The Sally Report
1003 replies to this topic
#876 Ice
Posted 29 June 2022 - 09:29 PM
Hope ya gunna smooth over some of that cocky shit on the K frame its shocking
and don’t give us any of thats how it left the factory BS  :)
love ya work Marty
#877 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 30 June 2022 - 05:16 AM
love ya work Marty
I had that problem. I couldn't leave all the welding splatter and rough edges on mine. The joys of being pedantic.
#878 sibhs
Posted 04 July 2022 - 09:57 PM
It's been a challenge getting the bush out of the diff. From memory my suspension guy just banged them out with a hammer and drift.
I tried that with no luck and had plenty of issues using the bolt and spacers method.
Finally they're out.
Attached File  IMG_8843.jpeg   202.82K   8 downloads
Attached File  IMG_8844.jpeg   207.36K   8 downloads
Attached File  IMG_8850.jpeg   200.85K   8 downloads
Attached File  IMG_8851.jpeg   202.12K   10 downloads
Attached File  IMG_8852.jpeg   119.46K   8 downloads
Attached File  IMG_8853 (1).jpeg   126.79K   8 downloads
#879 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 05 July 2022 - 12:23 AM
Hi marty..love your work mate..
#880 IanC
IanC
  • 613 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 05 July 2022 - 06:54 AM
Thank you for providing pictures and information for the rest of us (Me) to follow Marty. Legend.
#881 sibhs
Posted 05 July 2022 - 06:29 PM
Found a crack in the frame and also had to repair a bent bump stop and twisted top washer.
Attached File  IMG_8889.jpeg   142.27K   16 downloads
Attached File  IMG_8890.jpeg   94.12K   16 downloads
Used the oxy to heat up then banged the bits back into shape. Bump stop looks like it must have been hitting the spring so someones clobbered it with a cold chisel to move it back. Once it was back in shape I measured clearance to compare to other side. It did need some massaging to get the distance correct.
Attached File  IMG_8891.jpeg   116.65K   16 downloads
I ground a 'v' section out of the crack then gave it a good weld and grind back.
Attached File  IMG_8892.jpeg   167.1K   17 downloads
Attached File  IMG_8893.jpeg   136.02K   13 downloads
Attached File  IMG_8894.jpeg   142.08K   13 downloads
Attached File  IMG_8895.jpeg   236.09K   15 downloads
Then finally another wash with 'rust blast'
Attached File  IMG_8899.jpeg   255.29K   12 downloads
#882 davea79
davea79
  • 332 posts
  • Name:David Angel
  • Car:Never Mind
Posted 06 July 2022 - 09:16 AM
Loving your work mate. Just shows how much is involved to do it well!!
#883 sibhs
Posted 09 July 2022 - 08:58 PM
Need to get some etch on these blasted parts. Difficult with the temps being so cold but thought I'g have a crack.
Put the heater on for a few hours and got the temp up to 20 degrees.  Then turn the gas off and start spraying.
Attached File  IMG_8905.jpeg   193.69K   13 downloads
Attached File  IMG_8963.jpeg   248.04K   10 downloads
Cleaned up some welds to keep Gene happy.
Attached File  IMG_8964.jpeg   157.33K   10 downloads
Attached File  IMG_8965.jpeg   140.42K   10 downloads
Attached File  IMG_8968.jpeg   212.65K   12 downloads
Left the K Frame till last and it had cooled down too much so some of the paint sagged like melting human flesh.
Attached File  IMG_8976.jpeg   69.97K   9 downloads
#884 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 10 July 2022 - 05:09 PM
Is melting human flesh something that you see very often Marty? It's not a hobby that you've talked about before.
#885 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 844 posts
  • Name:JASO
Posted 11 July 2022 - 06:55 AM
The Truth is Marty, you cleaned off the welds to keep Gene happy, but in doing so made the K-frame too smooth, now its paint just runs of like Freddy Krugers face. :)
Jaso.
#886 Ice
Posted 11 July 2022 - 02:07 PM
Jaso.
Not quite Jaso gunna take more than clean welds to keep me happy  :)
In the paint industry thats called Bomb it on
#887 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 14 July 2022 - 08:19 PM
It's pretty easy to get runs in winter. More time between coats Marty, & back off the fluid.
#888 sibhs
Posted 14 July 2022 - 10:59 PM
Hi Gary, problem is I'm using a gas fired heater so I have to turn it off when painting and I have to get the paint on quick before metal goes cold. I'm thinking of hiring a paint booth to get the final black on.
Hi James, no experience in that stuff. It's just what it looked like. :-)
Polished up the junction brake block.
Attached File  IMG_8790.jpeg   204.47K   11 downloads
Attached File  IMG_8791.jpeg   115.18K   14 downloads
Before the front and rear axles go in I want to fit the brake and fuel lines. I bought a coil of each then built a pipe straightener.
Attached File  IMG_8863.jpeg   120.7K   15 downloads
Attached File  IMG_8864.jpeg   132.3K   12 downloads
Attached File  IMG_8865.jpeg   235.19K   15 downloads
Attached File  IMG_8870.jpeg   219.29K   15 downloads
Testing the bender.
Attached File  IMG_8871.jpeg   104.62K   15 downloads
#889 sibhs
Posted 22 July 2022 - 07:44 PM
Got some chrome work done and a fairly successful result.
Most of it was die-cast so this stuff is always touch-and-go as if it'll work.
The only piece I'm not happy with is the grill badge, it has pox marks from impurity in the cast. Chromer had two goes at it before admitting defeat. If it begins to bother me I'll send it over east to the company that has perfected die-cast chroming.
Attached File  IMG_9092.jpeg   445.52K   16 downloads
Attached File  IMG_9091.jpeg   180.52K   12 downloads
I told the chromer to only focus on the lip edges of tail lights the rest will be hi-filled and painted. No need to waste his time and my money on something not seen.
Attached File  IMG_9088.jpeg   191.53K   14 downloads
Attached File  IMG_9101.jpeg   171.85K   13 downloads
Assembled the rear ashtrays.
Attached File  IMG_9102.jpeg   226.78K   12 downloads
Attached File  IMG_9103.jpeg   191.89K   11 downloads
Attached File  IMG_9104.jpeg   143.92K   13 downloads
Attached File  IMG_9105.jpeg   162.56K   17 downloads
#890 Heath
Posted 25 July 2022 - 09:13 AM
Sweet. Looks quite good in the photos Marty.
Interesting that they made the ashtrays considerably more basic on the LH-LX.
#891 claysummers
Posted 25 July 2022 - 04:35 PM
They look like an engineering marvel.
#892 dacastle
dacastle
  • 112 posts
  • Car:LC gtr
Posted 29 July 2022 - 05:39 PM
Did you pull apart the rear window latches when you got them chromed
Your posts have  been a fantastic help with my rebuild
#893 sibhs
Posted 30 July 2022 - 02:33 PM
Hi Dave, I pulled one apart before chroming to adjust the click bit that holds window in and out. Then put together. So the answer is No. They were chromed as one piece. Very happy with result.
#894 Indy Orange
Indy Orange
  • 2,987 posts
Posted 30 July 2022 - 03:32 PM
Was that KD Marty?
#895 sibhs
Posted 30 July 2022 - 03:51 PM
Was that KD Marty?
Hi Paul, Yes, New owner, young guy who's been very helpful with me. Explaining and demonstrating some of the process. Getting a better understanding on why it costs so much to get chrome done.
#896 Indy Orange
Indy Orange
  • 2,987 posts
Posted 30 July 2022 - 05:32 PM
Nice job by the looks.
#897 sibhs
Posted 30 July 2022 - 07:53 PM
POPULAR
Getting the K-Frame bits ready for black paint. I knew these looked a bit out of shape so checked the measurements and used my new tool (thanks Ian) to expand them back into shape.
Attached File  IMG_9109.jpeg   85.67K   21 downloads
Wound them out to 215mm and they sprung back to the 204mm
Attached File  IMG_9111.jpeg   136.23K   16 downloads
Attached File  IMG_9112.jpeg   112.51K   16 downloads
Checking the bush will fill the gap.
Attached File  IMG_9114.jpeg   112.94K   15 downloads
This is one at correct measurement and the other not.
Attached File  IMG_9115.jpeg   147.83K   16 downloads
#898 RIM-010
Posted 15 August 2022 - 10:56 PM
Incredible, as always, Marty.
As Heath said, purple with a light trim is delicious!
#899 Maximart2
Maximart2
  • 19 posts
  • Car:LC GTR
Posted 19 October 2022 - 01:00 PM
Hi Marty, been following your posts and it's a big thumbs up from me. Any progress lately or are you having some well-deserved you and the missus time?
#900 sibhs
Posted 19 October 2022 - 07:37 PM
Hi Martin, I've been focusing on the Bathurst trip the last few months. Just got back a few days ago so hopefully get back into it soon.
