GTR and XU1 verification thread
model identification verification vinplate Body identification
1964 replies to this topic
#1826 S pack
Posted 14 September 2021 - 09:05 PM
Hey guys.
Not sure if this is the correct way to find out some info on a LJ 2 Door.
Body ID tag has:
MODEL - LJ82911
BODY No - 295494B
TRIM - 1870 50X
PAINT 567- 15337
TOP (blank)
Compliance plate has:
BLJ5588B
11/73
Body number matches the compliance tag number.
I`m trying to determine if a GTR.
Any info would be appreciated
The VIN tag and the Body ID Plate belong with each other and came from a Brisbane built GTR completed on the 12/10/1973.
You are missing one digit from the Chassis number however I don't believe it will make any difference to the result that the GTR VIN tag and Body ID Plate do not belong with that 11/73
chassis number.
Edited by S pack, 14 September 2021 - 09:06 PM.
#1827 S pack
Posted 14 September 2021 - 09:39 PM
Correction.
You didn't mention a VIN tag. The Body ID Tag is from a 10/73 GTR.
You said the number on the Compliance plate matches the chassis number stamped into the body sheet metal so the 11/73 compliance plate belongs with the body shell.
#1828 _Occy_
_Occy_
Posted 15 September 2021 - 07:19 AM
Hi Mate,
Thanks for the quick response and to your question I did miss a number on the chassis.
It`s BLJ55888B (missing an 8)
Correct the VIN tag is missing.
So is this a Brisbane built GTR?
#1829 S pack
Posted 15 September 2021 - 07:32 AM
The Body tag is from a GTR but it does not belong with that chassis number or that body shell. There is a high probability BLJ55888B is a Torana S that has been done up to look like a GTR and fitted with a GTR body identification tag.
Edited by S pack, 15 September 2021 - 07:33 AM.
#1830 _Occy_
_Occy_
Posted 15 September 2021 - 08:15 AM
Isn`t that good news!
Could the last letter in the chassis number be "P" my bad eyesight?
How do I identify it`s real identity if possible
#1831 S pack
Posted 15 September 2021 - 08:22 AM
Definitely a B.
#1832 S pack
Posted 15 September 2021 - 08:32 AM
If you can carefully remove the Compliance plate from the upper dash panel there should be four or 5 numbers written on the back in texta. Be careful not to touch and accidentally wipe it off.
This number is the last portion of the body number (not to be confused with the chassis number stamped into the left hand wheelhouse panel).
The PSN for your LJ should be able to be tracked down from this texta body number if it is legible.
Edited by S pack, 15 September 2021 - 08:32 AM.
#1833 _Occy_
_Occy_
Posted 15 September 2021 - 09:07 AM
I just ripped the tag off and there is no number written on the back!
The chassis number is definitely a B.
What to do from here!
#1834 S pack
Posted 15 September 2021 - 09:55 AM
Bugger. In that case you may as well just consider it a Torana S until proven otherwise.
#1835 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 15 September 2021 - 11:04 AM
The gurus know the stuff to look for under the bonnet and boot
So yes it can be identified if you're willing to show your hand
no worries dotto , not for me , was asked a question by a mate of a mate
#1836 dattoman
Posted 15 September 2021 - 08:07 PM
I was asked the same this week
Sable ?
#1837 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 16 September 2021 - 10:36 AM
no worries neil
he never mention what car
#1838 _Camo_
_Camo_
Posted 27 September 2021 - 12:29 PM
Hi All,
I'm interested to find out some info / history regarding my LC GTR, any help would be greatly appreciated.
VIN # - Missing - is it possible to get a new VIN Plate made?
MODEL # LC82911M
BODY # 20683B
TRIM # 1808   40V
PAINT# 567 12190
5/71
LC54572B
#1839 S pack
Posted 27 September 2021 - 01:37 PM
Hi All,
MODEL # LC82911M
BODY # 20683B
TRIM # 1808   40V
PAINT# 567 12190
5/71
LC54572B
Your chassis number should be LC 34572B for a 5/71 Brisbane car.
Paint is Silver Mist Metallic with black vinyl interior.
It is possible to get reproduction tags made but the legality of them is entirely another matter. Best not to venture down that path as repro tags just cast a huge shadow over the authenticity of a car.
Edited by S pack, 27 September 2021 - 01:42 PM.
#1840 _Camo_
_Camo_
Posted 27 September 2021 - 01:49 PM
Cheers, Yes Chassis # was a typo.
Regarding not having the VIN Tag, is that a problem if I was ever to decide to sell the car?
#1841 S pack
Posted 27 September 2021 - 02:03 PM
If you have the original logbook or some other documentation that proves definitively the identity of the car then the missing VIN tag may not be that much of an issue.
That said the value is likely to be affected because of the missing tag but that's just the way it is.
Do you know the VIN number for your car?
#1842 _Camo_
_Camo_
Posted 27 September 2021 - 03:44 PM
Thanks for the info, Unfortunately I don't know the VIN number and I don't have any documentation for the car.
#1843 Baz LJ
Baz LJ
  • 44 posts
  • Name:baz
Posted 04 October 2021 - 11:40 PM
is there a register or way to determine my original paint colour? my body id tag is missing, had bonnet pin straight thru that spot, got the other 2 tags still.
barry verified my other 2 tags (jp, psn, vin, chassis number, dealer, dates etc) through the vin disc a long time ago,
but is there any other or new improved info on how i can find some written evidence of the original paint and trim details?
any help appreciated
05/72 adelaide lj
#1844 JohnoG
JohnoG
  • 3 posts
  • Name:John G
Posted 12 October 2021 - 07:04 PM
Hi All,
Looking for some info on my LJ.
It's meant to be an XU-1.
It's original colour was Purr Pull and built in Brisbane.
Unfortunately the engine is not the original.  Last I heard the engine was in an EH but I don't have the number :(.
Also at the passenger side rear of the car is a threaded nut inside the subframe, does anybody know what that may be for?  Dual exhaust maybe??
4/73  BLJ33178B which matches the stamped number in the engine bay.
VIN # 8D11PCH272414J
MODEL:  LJ82911
BODY:  21658B
TRIM:  1856 50X
PAINT:  568 15347
ENG:  XU1
RR AXLE: G95
#1845 meanmachine72
meanmachine72
  • 2,050 posts
  • Name:Jono
Posted 12 October 2021 - 08:57 PM
built 2/4/73 JP 314619 sold dealer 543
#1846 JohnoG
JohnoG
  • 3 posts
  • Name:John G
Posted 13 October 2021 - 11:39 AM
Thanks Jono.  I'm hoping that's about my car. Cheers
#1847 S pack
Posted 13 October 2021 - 12:22 PM
Yes Jonno is talking about your XU1.
#1848 _dean_kidd@iinet.net.au_
Posted 16 October 2021 - 04:22 PM
Hello all,
I am looking to spend some of my hard earned on a LC GTR that has come up. Doing my researched all looked good using the sheet that you kindly have on the site. My problem is I think the plates and VIN don’t match the chassis number because of dates. I hope I’m wrong but would like some expert advise. Numbers are as per below.
Model- lc82911
Body-21863b
Trim-1192 40x
Paint-56811401
Vin- 82911ch620089
As per the sheet on this web site - the car was produced in 01/70
Plate/chassis number
Plated 08/71
Alc 39145b
These numbers match the pressed number in the engine bay
Could this be that the plates are off another car? Or have I made a mistake with my research?
Would love some feedback before spending a lot of money on a re birth.
Dean.
#1849 S pack
Posted 16 October 2021 - 04:57 PM
Dean, you are right to be suspicious.
The VIN Tag and the Body ID Plate are off a Pagewood (Sydney) assembled GTR completed on the 16/01/1970.
The Compliance Plate and the chassis number are from an 8/71 Acacia Ridge built Torana which may or may not be an 82911 model.
Pagewood ceased assembly of LC Torana (using Acacia Ridge built bodies) in late July 1970.
If you are looking for a matching numbers GTR then walk away from this one.
Edited by S pack, 16 October 2021 - 04:58 PM.
#1850 _dean_kidd@iinet.net.au_
Posted 16 October 2021 - 05:02 PM
Thankyou for this mate. I found it hard to believe that the car that these plates are off was sold in feb 70 and the cassis was build in 08/71. Bit hard to do that! I am so disappointed but was hoping that there was a mistake somewhere.
Dean
Also tagged with one or more of these keywords: model identification, verification, vinplate, Body identification
