stick shift 202
34 replies to this topic
#26 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 11 June 2016 - 07:38 AM
Looked like a flat change to me...
#27 _ljxu1torana_
_ljxu1torana_
Posted 11 June 2016 - 12:23 PM
never seen a m22 muncie doing that before.
#28 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 11 June 2016 - 02:34 PM
And now you have.
You don't hear the revs change when you're on the limiter hey.
#29 _ljxu1torana_
_ljxu1torana_
Posted 11 June 2016 - 04:57 PM
should be changing about 500 rpm before the limiter.
#30 _Skapinad_
Posted 11 June 2016 - 05:17 PM
Was that 1/8th mile ?
#31 warrenm
Posted 13 June 2016 - 07:41 AM
Yes.
And now you have.
Limiter is set at 8000, the revs only flare up about 200rpm.
#32 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 13 June 2016 - 08:14 AM
Just curious Warren, where is your peak HP? 6800rpm?
#33 _LS2 Hatch_
_LS2 Hatch_
Posted 13 June 2016 - 08:29 AM
If limiter set at 8000, I'm guessing very close to 8000 for peak HP
Maybe 7700-7800?
#34 warrenm
Posted 14 June 2016 - 07:28 AM
6800 rpm. I think it's higher after some head work but haven't had it on the rollers to confirm it.
Maybe 7700-7800?
I set the limiter a 1000 rpm higher as it sounded like I was hitting the limiter at a race meet some years ago, so I bumped it up, wasn't the limiter though, just never changed it back.
#35 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 14 June 2016 - 05:24 PM
Cheers Warren... I figured 6800 would be close- havent seen many cast headed 202s with the peaks much higher than that- I guess the limitations of the head design come into play above about 7k. I know JZED/ Duggan heads are making the peaks quite high in the range though. Whats interesting is my setup makes the peak at 5800-6000 but holds it strong to 6800 then drops off sharp.
Cheers for the great discussion!
