VK 202 motor free on gumtree, kelvin grove qld
Free is in the budget, if it's useable.
Haven't found it yet.
Posted 04 April 2016 - 06:48 PM
Posted 04 April 2016 - 06:59 PM
Not sure whether your budget would permit it, but what about weber-type throttle bodies and injection?
Modern with the old school look.
Maybe something like this: http://www.carbureti...ylinjection.asp
Or if you use the 12 port head, what about the injection that comes on the VKs
Glenn
Posted 04 April 2016 - 07:14 PM
The VK manifold is very good for what its designed for, a stock 202 that turns to 4500rpm. After that it very quickly reaches its limitations.
Posted 04 April 2016 - 07:53 PM
Posted 04 April 2016 - 08:40 PM
Umm, silly question....
Have you had a read of Old Johnno's "How to build the hot Holden six"??
You should.
Can't be bothered with the link, just google the above if you haven't.
Posted 04 April 2016 - 08:49 PM
If I was building this I'd use a good 9 port head, 245@0.050" cam on 108 centres and an SU manifold with TM40-6 carbs. I'd also try to use lightweight pistons and rods. Simple and affordable with a good spread of power.
Posted 04 April 2016 - 09:05 PM
Posted 04 April 2016 - 09:11 PM
Contact someone reputable. I get Kevin Brown to do my stuff for me.
Posted 04 April 2016 - 09:13 PM
Posted 04 April 2016 - 09:15 PM
Sweet.
Posted 04 April 2016 - 10:05 PM
Posted 04 April 2016 - 11:35 PM
Hey bomber its not a max power manifold but with just port matching and a 500 holley my fj pulled a 13.89 1/4 .don't knock it until you've tried it.
I think he was referring to the VK efi manifold, not the carb manifold.
Posted 05 April 2016 - 12:09 AM
For curiosity Mick, what is the wet weight of your FJ without driver?
Posted 05 April 2016 - 08:27 AM
Posted 05 April 2016 - 08:39 AM
OopsI think he was referring to the VK efi manifold, not the carb manifold.
Edited by STRAIGHTLINEMICK, 05 April 2016 - 08:40 AM.
Posted 05 April 2016 - 08:45 AM
Posted 05 April 2016 - 10:47 AM
From memory it was 2420lb without me in it.what does yr torana weigh.
Posted 05 April 2016 - 10:31 PM
2522lb without me in it. Heavy diff, heavy tail shaft, heavy wheels, heavy battery and a lined boot all contribute.
Posted 05 April 2016 - 11:34 PM
Yes, sorry.
Your uc goes alright with one though doesn't it warren?
Yes it used to, 130 at the treads with a very mild cam, I sold the car with the stock 173 back in it.
Posted 06 April 2016 - 12:03 AM
What is the diff.
9 inch...
Posted 06 April 2016 - 09:14 AM
