Hawks Torana dream lives on
447 replies to this topic
#401 Rockoz
Posted 28 February 2025 - 02:40 PM
Doesnt take too long to pull the front seats out.
That can help making underdash work a bit more bearable.
Have done it many times to make life easier.
#402 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 28 February 2025 - 03:28 PM
That's the plan as I need to finish the shifter cover too.
Attached File  20240225_161313.jpg   203.76K   5 downloads
#403 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 01 March 2025 - 03:08 PM
Ended up calling the guy I got the reco carb off and he exchanged it for another one.
Runs pretty much perfectly now.
#404 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 21 April 2025 - 08:14 PM
So the car is getting there now.
The gearbox issues are almost sorted, just one small change to make to the cable.
The shifter surround is in. I tacked it in place and ran seam sealer around it in case I ever want to make it better.
Attached File  20250417_085832.jpg   898.62K   6 downloads
I then changed the interior back to the cream colour as it's closer to my new front seats
Attached File  20250418_141846.jpg   672.13K   5 downloads
#405 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 21 April 2025 - 08:23 PM
New front seats are in.
Attached File  20250421_170239.jpg   679.66K   4 downloads
On another note, I have been considering selling the car to help with a head start on a house deposit.
I know it's almost there but considering the cost associated with getting the car engineered, I'm not sure if it's worth it at this stage.
The car is still registered as a 6, but the issue would be insurance.
Currently to get engineering it would need:
Upgraded booster
upgraded front brakes
pollution gear hooked up
Handbrake cables made
tailpipes (this is an issue due to the current fuel system)
The bigger issue is that I picked this motor up cheap as it has no engine number, its a VT roller motor. I do have a 78 308 block that I could use but realistically the right thing to do would be to buy another bottom end and swap all my stuff onto that motor.
I guess that's my mistake, probably shouldn't have purchased it like that.
So I'm kind of stuck, even selling the car in this state would probably be a hassle.
Thing is I'm scared to drive it much without it being legal and having insurance.
#406 ben23
ben23
  • 262 posts
  • Name:Ben
  • Car:'77 LX 2850 sedan
Posted 21 April 2025 - 08:51 PM
Hey mate I can't believe I have overlooked your build, admittedly I don't spend enough time on here. I just had a good browse through it and you are doing a top job. You commented recently on my "what to do?" post and while yeah at our respective points, selling the cars and putting it buying houses. You know what, frOck that. I'll get mine done and come down to Mexico and we will cruise!!
#407 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 21 April 2025 - 08:57 PM
Cheers Ben appreciate the sentiment. I'm in the same boat as you, way too deep into the car to ever make my money back now.
My issue is that my daily driver is rooted, I'm renting and have no savings.
I also have full custody of the 10 year old son which changes things a bit for me.
I definitely won't rush into the descision
#408 yel327
Posted 22 April 2025 - 07:40 AM
Upgraded booster
That's a bugger mate. What do you need to do with the brakes I get the booster, but rotors/calipers wise?
You do know that a VT motor will have the correct date code for a late 70's ADR27A 308....
#409 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 22 April 2025 - 10:12 AM
Cheers Yel,
The rotors/ callipers will need to be upgraded to HQ at a minimum.
The way i look at it is and HQ setup will cost around $1500 once you factor in new discs, HQ stubs, girlock steering arms etc.
Hoppers kit would be around the $2200 mark.
No idea what a booster and master will cost.
engineers certificate will be a minimum of $2000.
#410 yel327
Posted 22 April 2025 - 11:06 AM
Cheers Yel,
Is that what the Engineer makes you do? Because its a UC and you cannot use the fact that LX with L31 had the same rotors and calipers as a 6cyl car?
You could probably do the front brake upgrade to a budget if you were only doing it to sell it. HK-HJ stubs are easy to find, its the calipers for HQ that are getting harder to buy. Just use the UC steering arms, not perfect but pretty good. The easy way out is to use your UC PBR calipers (if that is what is on it) and simply change the pad carrier (to the one with HOLDEN on it). For the rears just bolt on HQ-WB backing plates, and fit HK-HG drums, straight bolt on including the Torana handbrake cables. The master cyl should be fine (unless its the late UC with the alloy/plastic master, then you need an aftermarket WB ute/van/tonner one). Booster you'll probably have to get one made out of other boosters and using your back pushrod. HK-HG work. That does mean you are left with HQ front stud pattern and UC rear though, unless you can get some axles made with HQ pattern, then HQ-WB drums just replace the HK-HG ones. I did see a whole HK-HG front end on Marketplace last night fitted with HQ front discs and calipers, and it looked like the rotors were drilled to HK-HG, but the bugger was in WA.
Engineers Cert does hurt I agree. But how much less is the car worth without it?
What I was getting at with the VT block - I assume it is all tested and legit (as in no risk of it being hot?) If it is just tell them its a HX/Z or VB block, and get a Police number issued.
I can assist you with what you need for the ADR27A gear so its all good. Remember a red ADR27A V8 has no EGR valve, it is blanked off.
#411 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 22 April 2025 - 01:39 PM
My rear brakes are the skyline discs and callipers. So I'm set there.
What I was led to believe when I purchased the motor is that the number off this one was getting used on his new motor as the car is registered with that number.
Hence it was taken off before the motor was sold to me. and pretty poorly at that.
If that isn't the case then yes there is potential it's hot.
I shouldn't have bought it, it was a mistake.
#412 ben23
ben23
  • 262 posts
  • Name:Ben
Posted 22 April 2025 - 01:59 PM
The way I see it is it won't really put a dent in saving for a home, however if it was the one thing stopping me from getting over the line, then yeah, I probably would.
#413 yel327
Posted 22 April 2025 - 02:01 PM
That will cost you more Engineering again with a rear disc conversion, they’ll have to do brake tests.
I’ll PM you the the number.
If you have Marketplace search “Disk brake Front cross member” in Mandurah WA. You can see he’s done a HQ disc and caliper conversion on a HK crossmember. Basically identical to hat you’d need to do, same stubs too.
#414 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 22 April 2025 - 03:05 PM
Thanks,
Yeah it's a complete Skyline rear end in it out of an R31. still need to get Handbrake cables made up.
Was hoping g to just pass it off as a factory disc rear end.
I have some H series callipers at home. I'll dig them out and see what type they are.
These are the fronts currently on it. When asking repco or similar for UC pads it always comes up with the wrong ones.
Attached File  20210731_134516.jpg   156.85K   5 downloads
#415 claysummers
Posted 22 April 2025 - 04:00 PM
Those marketplace studs look 4.75” PCD to me Byron, not 4.25”.
Edited by claysummers, 22 April 2025 - 04:00 PM.
#416 yel327
Posted 22 April 2025 - 04:03 PM
Look in between the studs Clay, there is other holes. They have obviously been drilled for something else.
#417 yel327
Posted 22 April 2025 - 04:09 PM
Thanks,
You might get away with that, Engineer's aren't silly though!
Is this late UC? Does it have the WB style master cylinder or a cast iron one?
These are the caliper style I was talking about. You just replace the cast iron bit (says TORANA) with the corresponding bit off a HOLDEN:
https://www.ebay.com...:Bk9SR_7mycHLZQ
These bolt straight up to HK-WB stubs/rotors with UC steering arms.
Here is the Holden type, you can use the whole caliper but the hose is bottom entry, top entry is more suited to Torana. Plus you need the Torana slide, look on the Torana ones on the Ebay link, the bolt that goes at the front next to the tie rod has a recess in it, which is for an Allen headed bolt. The normal Holden one fouls the tie rod.
https://www.ebay.com...:Bk9SR9qC38HLZQ
#418 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 22 April 2025 - 07:09 PM
This is the one on my car now.
Attached File  20250422_190704.jpg   840.57K   6 downloads
#419 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 22 April 2025 - 07:18 PM
And the where the engine number should be.
Attached File  20250422_191552.jpg   234.77K   5 downloads
#420 yel327
Posted 22 April 2025 - 08:37 PM
That cylinder would probably need upgrading to 1”, a WB Statesman replacement would do most likely.
That engine number pad isn’t pretty.
#421 RoyalPlum76SS
RoyalPlum76SS
  • 255 posts
  • Name:John
  • Car:SS Hatch
Posted 23 April 2025 - 01:48 AM
Thanks,
Those front callipers were only found on the late UC's, from mid 79 onward. They are actually the best of all the callipers found on LH-UC (exc L34's and A9X's) Basically the same calliper was found on the VB Commy's (only difference was the hose entry was on the back of the piston for the Commy's)
Just ask for a DB1085 if you want pads.
Seeing as these almost identical callipers were fitted to the 308 powered Commodores, would that be enough to sway an engineer to tick them off as adequate stopping power for a V8 UC?
#422 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 23 April 2025 - 08:24 AM
It possible, but I think upgrading is necessary. I have had them glowing with some spirited driving through the hills and that was when it was 202 powered.
#423 neglectedtorana
neglectedtorana
  • 1,090 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 23 April 2025 - 07:54 PM
Hi Steve,
You've done lots of work, well done.
What are the seats? Did they come with rails?
Before you get too worried about engineering have you spoken with one?
My understanding depending on which engineer you talk to is brakes that passed ADR on any vehicle are ok. I used Wilwoods and they don't have ADR approval so I had to do the brake test, I think if I had used the AU discs nd PBR caliper upgrade the brake test wasn't necessary as those components passed ADR.
Worth checking with an engineer first and might be worth asking more than one as you get different interpretations from each one.
Hope you get there and enjoy the car.
Cheers, Tom
#424 hawk
hawk
  • 2,221 posts
  • Name:steve
  • Car:UC Torana
Posted 23 April 2025 - 09:27 PM
Hi Tom,
The seats are a marketplace find and came with torana rails. They are autotechnica seats.
The backrest is a little narrow for me. but other than that they do the job.
To be honest, I'll probably just bite the bullet and go a hoppers kit.
Realistically though, I need to get ahead again and get a bit of money saved before doing much else with it.
I want to get the handbrake cables done though so I can at least drive it here and there.
The only other issue is that I'm not sure if it's running hot or not. I purchased a 304 sender and once warm its off the gauge, change to a 6 cylinder UC sender and its off the gauge once warm too.
So not really sure if it's actually running hot or not.
#425 Sicklh
Sicklh
  • 107 posts
  • Name:.
Posted 24 April 2025 - 09:14 AM
I follow you on Tiktok Hawk, Love the videos.
