202 extractors
154 replies to this topic
#126 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 September 2016 - 02:52 AM
2 space savers = happy days mate lol, although with a Ls3 they could be pretty wide & still toast them easy as ! Sounds pretty fun to try some space savers actually ha ha.
#127 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 September 2016 - 02:56 AM
I would be very nervous about putting 2 different size tyres on the back with the lsd mate, I've seen a few chew to pieces because of this. Those Nissan turbo hair dressers car's insist that you do not do it because it'll wreck the diff. Gary.
#128 Ice
Posted 04 September 2016 - 02:59 AM
Im using Penrite its about $200 for 20 litre drum LS3 takes just under 7.5 litres per oil change
and genuine oil filters
Dealer doesnt touch my cars my nephew is my mechanic has been for the last 25 years +
he can carry warranty work if needed touch wood should be good
#129 Ice
Posted 04 September 2016 - 03:04 AM
When i bought the car it said on the brochure the SS gets a alloy wheel as a spare
3 days after owning it had a look underneath nah spacesaver spare
quick phone call where,s me alloy spare
picked the alloy spare two weeks later they said just drop the spacesaver back in a day or so
no worries still underneath my car no calls yet from the dealer lol
#130 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 September 2016 - 04:25 AM
Gene, the liquimoly is around the same amount, if you check your oil drum, see if it contains zinc ? "Can" have bad circumstances with oxygen sensors. I'm not saying definitely, but it certainly can, also not meant for roller cam engines ask johno for his opinion on the stuff & please don't run thicker than a 5-30 mate. 5-40 hpr 5 maximum, which I'd nearly bet your using has a purple label, used in Hondas ect. Maybe just save it & use it in your torana Gene. & maybe even run some nulon in your Ls3 contains moly, Aussie made slightly cheaper, just wanted to help you mate, Gary.
#131 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 September 2016 - 02:16 PM
Hi Gene, just re read about your oil capacity, i didn't realize that the Ls3 in a holden, was holding 7.5 litres, about time, the pisily little 5.1 litres in a ls1 sort of scares me. I put in 5.6 litres every time, will be more when i fit the oil cooler to the ss, i must remember to do that job soon. Gary.
#132 _Bomber Watson_
Posted 04 September 2016 - 03:01 PM
Sorry, I went to bed.
186 rods are the same as 202 rods, there all the same the only difference is the early ones, then the blue/black/starfire rods, but all the dimensions are the same.
The 186 ran a taller compression height on the piston than the 202, rods were identical.
If your only turning to 5500rpm or so, the red motor rods will be plenty strong enough, and due to being lighter theres less reciprocating mass = less vibes.
#133 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 September 2016 - 09:37 PM
Thanks bomber, probably turn to 6,000 max would did you think of the specs on the CT 35 528 a camtech camshaft for this engine, i know that you favour solid cams. & any advantage of running a 1.6 rocker on the inlet ? Or a waste of time in your opinion please ? Gary,
#134 N/A-PWR
Posted 19 November 2016 - 10:02 AM
Found these today:-
http://www.rodshop.c...ompetition.html
they have the correct length primaries :)
#135 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 19 November 2016 - 01:43 PM
They are similar the ones i was telling you
about Dave to run on THE RAT .mandrel bent
aswell.
#136 _Bomber Watson_
Posted 19 November 2016 - 04:53 PM
THere only 1.5" primary arnt they?
#137 N/A-PWR
Posted 19 November 2016 - 05:16 PM
Seems so DJ
#138 warrenm
Posted 19 November 2016 - 09:33 PM
Nothing wrong with 1 1/2" primaries Bomber, but "correct length primaries" for what? N/A-PWR.
#139 N/A-PWR
Posted 19 November 2016 - 10:22 PM
They look about 31 inch Warren,
 for high revving?
your the PipeMax man
#140 Potta
Posted 19 November 2016 - 10:44 PM
I think he means they're all the same length for optimum air flow.
#141 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 19 November 2016 - 11:01 PM
Would these tuned length duel headers be
better than the tri y's?
And a stupid question could they b joined by
another collector to form a single 2.25 2.5
pipe etc.
Attached File  ph5027tdfa_200x133.jpg   18.1K   1 downloads
Edited by madtoranajzedded, 19 November 2016 - 11:07 PM.
#142 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 19 November 2016 - 11:39 PM
Yes Maz, someone could make a y shape collector for you. Google it mate, they'd be on the market somewhere already. Gary.
#143 warrenm
Posted 20 November 2016 - 05:51 AM
They are long primaries, but would be nice to know how long. The secondaries could be lengthened as required. Not to badly priced.
#144 N/A-PWR
Posted 23 November 2016 - 11:58 AM
Here is the other Pacemaker Tuned half Maz:-
http://www.pacemaker..._category_id=27
pipe etc.
#145 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 23 November 2016 - 01:29 PM
Thems the ones Dave 😊
How much longer would those secondaries
need b Waz .could the end of the collector b
made to fit say 2.25.
i will b putting side pipe on old girl well
into nxt yr sometime.just seeing if these
would work better on a milder donk than say
the hms.hopefully engine will have 220hp
Cheers maz
Edited by madtoranajzedded, 23 November 2016 - 01:34 PM.
#146 _rich243_
_rich243_
Posted 23 November 2016 - 02:13 PM
I was a little disappointed with my hm9c's when they turned up and found they aren't mandrel bent... So yes they are 1/5/8 primaries but certainly arent that where they are bent on turns. Torque/power increase seat of pants test is a thumbs up though.
#147 S pack
Posted 23 November 2016 - 04:28 PM
#148 N/A-PWR
Posted 23 November 2016 - 04:30 PM
I remember that Dave, makes us wonder hey.
#149 warrenm
Posted 23 November 2016 - 11:16 PM
Thems the ones Dave
Cheers maz
It depends on what duration the cam is + a few other engine specs, but generally 15-20" long.
#150 N/A-PWR
Posted 23 November 2016 - 11:34 PM
If you consider the exhaust centres of the Red  Six,
 from port  #1 to #6 equals 23 inches,
they are decently at least 30 inch primaries.
