Tim's LJ - The Build Diary
1033 replies to this topic
#926 RIM-010
Posted 22 June 2021 - 06:14 PM
I've also now found all of the Simmons barrels I need to fill the guards, and as a bonus I have a set of 5 V5 centres for the Premier, when I get around to building that!
#927 RIM-010
Posted 23 June 2021 - 05:32 PM
Attached File  received_168042555230475.jpeg   57.12K   6 downloadsAttached File  received_840077166913537.jpeg   54.48K   7 downloads
Cleaned up my gearbox crossmember and finished modifying it to suit the Celica box
#928 warrenm
Posted 24 June 2021 - 07:47 AM
You might find that the crossmember will flex or bend in the middle unless you've added some strength to the back side.
#929 RIM-010
Posted 24 June 2021 - 01:45 PM
Good call, I'm working on a fix for that.
#930 ant285
ant285
  • 143 posts
  • Name:ant
  • Car:lj
Posted 24 June 2021 - 03:03 PM
Nice mate. What are you having done to the diff? I’ve got the same diff going in my lj. I wanted to get a lsd centre but can’t seem to find one. Seeing what other options there are
#931 RIM-010
Posted 24 June 2021 - 05:25 PM
I'm going to run a TruTrac...
The diff just needs to have the centre assembled and fitted, axles in etc etc. I'm not keen to do it myself and frOck it up, so I'll give it to the professionals.
#932 RIM-010
Posted 24 June 2021 - 05:57 PM
Attached File  received_182882700446845.jpeg   56.24K   15 downloads
This should do to strengthen the crossmember...
#933 RIM-010
Posted 25 June 2021 - 12:22 PM
Attached File  received_4186554971391308.jpeg   47.81K   14 downloads
Voila!
Also had to give it a little tickle to clear the speedo cable.
Now just for a squirt of underbody black and in she goes.
#934 rodomo
Posted 25 June 2021 - 09:42 PM
Those sunnies aren't a welding mask dontcha know?  B)
#935 RIM-010
Posted 29 June 2021 - 08:05 PM
Attached File  received_230226125403453.jpeg   47.48K   11 downloads
Got the painters at work to give my diff a squirt of black... Shiniest thing on the car now!
#936 RIM-010
Posted 10 July 2021 - 07:11 PM
Clutch pedal and cable are in and hooked up, I've filled the way-too-big hole in the trans tunnel and got the shifter fitted and made a plate for the firewall to mount the accelerator cable properly.
Got the GTS mirrors mounted.
Next step is to get the crossmember back in and trial fit the diff so I can get a tailshaft measurement, then send the diff off to get built and a tailshaft made.
Things are happening!
#937 rodomo
Posted 10 July 2021 - 10:40 PM
Pic of GTS mirrors please?
#938 RIM-010
Posted 11 July 2021 - 02:12 PM
Attached File  received_350691103085151.jpeg   50.22K   6 downloads
Just a note, if you mount them where the original mirrors mount, you won't be able to open the quarter windows.
#939 rodomo
Posted 12 July 2021 - 12:23 AM
Thanks Tim
#940 gtrboyy
Posted 13 July 2021 - 11:18 PM
Did b/w into gtr many years ago vaguely remember shocks were pita to fit due to caliper clearance so they went on first then brakes...larger tailshaft meant handbrake adjuster studs grinded on it & re-routed handbrake cables.
Should be fun to be back in a torrie..still regret taking mine off the road & letting life get in the way.
#941 RIM-010
Posted 14 July 2021 - 08:35 PM
Cheers for the tips mate, it's definitely going to be tight in there for shock/brake clearance. I haven't played with the handbrake cables on the car yet, just measuring to get a tailshaft made tonight so that'll be the next project.
#942 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 844 posts
  • Name:JASO
Posted 14 July 2021 - 08:46 PM
WUHAN style, :)
#943 gtrboyy
Posted 17 July 2021 - 07:03 PM
Seen some cars that moved lower mounting stud for shock absorber to face rearward...looks sthe impler way to go.
Mine barely fit but when we realised diff joint made diff wider than specified & tailshaft issues on first drive I had a dummy spit sent car off to get mini-tubbed etc lol
#944 RIM-010
Posted 29 July 2021 - 03:32 PM
Tailshaft is sorted, bought a yoke from Dellow and I'll get a Falcon tailshaft cut down to length.
Handbrake cable is getting sorted, Flexible Drive Agencies are going to make me up a new one at the right length with the right ends. Just need to move the mounts on the car to suit.
Attached File  received_354977463009260.jpeg   76.87K   4 downloads
Now that the handbrake is sorted I can get the diff put together, get it back in, get the tailshaft in and then it's just brake lines and wheels...
There is now a mob in Adelaide building new billet Mawer centres, so I'll go with them.
Getting closer!
Oh I sorted out the speedo cable and clutch pedal/cable the other week too... Man it was a lost easier to play under the dash when I pulled this thing apart 15 years ago...
#945 gtrboyy
Posted 29 July 2021 - 08:29 PM
Ya just getting old dude & no longer youthful contortionist.
Snapped a few speedo cables back in the day if they had slightest kink to them
#946 claysummers
Posted 29 July 2021 - 08:41 PM
Auto Cables, Retro Spares at Eltham Vic would probably supply a handbrake cable to suit your application off the shelf Tim. Just a thought.
#947 RIM-010
Posted 29 July 2021 - 09:31 PM
Cheers for the tip Clay, nothing to suit Falcon brakes on a Torana though.
It'll be a pretty simple fix with a custom cable.
#948 claysummers
Posted 29 July 2021 - 10:48 PM
They only do one for wilwood by the looks
#949 RIM-010
Posted 02 August 2021 - 08:26 PM
Attached File  received_189987393166424.jpeg   54.07K   6 downloadsAttached File  received_352955033134547.jpeg   66.98K   6 downloads
No dramas with clearance on the brakes, the Falcon calipers are forward-mounted.
This, coupled with the fact that the Falcon rotor is heaps shallower than the Commodore setup, makes the Falcon BW78 a much more user-friendly diff if you want proper wheels on a Torana... And you get a better stud pattern as a bonus.
#950 RIM-010
Posted 10 August 2021 - 11:07 PM
Today I got the engine fired up for the first time, over 12 years after I bought it from Matt (tyre fryer)
Progress!
