Tim's LJ - The Build Diary
1033 replies to this topic
#1001 RIM-010
Posted 03 November 2021 - 11:41 AM
Cheers gents. Looking forward to making up for some lost time over summer!
#1002 I'm a Red Motor fiend
  • 774 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 18 November 2021 - 04:42 PM
Spotto you just before cruising in the Mitcham area mate, good stuff 👍
#1003 RIM-010
Posted 19 November 2021 - 06:05 AM
Cheers mate! I'm still coming to terms with the fact that I can just jump in it and drive whenever I want, for so long it was just a shed ornament. Most of that time it wasn't even in my shed!
#1004 red6
red6
  • 591 posts
  • Car:1971 Lc Torana S 2 Door
Posted 02 December 2021 - 05:31 AM
Hey Tim. Where did you source the Mawyer centres? What diameter are they? Were they very spendy?
Edited by red6, 02 December 2021 - 05:32 AM.
#1005 RIM-010
Posted 02 December 2021 - 09:25 AM
Gday mate, I got them through Showster wheels. They are the same diameter and bolt pattern as a 15" Simmons centre, so they'll bolt straight in to Simmons rims. I can get a measurement if you need more info than that haha
They were about $2200 for the set of 4 centres, or I believe they can do the whole assembly for about $4k a set, obviously dependent on sizing.
#1006 RIM-010
Posted 02 December 2021 - 09:39 AM
335mm diameter. I know of a company in Adelaide making them to suit 13" wheels if you're interested in staying small.
#1007 red6
red6
  • 591 posts
Posted 03 December 2021 - 01:39 AM
Thanks for that Tim - yeah if you could dig out the name of the mob in Adelaide that would be great. Cheers, Rob
#1008 RIM-010
Posted 03 December 2021 - 04:25 AM
https://vintageandcl...-wheel-centres/
They're just down the road from me, I gave them a Simmons rim to work off for the 15s. 13" centres are a great price, but the material cost of the 15" billet bumps them up above what Showster can do.
If I did it again I'd get the full wheel, assembled. I saved a little bit of money by using secondhand Simmons lips and barrels, but not enough to worry about in the scheme of things.
#1009 RIM-010
Posted 28 December 2021 - 09:00 AM
Finally got it running properly on the weekend... A good tank of 98 with a squirt of octane booster, and I had a play with the timing and the carb and now I have a car that idles and does't ping under load. Beautiful!
Painted the grille black and silver, and painted the rad support behind the grille black. Replaced the >20mm of shims in the upper control arms with corresponding 'blocks' I made out of an old truck uni.
The Mawers are still in pieces under the bench, I'm just enjoying driving it!
#1010 claysummers
Posted 28 December 2021 - 09:25 AM
We going to see it at All Holden Day Tim? Yeh yeh!!
#1011 RIM-010
Posted 28 December 2021 - 02:31 PM
Yeah, I can probably be there... I'll have a suss
#1012 claysummers
Posted 28 December 2021 - 06:12 PM
#1013 RIM-010
Posted 24 January 2022 - 07:57 PM
Attached File  received_645315066612156.jpeg   167.39K   11 downloads
Scored a drop tank the other day... Had to cut out the lip that the standard tank fits on, and in she goes!
One day I'll sort the exhaust out and get the tank centred.Attached File  received_630775381507266.jpeg   162.66K   14 downloads
But for now I'll just take all of my pics from the side
Edited by RIM-010, 24 January 2022 - 07:59 PM.
#1014 smeer
smeer
  • 1,526 posts
  • Car:1970 LC 4-door
Posted 25 January 2022 - 07:12 PM
Stance on those steelies is looking really good! 15s?
#1015 RIM-010
Posted 26 January 2022 - 06:59 AM
Cheers mate! Yeah they're 15x6.5 EL Falcon stockies, running 195/50 front and 205/55 rear tyres.
They're only on there until I get my Mawers built! But the new wheels will be running the same size tyres, albeit on 7" and 8" wide rims.
#1016 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 04 May 2022 - 11:49 PM
Hi Tim .Heath sent me your way as im basically doing the same brake package as you up front.can you remember what the part # was to the willwoods.im not quite sure if its the dustboot ones i need for registration purposes.did you make that bracket..
Ps: love those mawers
Edited by madtoranajzedded, 04 May 2022 - 11:51 PM.
#1017 RIM-010
Posted 06 May 2022 - 06:20 PM
Gday mate, I'm not sure what the PN# is but I'll see if I can find it.
I didn't make the bracket, I bought the whole kit from Rodtech here in Adelaide for about $1100... Can't recommend them highly enough.
I'm keen to get the Mawers together and on the car, got a fair but on with work at the moment but I'll get them sorted over winter
#1018 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 07 May 2022 - 12:41 AM
These are for my floater kit on rear Tim.they are dynapro lug mount with dust boots.there is a part # behind the bleed nipple at front.but you would have to take a wheel off to see it.lol. part #120-11481Attached File  20220507_003234.jpg   586.1K   10 downloadsAttached File  20220507_003301.jpg   615.45K   7 downloadsAttached File  20220507_003537.jpg   541.16K   8 downloads
Edited by madtoranajzedded, 07 May 2022 - 12:48 AM.
#1019 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 13 May 2022 - 06:07 PM
Was the wrong one.lol.the one above is to 0.81 rotor..
Got onto rodtech and they have me sorted..
#1020 RIM-010
Posted 26 September 2022 - 07:50 AM
Attached File  received_403108841994241.jpeg   80.38K   6 downloads
I accidentally bought another set of wheels... Ford stud 15x7 V5s, eventually they'll end up a heap wider and on my Premier, but for now I'll get them on the LJ
#1021 RIM-010
Posted 20 November 2022 - 06:52 PM
I forgot that Simmons' and Wilwoods don't play nicely... I'll investigate closer and see if I can get away with a couple of mm of spacer, otherwise they can wait until they have a home on the Prem.
I also got a bit of extra pocket money from the tax man, so I bought a set of triple 2" SUs from Bomber Watson... Can't wait to get them set up.
#1022 MRLXSS
Posted 22 November 2022 - 08:25 AM
Yeah bud! Sort of... haha
They'll look mint if you can get them sorted.
#1023 I'm a Red Motor fiend
  • 774 posts
  • Name:Adam
Posted 23 November 2022 - 05:18 AM
You will enjoy the 2" carbs. Are they HD or HS style? What sort of manifold?
#1024 RIM-010
Posted 24 November 2022 - 09:40 PM
Yeah I'll have a play with them, Matty, but I'm not going to take any meat out of the caliper or anything silly to make them fit
They're HD8s, on Armour manifolds... Bomber Watson is entrusting me as their new custodian.
#1025 Heath
Posted 25 November 2022 - 07:41 AM
Wilwood calipers are structurally how-ya-garn enough without subtracting any material from them!
It would be more a case of a hubcentric spacer or countersinking/counterboring the wheel bolts in some fashion to make them tighter. Cutting off excess thread on the bolts, that kind of thing.
