Fact or Fiction.
768 replies to this topic
#101 S pack
Posted 12 August 2015 - 08:09 AM
The first 48-215's rolled off the Elizabeth production line in 1948.
F or F.
#102 REDA9X
Posted 12 August 2015 - 08:11 AM
Constantly I readhow the A9X had the UC rear floorpan. The quickest answer I have is go and open the boot of a UC and an A9X and you'll have your answer. Where does the spare in a UC sit, and where does it sit in an A9X? Which came out first too? UC or A9X?
So Red,
Didn't the A9X have a bolt in piece to do the UC connection,
which is the only bit like the UC.  :D
EDIT:-
The A9X borrowed a section of the rear floorpan from the new UC Torana to allow the vastly improved Radial Tuned Suspension (RTS) geometry and fitment of the much stronger Salisbury rear axle assembly complete with disc brakes. This made the A9X the first Holden ever to be fitted standard with rear discs, and the Salisbury differential also meant the extra tall 2.60:1 ratio could be used.
#103 eyepeeler
eyepeeler
  • 1,963 posts
Posted 12 August 2015 - 08:28 AM
False and False.
48-215 had two headlights, as did FJ through to whenever. HK was the first to get quad or 4 x headlights on both Premier sedan model and Premier wagon model.
Others got the Brougham.
Leo tried hard to get quad lights on GTS but wasn't allowed until HZ.
LOL, that's what I meant, twin as in 2 side by side on each side of the car, not twin 1 per side of the car. Never seen a mono headlight car. I wonder if one was ever made?
#104 yel327
Posted 12 August 2015 - 09:02 AM
http://www.google.co...CFeIXpgodu7MFwg
Here's one with three:
#105 yel327
Posted 12 August 2015 - 09:05 AM
I'd be betting money that UC protos or even pilots were around before the first A9X was actually assembled. The UC design is most likely where the floor patch originated.
#106 _Bomber Watson_
Posted 12 August 2015 - 09:21 AM
All slr5000s had flares f or f
#107 S pack
Posted 12 August 2015 - 09:40 AM
hahahahahahahahahahahahaha. Then or now?
#108 hanra
Posted 12 August 2015 - 10:04 AM
According to Facebook. That is cold hard fact.
#109 yel327
Posted 12 August 2015 - 10:24 AM
Only when a driver was in them.
#110 hatchssv8
hatchssv8
  • 358 posts
Posted 12 August 2015 - 10:34 AM
F or F?
"Privelidged"  A9X hatches came with aluminium closures
#111 UCSLE
UCSLE
  • 740 posts
  • Name:troy
  • Car:Goggomobil
Posted 12 August 2015 - 10:59 AM
the only thing they have in common was the top control arms ? which came from the HQ ?  i also think the only reason the HQ , A9X and the UC
all share the same top control arm spacing is because they all had cast iron diff housings , the spacing better suits the cast iron centers .
#112 yel327
Posted 12 August 2015 - 12:38 PM
What I meant was the UC design would have been locked in a long time before any production A9X was built. So to fit the Salisbury all they'd need to do was build the floor patch for the LX that replicated the UC's UCA attachment.
There is another reason why HQ-WB design is so radically different to any Holden before it or to the locally designed LH-UC Torana, but i'll leave that explanation up to someone else for a later date.
#113 Bigfella237
Posted 12 August 2015 - 12:53 PM
F or F?
WTH are "aluminium closures"?
#114 hatchssv8
hatchssv8
  • 358 posts
Posted 12 August 2015 - 01:10 PM
the hatch closure
the hatch itself.......
Edited by hatchssv8, 12 August 2015 - 01:11 PM.
#115 _76lxJAS_
_76lxJAS_
Posted 12 August 2015 - 01:31 PM
F or F?
ill say fiction,
#116 _big jack_
_big jack_
Posted 12 August 2015 - 04:20 PM
Fact or fiction LX Hatch came out in a 4WD version
Fact
s0ymn8.jpg    :stirpot:
#117 _sstorana_
_sstorana_
Posted 12 August 2015 - 07:27 PM
Fact or Fiction...
There were only 135 SS 5000's built??
#118 Ice
Posted 12 August 2015 - 07:36 PM
Fact or Fiction...
Big Fiction Mick
#119 S pack
Posted 12 August 2015 - 07:39 PM
F or F.
#120 _sstorana_
_sstorana_
Posted 12 August 2015 - 07:40 PM
LOL!  Yep...
I am very close to having the correct numbers..
Hopefully will know by Toranafest.
#121 Ice
Posted 12 August 2015 - 07:46 PM
F or F.
Fact
#122 S pack
Posted 12 August 2015 - 07:55 PM
Fact
Ficton.
Construction of the Elizabeth Plant didn't commence until 1958.
#123 Ice
Posted 12 August 2015 - 08:06 PM
Ficton.
Arh didnt read it properly your right you got me it was Fishermen Bend
#124 hanra
Posted 12 August 2015 - 08:12 PM
LOL!  Yep...
Cool. Eager to read about it.
#125 _sstorana_
_sstorana_
Posted 12 August 2015 - 08:16 PM
Hey Brad,
the results will certainly surprise a lot of people.  We are just waiting on a reverse count confirmation..
Also, hope to have the break up of Autos/ Manuals as well.
Mick
