Tim's LJ - The Build Diary
1033 replies to this topic
#151 _JBird_
_JBird_
Posted 20 January 2007 - 12:55 PM
It is a really tight fit, as in, it just sorta crams in there.
#152 RIM-010
Posted 20 January 2007 - 09:42 PM
Thanks guys, I think I might just put the blanking plate in, and have the HU in the console.
postal_dood, I haven't got the wheels yet, theyre just what I want.
RIM
#153 RIM-010
Posted 26 January 2007 - 09:50 PM
I got some thinking and some Bodywork done today :)
Rear quarter before -
During -
and After -
Its not finished yet, obviously, but atleast we have the metal covered.
and now, to the thinking part. I measured up the front seats in my cousin's Toyota Soarer. They're 550 wide x 600 long on the base, and 930 from the bottom of the base to the top of the headrest. A standard LJ Seat is about 550x550 base, and about 880 tall. The Soarer seats are bloody narrow, but really supportive and comfy. Sam reckons they can be picked up for about $100/pair, and come in either Electric or Manual.
Unfortunately, Dad's not keen to install a set :cry:
And, the rest of the thinking went into the electrics. The tacho has been pissing me off, it jumps straight to full revs as soon as you start the car, and stays there wether you accelerate or not. It is all wired up properly, so the gauge itself must be screwed...
Next bit of thinking - Because I have 'Huge plates'o meat', My foot doesnt fit real well between the Clutch pedal and the trans tunnel, which is where the high beam switch lies. I am thinking of relocating the switch to the console, when I build it. Simple job, really, just need to sort out a suitable switch.
Cheers, Look forward to feedback.
RIM
#154 _Flamenco_
_Flamenco_
Posted 26 January 2007 - 10:06 PM
Good to see you're bringing it back to it's former glory :)
Not sure about the seats - if you take out the seats you'll see the floor doesn't sit level on both sides - I would think the soarer ones probably will. Won;t be a problem if you install the non electric ones because you can just use the LJ's runners. I'm sure you know the high beam switch is just 2 selftappers and could be moved anywhere by extending the wires.
#155 RIM-010
Posted 26 January 2007 - 10:09 PM
I wasn't planning on using the 'lectric ones. They weigh a bloody tonne! 7 motors in em...
Yes, I know that the high beam switch is only screwed in with 2 screws. I'd hardly even have to extend the wires!
RIM
#156 _Flamenco_
_Flamenco_
Posted 26 January 2007 - 10:13 PM
I must admit the VX SS ones I have in my hatch are heavy - they only use two motors for all the tilting and raising though...
#157 RIM-010
Posted 27 January 2007 - 09:36 AM
I love Photoshop :spoton:
Waddya Reckon?
RIM
#158 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 27 January 2007 - 05:41 PM
I like it. :spoton:
Mick.
#159 _Monkey_
_Monkey_
Posted 27 January 2007 - 05:43 PM
I see your starting to see the light RIM.
Convo's FTW.
#160 RIM-010
Posted 27 January 2007 - 08:27 PM
Today I had a bit of a play around in the boot...
Started with this -
and figured that the box on the left hand side would be a waste of space. I was gunna use that to keep the Jack, oil, wheel brace etc in. Instead, I used my geniusness and came up with this:
EITHER - Cut the spare wheel well out of a shell and weld it into the LHS boot floor, and use it as a toolbox.
OR - Fabricate a similar sized box out of sheetmetal and weld it into the LHS boot floor, creating a toolbox.
What do you guys reckon? Will there be any legal violations in doing this? I won't be cutting into the chassis or anythin, just cutting a hole probably 200x300 in the boot floor.
RIM
#161 RIM-010
Posted 06 February 2007 - 09:22 PM
Anyone?
RIM
#162 Peter UC
Peter UC
  • 771 posts
Posted 07 February 2007 - 11:52 AM
RIM are you sure you wired up your tacho correctly because it sounds like you have attached the coil wire up to the positive side of the coil rather than the negative.
#163 _73LJWhiteSL_
_73LJWhiteSL_
Posted 07 February 2007 - 12:59 PM
Rim, Are you planning on going gas? Cause that space you have 'whited' out at the front of the boot would be taken up with the gas tank.
Steve
#164 RIM-010
Posted 07 February 2007 - 03:10 PM
Peter UC, The Tacho is wired up to the coil properly. I though I might've got it the wrong way too, but it's definitely right.
Steve, Gas is for BBQ's, not Torana's...
Cheers guys.
RIM
#165 Heath
Posted 07 February 2007 - 04:01 PM
Gas is for cool people; I suggest you steer well clear from it mate.
#166 RIM-010
Posted 07 February 2007 - 06:12 PM
:finger:
Nah, If it was an LH/LX I'd run it on LPG... From what I've seen, Gas bottles don't fit too awesomely in LC/LJ Boots...
RIM
#167 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 07 February 2007 - 07:05 PM
The car's coming along nicely RIM but you certainly create some work for yourself.
I'd just keep the boot standard, keep the LJ on petrol, put the radio head unit in the console and keep the original seats (just get them retrimmed). Will save alot of money and effort.
Cheers Mick.
#168 RIM-010
Posted 07 February 2007 - 07:23 PM
Why would I want to get the seats retrimmed? They're in near perfect condition!
I know I create alot of work for my self, it's because I spend too much time thinking about the car and not enough time working on it (and there's SFA I can do about that ATM...)
I want to atleast weld a box into the boot for tools. Piss easy to do (famous last words), as far as I can see it, and will create a neater boot.
Oh, and we've decided that it won't be near ready for my P's :cry:
RIM
Edited by RIM-010, 07 February 2007 - 07:24 PM.
#169 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 07 February 2007 - 07:32 PM
Apologies, I thought your trim was pretty good. I should have said get the seats re-shaped (if you want them like racing seats).
Keep up the good work.
Mick.
#170 RIM-010
Posted 07 February 2007 - 07:37 PM
Nah, that'd be more effort and cost than bolting a set of Soarer seats in.
Maybe when I put a 1JZ/2JZ in it, I'll drop a set of Soarer seats in. Or is that getting too Toyota-ish?
RIM
#171 RIM-010
Posted 07 February 2007 - 08:32 PM
And, thanks to Loui, I know have a set of Headlight surrounds and a decent grille :spoton:
And he now has an original Radio and Speakers.
Cheers for that mate.
RIM
#172 _jake_
_jake_
Posted 07 February 2007 - 09:33 PM
u should concentrate on getting it all worthy to be registered first i reckon. then u can drive it on ur P's, and work on all the other stuff at the same time
#173 RIM-010
Posted 07 February 2007 - 10:39 PM
I'll be able to drive it on my P's... It just won't be ready in September, when I GET my P's...
It was registered before I started pulling it down. I couldve left it how it was, and drive it around like it was. But that's just dodgy. I don't want to rush it just so I can have it ready for my P's, and I just won't have the time between now and September to do it! I'll be home for a total of about 70 days between now and September.
RIM
#174 _73LJWhiteSL_
_73LJWhiteSL_
Posted 08 February 2007 - 11:34 AM
Tell me about it... But it sure eases the pain at the fuel pump I will tell you that. I love the fact it only cost me at most $35 to fill a tank, and thats good for around 500ks :tease: :tease: :tease:
Steve
#175 Loui
Loui
  • 495 posts
Posted 08 February 2007 - 08:08 PM
RIM
No probs mate
You will be wishing you had'nt swapped when ive got talkback radio pumping as im cruising the streets
Loui
