Holden V8 Water Pumps
34 replies to this topic
#26 arrimar
arrimar
  • 3,134 posts
Posted 01 July 2017 - 04:54 PM
Note pressings in this single outlet water pump body to prevent the bearing coming forward. I think this is what the Sept 74 update was referring to.
#27 Shiney005
Posted 02 July 2017 - 11:10 PM
Yep. I had a look at mine and the the one with the blanked off second outlet doesn't have it and the one with only one outlet cast into it does have it. When was production of L34s finished? Was it before Sept '74?  Does this mean that all L34s were produced with the earlier pump?
#28 arrimar
arrimar
  • 3,134 posts
Posted 03 July 2017 - 09:49 AM
Thats how my two are as well.
The pumps may have been available prior the paperwork, who knows?
Manufacture stamp on inside of mine is D164 (if that's a date it could be '74 164th day, ie. june 13) which predates the build of my car.
What is stamped inside your NOS pump Laurie?
#29 Shiney005
Posted 03 July 2017 - 11:05 PM
The one fitted to my car at the moment (early type) is D22. 22nd Jan '74.
Attached File  308a (5)small.jpg   83.41K   2 downloads
My spare early type is D181 30th June '74
Attached File  308a (1)small.jpg   110.2K   2 downloads
It also has this mark which must be a clue to the manufacturer.
Attached File  308a (2)small.jpg   133.59K   3 downloads
The later NOS one with the bearing retainers is D332, but it is stamped (cast) on the back side . 28th Nov '74
Attached File  308a (3)small.jpg   198.51K   3 downloads
Attached File  308a (4)small.jpg   115.64K   6 downloads
Edited by Shiney005, 03 July 2017 - 11:11 PM.
#30 Shiney005
Posted 03 July 2017 - 11:14 PM
It is getting close to lining up with the CAMS documentation.
#31 arrimar
arrimar
  • 3,134 posts
Posted 04 July 2017 - 07:09 AM
The cast blind one I have is stamped D237, so appears that style continued being produced after introduction of the other style. Or maybe D is day not 4?
#32 Shiney005
Posted 04 July 2017 - 08:14 AM
But that is August 20. So that makes the timeline still correct if the new style wasn't introduced until October. Or am I missing something? It's still early here. :ZZZ:
#33 arrimar
arrimar
  • 3,134 posts
Posted 04 July 2017 - 10:45 AM
Between us there's 5 pumps.
Let's assume the stamps are dates.
1.Jan 22 blind (on your engine)
2.Jun 13 single (on my engine)
3.Jun 30 blind (your spare)
4.Aug 25 blind (my spare)
5.Nov 28 single (your spare)
#34 hanra
Posted 07 May 2021 - 02:08 PM
VK Water pump P/N
VK Water pump pulley P/N
VK Crank pulley P/N
#35 Shiney005
Posted 08 May 2021 - 09:17 AM
So VK's used both the short and long pumps?
I wonder if the crank pulley "Engine Performance Equipment exc Air Cond" was smaller in diameter than the others?
Edited by Shiney005, 08 May 2021 - 09:17 AM.
