And many consider the phase 3 not only as a muscle car, but the fastest 4 door car in the World, and it was basically, an american muscle car, with our Ford falcon body ontop.....
Not that much is Aussie design about those Falcon bodies either.
Posted 18 December 2015 - 06:54 AM
Posted 18 December 2015 - 07:55 AM
Bit like a Chinese Gooseberry or a Kiwi Fruit, same thing, two different names
Posted 18 December 2015 - 08:44 AM
You forgot the LC/LJ/UC at the start of the thread title
Posted 18 December 2015 - 08:58 AM
And if GMH hadn't decided to switch to the LC as the weapon of choice and continued with the HG a GT-HO may never have ever won Bathurst. 1970 would have been a close thing, the race was actually significantly slower than 1969 and Harry would have had another year of development which should have included his Old man Emu HG with the LT1 engine but even if the 1970 race had seen a HG using the 1969 engines further developed it'd have been very close. After that though 1971 and 1972 would have been totally different, what would have happened is anyone's guess. Ford may even have pulled out of racing as at the time there really was no other engine in the Ford stable suitable for the task, the Cleveland they had was the best available, they'd have to have developed it further whereas GMH had access to that wonderful 1970 Z28 LT1 engine if needed.
Posted 18 December 2015 - 09:11 AM
Its agreed. Toranas are definitely not musclecars.
So does that make Toranas, Pony Cars?
Pony car is an American class of automobile. The term describes an affordable, compact, highly styled car with a sporty or performance-oriented image.
* runs & hides before the can of worms erupts.
s
Edited by StephenSLR, 18 December 2015 - 09:12 AM.
Posted 18 December 2015 - 09:20 AM
Posted 18 December 2015 - 09:27 AM
I'm tending to agree with yel, the only one we had was the GTS327.
What about the 360 Charger; didn't they stick the biggest boat anchor they could find into a Charger?
I recall a joke about the 265 Chargers with triples; if you wanted the fuel efficient version, you got the 360.
s
Posted 18 December 2015 - 09:37 AM
Edited by Bomber Watson, 18 December 2015 - 09:37 AM.
Posted 18 December 2015 - 09:41 AM
The 340 E55 Charger in a VH is the gun V8 car, but they were only autos and dressed up as a luxury car sort of like a HQ LS (not sporty). Wheels or Modern Motor put a decent exhaust on one and it was faster than a GT-HO over the quarter. The VH had the high compression 340ci engine, the VK E55 got a far lower performance version of the same spec engine, very much like the L48 changed from HG to HQ (10.25:1 down to 8.5:1) the same happened with the E55 from VH to VK, from memory went from 10.4:1 down to 8.5:1.
The 360c cu engine is like the 2BBL 400 would have been in a HQ. Easily woken up but a doughey stump puller. There were performance versions of the 360 in the USA (just like there was 1971-1974 Z28 350ci SBC engines in the USA) but we didn't get them in Australia afaik.
If you are going to include any Charger in Aussie Muscle it is undoubtedly the E38 and E49. They fulfil all criteria other than being a 6cyl. Nothing was ever faster until the HSV cars of the 90's.
Edited by yel327, 18 December 2015 - 09:45 AM.
Posted 18 December 2015 - 09:46 AM
Posted 18 December 2015 - 09:57 AM
I remember seeing a container full of the 340 Chrysler motors at Indy speed shop in the early 80's of old stock motors. They had steel cranks, good compression with the latest w port heads. They were a very underrated motor, on the level of an LT1 chev.
Posted 18 December 2015 - 10:54 AM
The VH engines had steel cranks. Once these ran out they used the later low comp engine with cast crank in VJ (I said VK before).
340 in US in 1971 was 10.4:1, 850cfm carb, 2.02/1.6 valves and 290hp. Not sure if we got all the goodies in the VH E55. Apparently the 290hp was an under-rated figure. Some good info here:
http://www.e55charge...m/e55-chargers/
Posted 18 December 2015 - 10:57 AM
Aha, auto and 2bbl carb, that ones out.
360 was a 4BBL Bomber, but a lugger not a fighter!
Posted 18 December 2015 - 12:07 PM
E57 360 was a 2 Barrel slug, like you said earlier. The E57 in both late VJ and VK spec was just a caravan tower. Even the 'performance' versions in that US weren't thought much of.
E55 340 in the earlier form was a gun engine. The batch imported in late 1969 had the bigger valve heads. They were the ones that found themselves in the VH E55 SE Charger, and also the first 70 or so VJ E55's. The VJ's after that had the second batch that was imported to get rid of the stocks left in the States and they had the small valve heads. And in case anyone is wondering, the original batch was imported with a view to possible racing. However, the testing of the mule utes canned that and John Ellis went down the 6 pack path. The carbies off that batch of engines found their way onto the E34 Pacer that was a late development for Class D at Bathurst in 1970. But there was never a plan for a 340 'supercar' Charger in 1972, despite the Modern Motor article. John Ellis and CAL were committed to the E49 development, until mid 1972 when a new boss wanted CAL to go down the path of sponsoring golf.....
Regarding the XU1, all I can say is thank goodness some of the bosses in Holden realised there were more races in Australia than Bathurst. The LC XU1 won the 1971 Manufacturers Championship against the Phase 3 and E38, along with four ARC's in a row. The LC's Warwick Farm debut also saw a win against Bob Jane's 350 Monaro, which by all accounts was the fastest series production Monaro at the time. Sometimes the powers that be know better than the blokes in the field, and I firmly believe this was one of those times. My opinion. I was at Warwick Farm, one of the most technically challenging circuits ever in Australia, most meetings from January 1971 through July 1973, and saw the crowds there. So I'll leave it at that. (Because I know there will be paragraph after paragraph singing the praise of Harry's HG forthcoming)....!
Posted 18 December 2015 - 12:17 PM
Least we can say our Aussie Super Car were that fast they banned them ![]()
Posted 18 December 2015 - 02:10 PM
There you go, we only got the 2BBL 360!
You won't get any arguments from me about the LC XU1's credentials. By all rights it embodies the whole US Muscle Car theme other than the lack of cylinders. It too like the HK GT327 has an engine unique within its series, the engine is pulled from the bigger car, it is performance oriented, looks the part, and even goes one further in that the engine is modified for performance. If you ever got a chance to chat to Don Holland he had proof and was adamant that the ARDC stuffed up again in 1970 and he was actually on the same lap as the winning Fords, not a lap down as the official results show. So it does make you wonder "what if?" the HDT cars hadn't suffered from (I think) valve spring troubles.....
BTW Old Man Emu was canned due to enormous cost, XU1 was a far cheaper car with a lot more local content and had a future - imported engines were about to go backwards big time in performance and the HK-HG shape was planned to be gone by the time 1971 rolled around. As you say people within GMH obviously had far more puzzle pieces than Harry did.
Posted 18 December 2015 - 03:52 PM
as someone said (and he was spot on) muscle car means a big piece of American shit box, that is fast in a straight line (because they put a truck motor in a car) and shit everywhere else, especially in Factory Form....
This wasn't a bad thing; the car companies didn't have to overspend on engineering and kept the costs down; they weren't pretending to make them Sports Luxury; just pack in as much grunt as possible to satisfy power hungry customers; bearing in mind these were perfect for the long straight roads of the USA countryside and the Saturday Night street racers who just wanted to switch the thing on, point it in a general direction and slam the foot down.
s
Posted 18 December 2015 - 04:03 PM
Posted 18 December 2015 - 04:35 PM
Posted 18 December 2015 - 05:03 PM
Haha! I was having some fun, which I think this thread is all about ![]()
Bathurst 1970 was an interesting result. I think in the Brock /Morris car, it was the grooves in the valves weren't done properly and they had a failure there. And Bond, having led for the first 5 laps, settled into consistent times, but had problems with the Stromies. Pretty well documented that Don Holland was screwed by the lap count (did someone say Bond and 1976). The other thing about that race is that John Ellis (Chrysler race team boss) is adamant that air jacks were illegal. Which is what Howard Marsden used in the pitstops of the factory HO's. The humble 2 barrel E31 Pacer of Doug Chivas and Graham Ryan was credited 4th, but John Ellis wanted to protest against the factory Fords using the air jacks and he was stopped by the execs at Chrysler as they thought disqualification of the Fords may actually impact negatively on Chrysler in the marketplace, and by then they were already testing the E38's in the form of the mule utes, so weren't overly fussed about what the Pacer achieved. What might have been.....
Edited by oz772, 18 December 2015 - 05:04 PM.
Posted 18 December 2015 - 05:18 PM
At least the ARDC were consistent! Stuffed up lap counts in 1967, 1968, 1969 and 1970. Harry Firth protested in 1967 and got the result overturned. The ARDC covered their butts in 1968, but months later exonerated Des West but never overturned the result. 1969 Des wanted to protest but Harry wouldn't let him as a HDT car won, and we already spoke about 1970. Poor old Des West really should have had 2 x Bathurst wins to his name and Brock ten wins.
Posted 18 December 2015 - 08:35 PM
s
Yes very true........... but Jesuz, it looked embarassing when a little Alfa was hanging on to or leading them .. I had a race with a 6.6 ltr trans am. im xu1... and I was infront the whole way.... when we pulled up at the next set of lights... his mate says to me, " it was blowing a lot of smoke (meaning my car) and I said to him "that you seen every puff of it from where you were ..... still not a lot of cars much faster than a lack of muscle XU-1 .... and "Giant Killer" is a way better handle than some dumb muscle car name ..... V8's sound good, 6 cylinders go good; just ask Nissan & Toyota.....they don't need V8' to make 1000 HP ... Just stirring
Edited by ChaosWeaver, 18 December 2015 - 08:36 PM.
Posted 18 December 2015 - 08:48 PM
I know a lot has been spoken about a V8 XU-1....and it would have been special...... But can you imagine just how special a Inter cooled turbo XU-1 could have been??? lightweight and powerful ........ pretty much like this.... GMH needs to headbutt a star picket for not bolting on a turbo ....
Posted 18 December 2015 - 08:56 PM
You 6 cyl guys have got your own thread (some 72 Bathurst bullshit ) leave the muscle car talk to the V8 guys please, so PING OFF. LOL
Posted 18 December 2015 - 08:59 PM
I think a VL turbo might give you some inkling! If not that one of those dealer made UC turbos.
But a V8 turbo would have been even better! GMH actually tried this on a HX GTS sedan.
At the end of the day i'd put my money on a closer to stock and lower revving 308 XU1 being a better endurance touring car than a turbo six, at that time (ie early 70's).
