Interpreting Holden documentation ?
210 replies to this topic
#126 Kockum
Kockum
  • 478 posts
Posted 17 January 2017 - 11:22 AM
Rockoz ,
Forum member flyagainxu1 had a strike me pink car that SUPPOSEDLY had factory installed v8 exhaust brackets down the back end of said car .
#127 xu2308
Posted 17 January 2017 - 11:24 AM
You guys that read these Drawings said they were Proper Engineering Drawings, yet they are Card Code Drawings where Add ons can be made, you did not know that, so EXC could be EXChange as well, it's Card Code not official Engineering Drawings that you say you dealt with :)
#128 xu2308
Posted 17 January 2017 - 11:27 AM
Rockoz ,
The brackets on Flyxu1 SMP XU1 were aftermarket brackets for a twin system, the XW7 road going car had the XU1 muffler.
#129 Rockoz
Posted 17 January 2017 - 11:36 AM
no no no no no.
If it was a part to be exchanged it would have been in a format I have described before
1234 EXC XW7
1235 XW7
That way there is no ambiguity.
 There is a standard that applies to drawings.
These days it is actually detailed as an AUstralian Standard.
Back then they would have used the same annotations for all drawings so there would be no dramas interpreting anything.
It has been explained to you by different people from different backgrounds who all have the same conclusion
There are also standard words I could use for you in this instance.
But I dont want to join Skap.
#130 xu2308
Posted 17 January 2017 - 11:41 AM
There are words I could use as well, remember what Neil said the GMH guy about Engineers :)
#131 Kockum
Kockum
  • 478 posts
Posted 17 January 2017 - 11:44 AM
Xu 2308 , yep aftermarket for sure .
#132 hanra
Posted 17 January 2017 - 11:48 AM
Im so totally lost with this thread, and I almost need someone to explain to me very basically what on earth is going on.
But from all my readings of my GMH Parts Manuals, predominately LH, it frequently uses the term "exc" in reference to excluding the L34 from certain P/N's. On the next line underneath, dedicated L34 P/N's are then allocated to the previously excluded part. I see the same used in the LJ parts manual for XU1.
Am I missing something here?
#133 Rockoz
Posted 17 January 2017 - 11:58 AM
No Hanra you actually have it nailed.
#134 xu2308
Posted 17 January 2017 - 12:00 PM
Parts manuals drawings to Card Code Drawings are a different beast Hanra.
#135 _ChaosWeaver_
_ChaosWeaver_
Posted 17 January 2017 - 12:02 PM
Al, it was you that said you had the Full Set of XW7 Engineer Drawings.  Remember, they were given to you by an Ex Engineer that worked on the program, and gave you ALL the engineering drawings ?? ......
All you have showed us is 2  portions of drawings.  One drawn in 1968, the other drawn 1970 ...   That's a fair way short of Jun. 1972 .
I also showed you an amended and revised GM-H Technical drawing, that shows just how GM-H identify a revision to their drawings ..
#136 xu2308
Posted 17 January 2017 - 12:04 PM
Chaos the XW7 Add on is 1972, XW7 happened in 1972 :)
#137 _oz772_
_oz772_
Posted 17 January 2017 - 12:13 PM
I stand by my opinion though. The numbers prove your GTR was at experimental engineering but the numbers do not prove any more than that.
A question for you both Dave and Al. Does HHS have records of any other LJ GTR's (I guess 4/72 Adelaide build)) at experimental at this time? Personally, I couldn't care about rat traps and subframes, and any other things that could be changed over the years. If the ADR tag was fixed to that body, and the car is from the Adelaide plant, then the numbers on the back of the ADR tag tell the story.
#138 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Car:LX SS HATCH - IMORAL
Posted 17 January 2017 - 12:40 PM
Oh ffs
It means excluding/excludes. End of frOcking story
It will never ever mean exchange. Please get this through your head and move on
#139 _RS250_
_RS250_
Posted 17 January 2017 - 01:45 PM
Al,
Here is the LJ Parts Manual list for the Inlet valves......in YOUR terms "Exchange" has no meaning, however as "Exclude" it makes for 100% understanding.
Please drop it, your wrong on the "EXC" meaning, regardless how stupid you want to portray your Holden Engineer's right to write how he feels.
Its only ever been "Exclude" ever since I can remember at the Holden dealer as a young whipper snapper hanging over the counter reading his parts book.
Attached File  GMH parts.jpg   181.93K   0 downloads
#140 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 17 January 2017 - 02:02 PM
#141 Rockoz
Posted 17 January 2017 - 03:16 PM
Al
With all due respects to you, your refusal to accept that you are wrong when you have been shown evidence, had it explained to you multiple times, means that any information you have provided would have to be put to increased scrutiny.
You arent doing your cause any favours by not accepting the truth.
You have provided lots of information that has debatable reliability.
It has been said before that no one was out to say you were wrong about your car.
All that was asked was clarified and reliable information that could stand the test.
You have failed that with the drawings.
Wishing it to be will never make it be.
You may well have a unique piece of Australian Motoring history as you claim.
But you have made it difficult for me to believe anything you claim.
I hope you do have what you think you have.
But you just havent provided the proof.
And realistically you have had less scrutiny than a lot of people claiming to have XU-1s.
Do some more homework and research.
It is up to you to prove beyond a doubt what you have.
#142 S pack
Posted 17 January 2017 - 06:12 PM
You were the one that called them engineering drawings back in your deleted V8 Prorotype thread.
#143 S pack
Posted 17 January 2017 - 06:37 PM
I seen Card Code under the Drawing, Chaos there you go no wonder the Pencilling In Hapened :) It's still a Revision by a GMH Engineer, part number for that XW7 Clutch Pedal is there for a reason :)
Yep it's for the export LJ with the Opel 4cyl and MC6 Transmission. :)
#144 _ChaosWeaver_
_ChaosWeaver_
Posted 17 January 2017 - 06:59 PM
Looks like someone was planting seeds sometime ago ... Sounds kind'a familiar  :blink2:     Link : http://www.fastlane....ify-torana.aspx
Posted : 8 years ago
Rank: Guest
Groups: Guests
Was thanked: 1 time(s) in 1 post(s)
hello can anyone help me identify this torana it is from a deceased estate from my uncle who worked at holdens as a enginneer
it is a LJ 2 door factory V8 it has numbers 82911JH991922 XW7 on a plate near the radiator. is it a xu1?
#145 RallyRed
Posted 17 January 2017 - 07:05 PM
there used to be a thread about the V8 Xu1 prototype as I recall.....but I think it was scrubbed...so at the risk of a stoning...
Youse can only use small stones anyway...çause essentially, this thread is about the same thing anyway.
This just popped up on F/B ( credit to Lynden C Maxfield‎Old Car Yard Photographs - Australia)
Holden Torana ad Leven Motors, Ulverstone 74
#146 S pack
Posted 17 January 2017 - 10:34 PM
They are 'Instruction Drawings' not Card Code Drawings.
The cards those codes reference are another animal again.
Edited by S pack, 17 January 2017 - 10:36 PM.
#147 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
There was a smp on the east coast (tas)
While back for sale.roughly in early 2000s
im not sure if had motor in it.
Gee there couldnt of been that many smp in Tas
#148 S pack
Posted 17 January 2017 - 10:43 PM
Didn't Al and Jess own an SMP XU1 before the SMP GTR?
#149 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 17 January 2017 - 10:51 PM
Dunno Dave..my friend mentioned the pink lj
but there was something wrong what didnt add
up so we lost interest.too much partying
has robbed my memory lol..
#150 xu2308
Posted 17 January 2017 - 11:17 PM
Rank: Guest
Groups: Guests
That is a Brisbane Built LJ GTR, nothing to do with me. Maybe XGTR on the Forum might be your man here as his GTR is Brisbane Built.
My GTR is Adelaide Built :)
