GTR and XU1 verification thread
model identification verification vinplate Body identification
1964 replies to this topic
#251 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 19 July 2010 - 02:31 PM
Hi Pugsley
Welcome to the forum.
The numbers that you have given accord with each other datewise so it is more than likely that the tags all came from the GTR that you have described. Only an inspection of the vehicle by a person familair with the identifiers of a GTR can categorically say whether the car is genuine. It goes without saying that a GTR or XU-1 can be 'manufactured' by attaching genuine tags to a base model. Someone from a nearby Torana club may be able to assist.
Bazza
Edited by Bazza, 19 July 2010 - 02:32 PM.
#252 _gtfella_
_gtfella_
Posted 24 July 2010 - 11:27 AM
hello to all any help with these numbers would be appreciated .model no lj 82911 ,bod no 1157 -A,trim 1822-40X,c plate 10-72,ALJ 14754A, third tag hard to read it was dark 8011lcl21943 6J thanks guys
#253 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 24 July 2010 - 12:03 PM
Hi gtfella
The VIN would be 8D11LCL219436. It comes up as an LJ GTR completed in Adelaide on 27/10/72 and sold by dealer 286 (GMH Internal) during 10/72. The original engine number was JL23597. The colour is The Lone O'ranger with black vinyl interior.
All numbers are consistent datewise.
Bazza
#254 _LoneOranger_
_LoneOranger_
Posted 01 August 2010 - 07:25 PM
Hi Every one.
Can someone please tell me what these numvers belong to.
What should rhis car be.
82911CH178376
Thanks John
#255 bullitA9X
bullitA9X
  • 4,168 posts
Posted 01 August 2010 - 08:29 PM
Hi Every one.
82911CH178376
Thanks John
lc gtr built 23/11/70 sold 1/71 by dealer 624 no engine number listed
#256 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 01 August 2010 - 08:32 PM
Hi John
That VIN relates to a GTR completed Brisbane 23/11/70 and sold by Boyded P/L of Rockdale NSW during Jan '71. There is no engine number recorded.
Do you have any other tag details?
Bazza
#257 _LoneOranger_
_LoneOranger_
Posted 01 August 2010 - 10:03 PM
Thanks Bullit & Bazza,
Is there a way of knowing the colour, even without a colour tag
John
#258 _Roddo_
_Roddo_
Posted 14 August 2010 - 09:05 PM
vin no 82369ch214634 model no lc 82369a body no 28525b trim no 181840f paint no 56813131 7/71 lc any help would be great thanks
#259 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 14 August 2010 - 09:47 PM
Hi Roddo
Welcome to the GMH-Torana forum.
The VIN relates to a 4 door S model completed in Brisbane on 1/11/71. It was sold by J N Caldwell P/L of Crows Nest NSW during Nov '71. The car was fitted with a 2850 cc (173 cid) but the engine number is not listed. It left the factory with a Trimatic auto, disc brake front end and a 2.78:1 ratio diff. It was Brooklands Blue with black interior.
Do you have the Chassis Number?
Bazza
#260 _hoping_
_hoping_
Posted 14 September 2010 - 06:37 PM
I have brought a LJ 10/73 2 door sedan BLJ 54197B
On this plate it also has 1,2,3,4,5A,6,7,8,10B,11,12,14,15,16,18,20,21,22,23,24,25,26
On the back of this tag, It has 444 written in black
This is the only tag that come with the car, On L/H/S inner guard it has BLJ 54197B
Last registered in 1994
I'm trying to restore this car to it's original format, Car body is fully repaired & undercoated, waiting for the correct colour
Can anyone help with more information or records relating to this car, EG) Correct colours & interrior
How I could possible renew tags eta ???????
Regards Hoping
#261 yel327
Posted 14 September 2010 - 08:15 PM
You'll be able to find the PSN in the records and then reconstruct the VIN. Plus work out the ENG, TRANS, RRAXLE codes and the BODY number for the BODY plate. But the paint and trim lines cannot be worked out except by what evidence is on the car. The PSN will give you what the car was originally too, ie S, GTR, XU-1 etc. I wouldn't bother renewing tags, you have the important one. Just knowing what the others said will be good enough, although it will always be de-valued because of the missing tags.
#262 yel327
Posted 14 September 2010 - 08:34 PM
I just looked it up. At first glance I'd say it was H296444 (so VIN should be from memory 8D11LDH296444 (someone please correct if wrong!)). This was a GTR completed on 18/10/73, and sold in 11/73 by dealer 054. BETSBAC code is 76203C0, which is GTR,202,M20,manual steer,discs,3.08,no A/C. If I were you i'd check all other Brisbane PSN's from 9/73 area to 11/73 area that end in 444 that are coupes just to be sure, but this could be your car! Damn. I just found H297444 which is the same build configuration completed on 26/10/73 so that could be it too. This was sold by dealer 630 in 4/74. Those appear to be the only possibilities. See if you can find out any info like when it was first registered and where, or old rego papers with dates close to those selling dates. Also, if you can find an original engine number. One of those two above has an engine number recorded, the other doesn't. Good luck!
Edited by yel327, 14 September 2010 - 08:46 PM.
#263 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 14 September 2010 - 09:49 PM
Hi
Working forwards and backwards from 2 known data points - my bet is on H296444
Bazza
#264 _Nitter_
_Nitter_
Posted 15 September 2010 - 07:49 AM
Wouldn't those numbers on the back of the ADR tag make up part of the body number on the trim tag...not the vin?
#265 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 15 September 2010 - 08:41 AM
Hi Nitter
Good question. Normally in the case of Brisbane built cars that would be true, but from mid-May '73 Brisbane cars got their Body Number from the 6 numerical characters of the PSN (the last part of the VIN). Prior to that, Brisbane Body Numbers were from an unrelated sequence and had 5 characters.
Bazza
#266 _Xu1er_
_Xu1er_
Posted 24 September 2010 - 08:44 AM
Hi folks,
Found Some photos in storage. I will post more soon.
Here are details of my families Xu1's. The first being my brothers (73), and the other my uncles. Unfortunately both were sold some years ago. I am pretty sure my brothers (73) was stolen shortly after he sold it? It was a rare beige colour.
If anybody knows anything more about these vehicles or there whereabouts, I would be interested to know.
I have various photos of the cars which I will post if requested.
Car 1 28/8/73 Brisbane page 124 on VIN Disc
Eng JP388675
CH BLJ51174B
VIN 8d11JH290109
BATSEC 77403EQ
Sold by Dealer 029 on 10/73
Car 2 24/11/72 Brisbane Page 187 of VIN Disc
Eng JP254932
CHALJ16434B
VIN 82911JH259284
BETSAC 77403EQ
Sold by dealer 029 on 12/72
Xu1er AKA john.
Attached File  SCAN0017.jpg   191.85K   13 downloadsAttached File  SCAN0018.jpg   97.4K   5 downloads
#267 _Skapinad_
Posted 24 September 2010 - 09:02 AM
great pics, love to see more... interesting the 73 does not have the headlight surrounds blacked out..... learn something new everyday !
#268 _Xu1er_
_Xu1er_
Posted 24 September 2010 - 09:17 AM
Mate the red one had been repainted. the beige one was totally original. The headlight sourounds were blacked out, however were faded and the flash on the camera did not help.
John
#269 _gtr-xu1_
_gtr-xu1_
Posted 24 September 2010 - 10:05 AM
i think the red one was baroda silver from new??????
#270 _Xu1er_
_Xu1er_
Posted 24 September 2010 - 12:15 PM
Your right mate... I will post a picture before it was restored.
#271 _Xu1er_
_Xu1er_
Posted 24 September 2010 - 12:28 PM
Further photos.
#272 _gtr-xu1_
_gtr-xu1_
Posted 24 September 2010 - 01:58 PM
well the good news is the red car still exists, i dont know where but as i had its numbers on record, its out there somewhere
#273 _Mike73_
_Mike73_
Posted 25 September 2010 - 04:54 PM
hi baz , i have a blue plastic gear at the end of cable at g/box end , there are numbers on it .....- 7430970 holden 112 , do these numbers mean anything. cheers dave
and yes a outer and a inner and a blue plastic gear at end. cheers
Hi Daf67,
the locating tab at the extension housing must be in the slot, if on top your gears get chewed up, check that the cable is still turning at your speedo end. the metal clip holding the drive gear in the extension housing can also break.
Never heard of a 100mph speedo in a 6cyl model, but I agree it might be possible that a Brabham could have used them, these are the same otherwise as far as I know, the dates of the gauges might be a hint.
If it is a Brabham one, you need to move the switch on the back of the tacho to 6cyl for it to reade correctly.
The blue gear is for 3.08 diff, the white one is for 2.78 and I think the 3.36 is yellow one or something?
All these are for standard size wheels only.
Mike
#274 _mikecatts_
_mikecatts_
Posted 28 September 2010 - 06:36 PM
Hi all..
Im looking at buying this LC GTR XU-1.
Built 19/8/1970 Adelaide build..lc16##2a...scribe number 8##4(on back oc compliance plate)..
Has the 3100x 2###7 engine with #28###43 G90 head.
It has girlock front brake callipers,,disc size around 230-240mm(hard to measure, see pic), looks like a heavy front end..as pic..with sway bar
.Its Rally red.
NUMBERS HIDDEN FOR OBVIOUSE REASONS GUYS.
It has the compliance plate which matchers the chassis, has tank, tripples (not on), large master cylinder.. fuel cap
Doesnt have steering wheel and rims not sure about extractors and has aussie 4 speed as to opal...
needs work...
Question..It is missing the "vin" plate and the "body id plate". The seller says that is how he got it in 1998?
Can I get new plates made as I have the rego papers with the matching engine/chassis numbers?
#275 _Skapinad_
Posted 28 September 2010 - 06:59 PM
damn.... not a CK !
Also tagged with one or more of these keywords: model identification, verification, vinplate, Body identification
