The Sally Report
1003 replies to this topic
#951 sibhs
Posted 18 June 2023 - 09:24 PM
I'm getting all my GTR Badges re-chromed so I stripped the paint first.
Attached File  IMG_2417.jpeg   115.51K   6 downloads
Attached File  IMG_2429.jpeg   205.14K   5 downloads
When I removed the badges from the door trim I drilled off the holding rivet which was a mistake. If you're ever stripping them  it's better to make the card hole bigger and pull badges through leaving rivets intact.
To fix this I had to drill out stem and fit a screw. Once I was happy it was at the right depth I glued it and ground the screw flat. Once fitted a cir-clip will used to hold them in position.
Attached File  IMG_2453.jpeg   149.21K   5 downloads
Attached File  IMG_2463.jpeg   60.91K   5 downloads
I took measurements off the original trims and taped out their position before drilling holes in card. Don't make a big hole in vinyl because there's not much room between edge of badge and hole.
Attached File  IMG_2454.jpeg   193.27K   5 downloads
Here are some measurements for those that might need.
Attached File  IMG_2455.jpeg   260.87K   5 downloads
Attached File  IMG_2456.jpeg   210.52K   4 downloads
Attached File  IMG_2457.jpeg   199.65K   5 downloads
Attached File  IMG_2458.jpeg   97.31K   6 downloads
Attached File  IMG_2460.jpeg   211.82K   5 downloads
Attached File  IMG_2462.jpeg   213.57K   5 downloads
#952 sibhs
Posted 18 June 2023 - 09:50 PM
There's been a bit happening on the car recently.
Fitted the fuel tank after painting it 3 times.
Attached File  IMG_2384.jpeg   105.55K   7 downloads
Attached File  IMG_2408.jpeg   130.09K   4 downloads
Test fitted the chrome rocker cover.
Attached File  IMG_2379.jpeg   186.19K   4 downloads
Cleaned up one of my coils.
Attached File  IMG_2386.jpeg   186.06K   5 downloads
I finally got more creases out of the hood lining, still a few to work on around centre pillar and got a guy out to fit the screens. New glass at the front and a good genuine rear. I asked for the joiner in the mylar to be put at the top on this build, I heard that was factory position to reduce water holding.
Attached File  IMG_2528.jpeg   198.97K   6 downloads
Attached File  IMG_2529.jpeg   138.23K   6 downloads
Attached File  IMG_2532.jpeg   133.05K   5 downloads
Things are finally starting to speed up on this build.
#953 Heath
Posted 19 June 2023 - 12:40 PM
It is all looking fantastic, Marty!
#954 claysummers
Posted 19 June 2023 - 06:54 PM
Good stuff Marty. Runs painting the tank first two times?
#955 sibhs
Posted 19 June 2023 - 08:57 PM
Thanks Heath
Cheers Clay, yep plenty of runs. Managed to get it done by only painting one side at a time instead of the whole thing at once.
The dash was in really good condition but did need some tidying up.
Attached File  IMG_2465.jpeg   271.38K   16 downloads
Work my way around with a screw driver to release the cover.
Attached File  IMG_2483.jpeg   130.24K   12 downloads
Attached File  IMG_2485.jpeg   329.05K   7 downloads
Brasso worked well to polish the plastic lenses.
Attached File  IMG_2490.jpeg   184.98K   8 downloads
Painted the needles and required bits.
Attached File  IMG_2496.jpeg   149.36K   7 downloads
Attached File  IMG_2498.jpeg   190.53K   7 downloads
Attached File  IMG_2505.jpeg   96.59K   8 downloads
Chrome pen used to re-do the surrounds.
Attached File  IMG_2512.jpeg   225.73K   7 downloads
Had a fellow forum member check the operation of the gauges. Connected them up to his tester and flicked the switch to test.
Attached File  IMG_2561.jpeg   189.37K   11 downloads
I want to get the speedo serviced and re-set to zero. Just got to find a instrument person north of Perth.
#956 rodomo
Posted 19 June 2023 - 10:46 PM
Getting there Marty! What did you use to "swish" the fuel tank out with prior to fitting?
#957 claysummers
Posted 19 June 2023 - 10:50 PM
Funny I had the same problem. Ended up using a 1.2mm touch up gun. One shot 2k metallic over Epotec.
#958 sibhs
Posted 19 June 2023 - 10:59 PM
Hi Rob, I used KBS tank treatment system. Works really well fixing pin holes and eliminating rust. Used on the LJ and still good 8 years on.
#959 Rockoz
Posted 20 June 2023 - 10:01 AM
Thanks Heath
Quite a few years ago I got some really good advice from a VDO rep in Perth.
He managed to point me in the right direction for parts for LH LX Tachos
Probably too long ago to find an email address or the shop, but you might find something by searching.
#960 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 20 June 2023 - 10:51 AM
looking good marty
still waiting for my door cards
instrument tester and refurbisher
Speedline instruments in malaga
did a 48 kb3 cluster for bro came up spot on
#961 sibhs
Posted 22 June 2023 - 07:45 PM
looking good marty
Thanks Guys, I'll give Speedline a call.
Gearbox is back from builder.
It needed another cluster gear and kit put through it. Luckily I had a good second hand cluster and kit.
I cleaned it up before masking and painting. Decided to paint by hand due to temperatures, time and who's really going to see it.
Attached File  IMG_2556.jpeg   189.38K   6 downloads
Attached File  IMG_2559.jpeg   122.71K   6 downloads
They'll never know!
Attached File  IMG_2565.jpeg   155.5K   7 downloads
Attached File  IMG_2573.jpeg   167.49K   6 downloads
Attached File  IMG_2575.jpeg   139.52K   6 downloads
Fitted the linkages and tested the shifter. Got all the slack and wobble out of them.
Attached File  IMG_2600.jpeg   210.06K   7 downloads
Next step is getting this under the car.
#962 yel327
Posted 22 June 2023 - 07:59 PM
Your overspray is too neat! Looking good.
#963 LJ RB30
LJ RB30
  • 1,058 posts
  • Name:Trevor
Posted 23 June 2023 - 12:40 AM
Hi Marty,
Impressed as always at your motivation & attention to detail.
You have given me ( a few months ago initially now) the motivation to  try something i never ever wanted to do ie rust/panel repairs, inner & outer sills.
Its on a rusty patina 4 door that's destined for drags only & its definitely not going to be a show car buts its given me great practice to repair some long avoided repairs on a couple of my other vehicles that i want to fix.
But my question now is what have you painted the gearbox with?
I was going to do a 2 pac red oxide color equivalent on a box I've had in bits for a while so im curious to know what yours is as it looks basically like it should.
Keep up the awesome work mate.
Will have to catch up again & see your handy work in person.
#964 sibhs
Posted 23 June 2023 - 09:28 PM
Hi Marty,
Hi Trev, Rust repairs and painting can be very rewarding. That 4 door sounds like perfect practice for you.
The paint is a two pack I had matched up to red oxide colour. I used it on the interior of the body shell and the gear box. I've got a bit left over if you want some when you drop by for a chat.
#965 LJ RB30
LJ RB30
  • 1,058 posts
  • Name:Trevor
Posted 24 June 2023 - 04:37 PM
Thanks Marty that would be great.
Yes it was daunting at first but having two others to compare to the shed helped as the tin termites were definitely hungry.
Panel work is definitely an iceberg scenario! There’s ALWAYS more below the surface😂😢
I seen the inner sill you got and thought I would use barely 1/5th of that to fix the good car and barely 1/2 & 1/3rd to fix the rusty one so I decided to make my own.Attached File  00F59BAD-C633-44D3-9E68-68FE74CF9325.jpeg   112.22K   6 downloads
I can make left & righthand panels with this.
Certainly not perfect as they require straightening & flattening but it’s perfect for my beginner attempts😁
I’ll PM you about catching up.
I look forward to seeing your awesome work 👍
#966 S pack
Posted 24 June 2023 - 05:28 PM
I seen the inner sill you got and thought I would use barely 1/5th of that to fix the good car and barely 1/2 & 1/3rd to fix the rusty one so I decided to make my own.attachicon.gif 00F59BAD-C633-44D3-9E68-68FE74CF9325.jpeg
Nice work Trevor. :spoton:
#967 claysummers
Posted 24 June 2023 - 07:21 PM
That's the way...
#968 sibhs
Posted 24 June 2023 - 08:58 PM
Excellent Trev, I hope you got the same buzz I get when a complete amateur creates something cool like that.
Another big step ticked off this build. The engine and gearbox are in with the help from neighbours (good ones) and Sally.
With a lack of space I had to lift car from the side then prop it with chassis stands, slide the engine under then move the lifter to the front and lower it down. It all went smoothly and the K-Frame bolted up well.
Attached File  IMG_2614.jpeg   151.39K   4 downloads
The long walk from the back workshop to the front garage.
Attached File  IMG_2632.jpeg   239.32K   6 downloads
Attached File  IMG_2634.jpeg   206.63K   8 downloads
Attached File  IMG_2639.jpeg   183.58K   7 downloads
Attached File  IMG_2650.jpeg   227.37K   9 downloads
Attached File  IMG_2656.jpeg   212.45K   9 downloads
The first time the LJ has seen the LC in Amethyst.
Attached File  IMG_2659.jpeg   179.37K   8 downloads
Next task is to get the engine fired up.
#969 LJ RB30
LJ RB30
  • 1,058 posts
  • Name:Trevor
Posted 25 June 2023 - 08:00 AM
Fantastic 😁
You are certainly a master at using the space you have👍
#970 jpxu1
jpxu1
  • 573 posts
Posted 25 June 2023 - 12:40 PM
That old adage- where there's a will, there's a way!
Excellent work.
Edited by jpxu1, 25 June 2023 - 12:40 PM.
#971 sibhs
Posted 14 July 2023 - 09:41 PM
With the engine in it's time to get the dash pad and gauges fitted. I fitted the crash pad and realised I couldn't secure the three nuts on left side because I'd fitted the glove box. This was a pain it the arse because I had to remove the glovebox, heater control panel, lower dash and the demist ducting. Fit the three nuts and put it all back in.
Attached File  IMG_2683.jpeg   136.97K   12 downloads
Attached File  IMG_2684.jpeg   136.71K   12 downloads
Attached File  IMG_2686.jpeg   161.05K   11 downloads
Attached File  IMG_2727.jpeg   156.03K   9 downloads
Thanks to Albert for recommending Speedline Instruments. I dropped the speedo off for a service and set the odo to zero. They said they stripped it, cleaned, replaced worn bushes, assembled, calibrated and tested. They are very professional company and only took three days. Cost was a bit more than I was expecting ($200) but happy it wasn't lost or broken.
Attached File  IMG_2841.jpeg   109.13K   3 downloads
Attached File  IMG_2733.jpeg   386.46K   4 downloads
Setting up the Rares bumper and fitted.
Attached File  IMG_2734.jpeg   171.8K   3 downloads
Attached File  IMG_2744.jpeg   194.19K   4 downloads
Rear trims in and back seat fitted. I've made a cut out rocker cover to keep an eye on valves and oil pressure.
Attached File  IMG_2754.jpeg   173.55K   5 downloads
Attached File  IMG_8617.jpeg   165.86K   6 downloads
#972 Indy Orange
Indy Orange
  • 2,987 posts
Posted 14 July 2023 - 09:47 PM
Looks mint Marty!
#973 sibhs
Posted 14 July 2023 - 10:08 PM
Seem to be gathering a collection of grills and want to have a go at restoring them. I've made enquiries about re-anodising and I've done some tests on aluminium braising. Next is making a jig to get them straight and have correct profiles to tap out the dings and dents.
Jig is made from using a nice straight sample and from my quick little tests it looks like it might work. If this is another one of my 'Fail' ideas I have a cool Mad Max style grill for the shed wall.
Attached File  IMG_2675.jpeg   575.39K   4 downloads
Attached File  IMG_2668.jpeg   551.38K   4 downloads
Attached File  IMG_2669.jpeg   349.27K   4 downloads
Attached File  IMG_2671.jpeg   559.02K   4 downloads
Attached File  IMG_2672.jpeg   386.62K   4 downloads
Attached File  IMG_2673.jpeg   413.17K   5 downloads
Attached File  IMG_2674.jpeg   257.94K   4 downloads
Edited by sibhs, 14 July 2023 - 10:09 PM.
#974 Ice
Posted 15 July 2023 - 12:24 AM
Looking fantastic Marty love the dash and that colour trim is the bomb
but i think you need some fuel you’re empty
#975 bat 53
bat 53
  • 527 posts
  • Name:albert
  • Car:lc gtr
Posted 15 July 2023 - 10:20 AM
glad to help
you have more patience than me for repairing delicate stuff
looking good
albert
