping engines in September with the Z prefixes but Q prefixes were still being put into cars in 10/78 into 11/78. The engine plant at Fisherman's bend didn't specially make engines for auto 6cyl Torana either, they were simply sent out as a Holden auto engine and it was the assembly plant that stamped the X into them, so when Z prefixes started in Holden they'd start in Torana at the same time.
I have the Service Bulletin somewhere that states the date they started, i'll have a look tonight.
The LD2 auto engine in later UC is XZE too, you have it as XZD
#362 _sstorana_
_sstorana_
Posted 20 August 2015 - 02:01 PM
Byron
just going off what is in Norm's book and Dr Terry's book.
I had a look through my service bulletins and couldn't find anything. If you have to, can you tell me the group and date please?
Mick
#363 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 20 August 2015 - 05:50 PM
f or f ?
The V8 Holden engine was based upon a Chev V8 but ended up being "unique" in design by being the lightest V8 of the era?...and...the plastic has won more Panoramic titles than any other V8?
#364 yel327
Posted 20 August 2015 - 07:32 PM
Byron
Mick
Mick
Couldn't find the 1978 stuff tonight, only 1979. Will look in archives tomorrow.
#365 _ChaosWeaver_
_ChaosWeaver_
Posted 20 August 2015 - 07:37 PM
f or f ?
Fact...........
#366 yel327
Posted 20 August 2015 - 08:11 PM
I would have though the alloy Rover V8 of that era would have been lighter?
#367 Shiney005
  • 10,029 posts
Posted 20 August 2015 - 08:53 PM
Wanneroo Park 1978?
Yep. Brock Harvey Negus.
#368 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,429 posts
  • Name:facebook dave
Posted 20 August 2015 - 09:07 PM
Fact or Fiction.
laurie
i,ve got a photo print of that!
fact!
#369 _Mint_
_Mint_
Posted 20 August 2015 - 09:33 PM
f or f ?
thought it was based on a Pontiac v8?
#370 rodomo
Posted 20 August 2015 - 09:58 PM
Maybe the lightest cast iron V8? Alloy inlet manifold, timing cover and water pump.
But, also, dissy at different end of the block and different "V" angle compared to Chev?
#371 S pack
Posted 20 August 2015 - 10:34 PM
I'll say Fact.
#372 xu2308
Posted 20 August 2015 - 11:42 PM
F or F
GM Holden were tinkering with the XU2 Name for V8 LJ Torana
#373 N/A-PWR
Posted 20 August 2015 - 11:57 PM
Fiction, was for the LH SL/R XU-2
#374 xu2308
Posted 21 August 2015 - 12:03 AM
Phil Zmood's
GM Holden Design Drawing of LJ XU2 Torana 308 V8.  So Fact
#375 N/A-PWR
Posted 21 August 2015 - 12:07 AM
apparently,
the LJ was a  cover to throw the media off of the LH coming out,
could be wrong,
although Harry did put a 253 into an XU1,
where GM did make 3 V8 LJ's,
one Strike me Pink
