Supra 5 Spd behind 253/308 - WHICH CLUTCH SETUP?
#1
Posted 28 August 2006 - 11:51 PM
I am currently looking into all these options, trying to decide on which setup to go with (I'm replacing the aussie 4 speed behind my 253 for a W55 Supra 5 speed). The current clutch setup consists of a cable that goes to a rat-trap.
Can anyone tell me what options I have if I decide to retain my current clutch setup? Is this possible? I know I need to buy a new clutch plate (ie. through Castlemaine Rod Shop or similar).. but I heard I can pretty much use all the other original parts... is it that easy?? The bellhousing I have for the conversion is CRS one (Part # BH40) which I believe is the one that can be used to suit multiple setups.
It seems the most common method is going to a full hyraulic conversion from CRS/Dellow etc.... but I'd really like to find out if I can just keep my current setup, and if this setup works ok?
What path have others taken when putting a Supra box behind a Holden V8? Which standard Holden parts are retained & which other parts need to be purchased?
Any good or bad experiences? Pro's & con's ????
Many thanks.
#2
Posted 29 August 2006 - 12:15 AM
i just hate the old rat trap (dog trap) and prefer the heavy clutch feel the cable gives.
if you have soft legs or dont like the heavy feel, go hydraulic.
the bell housing will have multipul folk nipple mount locations if it is a multi fit.
#3
Posted 29 August 2006 - 12:39 AM
But from my undertanding the only thing you actually have to change is the driven plate with the splines. Since the bellhousing should use your original fork and thrust bearing and the cover still bolts to your original flywheel..
The 308 clutch is 255mm diameter so its just a case of using a Toyo driven plate with the right # of splines in that diameter
For extra free clamping force I would have the flywheel machined with a 20 thou step like a Toyota one (this is what I do on the racecar) rather than having a flat flywheel.
Should be an easy swap
At least I hope so as I have a similar kit going behind a 253 or 308 in the future
#4
_Toranamuk_
Posted 29 August 2006 - 12:44 AM
Using the BH 40 bell housing, purchase a CB2 cable bracket & either one of CRS's custom clutch forks, or modify a commy/WB V8 clutch fork. The outer protruding edge of the fork from the bell housing needs to be heated & bent towards the rear of the bell housing.
Use a standard UC 6cyl Aussie 4sp clutch cable.
Grab a stock UC 6cyl cable clutch pedal. The top of the pedal needs to be modified to get the pivot ratio correct to suit the longer clutch fork.
Cut the hook off flush with the top of the pedal. Add a 25mm piece between the pedal & the hook to raise the hook up by 25mm & weld it in (good quality welding needed).
Modify the panel above the clutch pedal with a die grinder where the hook will swing to give it enough clearance. It will go right up to the brake pedal bolt crush tube.
It might sound like a lot of work or a bit odd, but its worth the effort, & to only have 1 effective wearing part (the cable) it gives a nice smooth & not heavy clutch.
I've done a lot of these conversions, & even one for "dangerous" for his hatch.
For more info if you need , PM me. More info to give than what it'll take to post, like cable position in the firewall etc etc
#5
_UCV80_
Posted 29 August 2006 - 10:02 AM
I use cable and its fine,
It is that easy
I have a 6, but i dont see how the v8 would be different..
#6
Posted 29 August 2006 - 03:40 PM
Ok so my main question now is why go to these lengths to do this custom setup? Why do your prefer it over the factory setup, if it's so easy to just change the clutch plate and use all the original bits? Why don't you like this setup?? It would only have two wearing parts - the cable and the rat-trap...
Thanks again, I really appreciate all these answers!
#7
_Toranamuk_
Posted 30 August 2006 - 08:40 PM
The rattrap has too many moving & wearing parts in it, fulcrums, pivots, clevis pins & all held in by 1 5/16 bolt that commonly breaks. Not a reliable setup, plus gives a heavier pedal than the same clutch that uses a cable only system.
#8
Posted 31 August 2006 - 12:23 AM
The rat trap I have also had, and can also vouch for it's horrible feel and unreliability.
Dave
#9
Posted 31 August 2006 - 11:51 PM
#10
Posted 14 September 2006 - 04:21 PM
I will be stoked if the length is already correct...
#11
_73LJWhiteSL_
Posted 14 September 2006 - 07:50 PM
For some reason the LX Hatch that the conversion came from for my car used the standard tailshaft, but in the LJ the standard tailshaft wouldn't fit. Go figure. I do understand the Supra box is noticable longer than the Celica box however. I would say you will need to get it shortened.
I used Hardy Spicer in Dandenong.
(03) 9799-3250
1/ 73 Remington Dve
Dandenong South Victoria 3175
In the end balencing and shortening cost me $120
Steve
Edited by 73LJWhiteSL, 14 September 2006 - 07:53 PM.
#12
_Toranamuk_
Posted 14 September 2006 - 09:49 PM
The BH82 bell housing is 5/8ths (16mm) shorter than the V8 Aussie 4sp bell housing, so the slip yoke that CRS supplies is 5/8ths longer & accepts the standard RUJ2030 uni joint.
Fit new premium joints & get it balanced though (or get the balancing co. to supply & fit uni's).
The supra conversion behind a 6cyl requires a 25mm (from memory, although something clicking at 19mm) SHORTER tailshaft, as the length of the supra/celica input shaft is longer than a 6 cyl Aussie 4sp (or 3sp).
#13
Posted 14 September 2006 - 11:33 PM
I've got a great bloke I use for tailshafts in Ferntree Gully, so I'll get him to fit brand new uni's and balance it all tomorrow... ace! The hatchback may just be back in action on Saturday!
Thanks again guys, huge help as always
#14
Posted 14 September 2006 - 11:44 PM
#15
Posted 15 September 2006 - 11:50 AM
#16
Posted 16 September 2006 - 01:53 PM
I ended up deciding to stick with the standard clutch setup initially, and see how it goes.... then later down the track if it does prove horrible then I was going to upgrade to the custom setup mentioned above.
Anyway, so I've fitted the correct Toyota clutch plate, and retained all the other stuff as original Aussie 4 speed (pressure plate, thrust bearing, throwout fork etc)... and I was going to use the original rat-trap/cable combo.... But I've just gone to bolt the rat-trap bracket up, and it's totally different on this CRS bellhousing! There's no way it will bolt up. The bracket has 2 bolts, perfectly aligned (flat) to each other. The CRS belhousing has a massive bulge where the bottom bolt goes in (and therefore requires a much longer bolt).... what is going on???? How am I meant to make this work???
355LX - you mentioned you've used the rat-trap setup... how did you bolt it all up?? Did you have the BH40 CRS bellhousing????
Bugger bugger bugger :(
Edited by LXCHEV, 16 September 2006 - 01:54 PM.
#17
Posted 20 September 2006 - 12:21 PM
#18
Posted 20 September 2006 - 04:36 PM
I am not 100% sure, but there may be a couple of different rat trap assemblies amoungst the holden V8 line-up over the years. I tried to fit the factory LX Torana rat trap set-up on to my HJ monaro, but it seems to be different, and wont play ball. It may only be the part of the assembly that attach's to the firewall that is different for mine, but as it's not a primary concern (selling it as non-running car), I have'nt persued the problem.
Maybe a question for Dr Terry to clear up, if there are in fact different ones out there.
Dave
#19
Posted 22 September 2006 - 12:02 AM
#20
Posted 22 September 2006 - 12:25 AM
also avliable for the above from dellows is a cast bracket that allows cable fitment (and you will need a different folk)
#21
Posted 07 April 2008 - 11:24 PM
I am over this rat-trap setup... the bolt has already snapped on me once and the swinging arm brackets broke too... but we repaired it & I've been cruising happily ever since.
However, it's starting to feel a bit average again, I had a quick look and things are getting messy under there, hahaha!! I'm hoping to just get a few more weeks of cruising in, while I get all the parts together to do the full Commodore / UC pull-type cable setup.
I'm already using the BH40 bellhousing, so I'm going to order the CB2 cable bracket.
Toranamuk - in your original post, you mentioned CRS sell 'custom forks'. Is this a listed item available off the shelf? What do I need to ask for? Any help would be great.
I'm also now on the lookout for a UC 6cyl aussie 4 spd cable - hopefully Rare Spares sell these, and then I need to find a stock UC clutch pedal - will hit the wreckers this week.
More to come soon.... wish me luck
#22
_Toranamuk_
Posted 07 April 2008 - 11:52 PM
CRS used to list a heavy duty brass/bronze clutch fork that was cast to suit the BH40 & CB2 bracket. Hopefully they still make it.
It is cast so that the hook end points slightly rearwards & it retains the same distance from the cable mount to the hook that the original holden setup should have.
You can heat up & bend the original clutch fork carefully, I have done it & then welded some small support braces on the inner edges where it has been heated & bent.
I do have some clutch pedal cable hooks being laser cut so that any pedal can be converted, I need to & will follow them up, as they have been there since new years so hopefully some progress can happen soon.
The clutch cables are still available new, if you cant get one or get stuck let me know.
Craig.
#23
Posted 07 April 2008 - 11:57 PM
- Brett.
#24
_UC HATCH_
Posted 08 April 2008 - 03:00 AM
Here the throwout forks from CRS catalog that are the right type.
Hope this helps you some.
A wrecker may be cheaper for one from a HZ-WB or Commy v8.
Posted 08 April 2008 - 10:55 AM
Thanks UC HATCH.
