LH Wiring Diagram
34 replies to this topic
#26 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
  • Car:SLR5000 LH Torana
Posted 26 June 2021 - 08:09 AM
The 6 & V8 wiring is the same except for the 2 extra spark plug wires. GMH didn't issue a separate diagram for the V8.
You are correct about the number referring to the wire gauge, although I don't believe that GMH did this for the LH diagram.
Dr Terry
You say they didn't issue seperate diagram for V8. My diagram says to refer to sheet 12zz-2 for 4 and 8 cylinder engine wiring, so maybe just an extra page showing only whats different. Do you have an idea what this 12zz-2 sheet is.
Howie
#27 hanra
  • 11,050 posts
Posted 26 June 2021 - 08:35 AM
What are you needing to know though? Everything you need is on that diagram and a U21 diagram is also available here as well.
#28 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 26 June 2021 - 08:58 AM
Good morning Hanra I have just realised that  the 12ZZ-2  reference for 4 and 8 cyl engine wiring is also the reference for U21 Instrument, so is there only one page (12zz-2) being the wiring diagram for the U21 upgrade for both 4 and 8 cylinder, or is that a typo error and U21 should be  a -1?
#29 hanra
  • 11,050 posts
Posted 26 June 2021 - 09:17 AM
U21
#30 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 02 July 2021 - 03:51 PM
Guys from my research it appears that 3mm seems to be the smallest auto wire gauge to buy in 10mtr lengths. The manual shows most wiring ranging from 12-18gauge, which only 2.052mm down to 1.024mm, so should I just use 3mm for wiring between 12 and 18Gauge?
Howie
#31 hanra
  • 11,050 posts
Posted 02 July 2021 - 04:00 PM
Strip some of your original wire back. Take same wire into Autobarn. Compare with the rolls of Narva wire. Buy that one.
#32 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 03 July 2021 - 07:46 AM
Thank
Thanks Hanra, I did that for some small repairs, but I have decided to replace entire looms so I thought I should make the effort to get the gauges and colours  correct, I can buy from the states, but as I mentioned in all of the large auto wiring mobs I have contacted in Australia has 3mm as a minimum.
#33 308 Sunbird
308 Sunbird
  • 975 posts
  • Name:Stuart
Posted 03 July 2021 - 04:03 PM
https://www.rapidcab...utomotive-cable
#34 308 Sunbird
308 Sunbird
  • 975 posts
  • Name:Stuart
Posted 03 July 2021 - 04:05 PM
https://www.rapidcab...ary-copper-wire
#35 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 16 June 2022 - 07:47 PM
Bigger resolution -
