Drop Tank Sizes
#26
Posted 25 September 2006 - 11:51 PM
So far, purchased alloy 5154 1.6mm, will handle 45 degree folds without stressing the fold.
Baffles (2 off) to be welded onto floor of tank. skid plates will be 5.00mm as will the mounting brackets (4 off). Will go with 2 holes in the tank, one for the intank fuel pump and the other for the OE Torana pick-up and fuel level sender.
ATM I can only make it 30mm shallower than the other brand, I am restricted by the height of the fuel pump assy.
Also, the extra plates welded to the sides of the tank where the mounting brackets are eventually mounted will be welded 180 degrees opposite to what I have seen. It will not be welded all the way across the bottom of the plate to allow any water to escape and prevent corrosion.
Not sure if there will be any noise or vibration eminating from the tank through the floor or the mounts when the pump is running.
Is there anyone out there with an intank fuel pump that can shed some light on this?
Thanks, Max
#27
_1TUFSLR_
Posted 08 October 2006 - 07:14 PM
#28
Posted 09 October 2006 - 05:42 PM
#29
_1TUFSLR_
Posted 09 October 2006 - 05:59 PM
#30
_AGGRO_
Posted 07 November 2006 - 07:06 PM
#31
Posted 25 March 2007 - 09:59 PM
#32
_TORANA IN THE BLOOD_
Posted 26 March 2007 - 07:52 AM
#33
_ant355_
Posted 04 June 2007 - 07:06 PM
i just want to see how they are held in and what that plate that it bolts into looks like if thats possible please??
#34
Posted 30 September 2007 - 09:38 PM
#35
_UNVSM8_
Posted 07 December 2007 - 04:26 PM
cheers!
#36
Posted 07 December 2007 - 04:43 PM
#37
_UNVSM8_
Posted 07 December 2007 - 05:01 PM
#38
Posted 07 December 2007 - 05:15 PM
#39
_mowie_
Posted 02 October 2009 - 09:13 PM
#40
_Dukey_
Posted 21 February 2012 - 06:30 PM
Edited by Dukey, 21 February 2012 - 06:33 PM.
#41
_LS1 Hatch_
Posted 23 February 2012 - 02:18 AM
#42
_toranahatchbacks_
Posted 31 December 2012 - 09:21 PM
#43
_Good Stock_
Posted 17 July 2013 - 12:36 AM
#44
_Good Stock_
#45
Posted 24 January 2020 - 07:14 PM
#46
Posted 25 January 2020 - 10:02 PM
Hi Birch. I saved them years ago, but they are now on one of my many external hard drives. I wouldn't be able to even start searching for them any time soon.
#47
Posted 26 January 2020 - 05:16 AM
These are the ones I saved from somewhere here. Be warned though this is a big tank (~120L) and will hang down quite low, you may want to revise the depth especially.
The tank I bought mostly pre-made for my own car is only 200mm deep in total and has a bit more taken off the bottom/rear to improve the rear departure angle. By my calculations its a little under 90L.
None of these leave a massive amount of clearance to the diff, and also generally need the rear strap mounts trimmed back too.
#48
Posted 18 February 2020 - 12:55 PM
I made mine to the dimensions above (230 high) and i would agree its sit way to low under the car. Personally i think it doesnt suit the car. When i finally pull my finger out and get to rebuilding the car, i will be triming 30-50mm out to make it shorter.
#49
Posted 20 February 2020 - 02:07 PM
