186 rebuild, Oracle advice
738 replies to this topic
#1 claysummers
Posted 26 February 2021 - 05:29 PM
Was 1996 last time I rebuilt one if these so I thought this the best place to get specific advice along the way.
Motor came in my FB ute and appears to have been bought unstamped unpainted short motor then stamped V680077P, so assuming it is 68 vintage.
Ran fine with 155 to 170 compressions but noisy piston and or gudgeons and smoky.
The bores seem to have minimal ridge however the pistons seem to have a good 25thou clearance and rock in all directions.
Hers is where some advice is solicited. I'm having trouble getting the balancer key out of the keyway in the crank, so I can pull the rear off the snout. Appears to be pretty tight. I was thinking it would just be pulled out by the rear as it slides up the snout. Not sure now and don't want to force it. Not worried about the key as they are generally replaced. But don't want to break tool using the rattle gun. Maybe I'll proceed by hand.
early Holden nut
#2 claysummers
Posted 26 February 2021 - 05:33 PM
Never mind the last question c same with perserverence.
early Holden nut
#3 S pack
Posted 26 February 2021 - 07:18 PM
The woodruff key shouldn't be hard to remove from the snout. Blind punch and a small hammer to dislodge it.
#4 rexy
  • 3,834 posts
Posted 26 February 2021 - 07:40 PM
That is a vic police number?
#5 S pack
Posted 26 February 2021 - 07:46 PM
Correct, VIC Police Surrogate vin number. The 77th number issued in 1968.
#6 yel327
Posted 26 February 2021 - 08:02 PM
You’ll know by the cast date when it was built.
Check the crank’s end float too to make sure it is OK. I can’t recall a Holden six in a car having issues but seen a lot of SBC’s out of manual trucks where the crank is buggered as the thrust surface on the crank has worn. On one of them I had no end of trouble removing the key as it had been affected by the crank moving backwards and forwards. If the Holden 6 you have has been in a Bedford it may have been hammered. The reason I have seen a fair few truck SBC’s is they are a good source of STD bore 4 bolt blocks. Funny thing is they normally have buggered thrust and bearings but are often STD bore. Maybe it’s something to do with small (2BBL) carbs so less bore washing but boy do their crankshafts cop a flogging!
#7 claysummers
Posted 27 February 2021 - 08:12 AM
Yeh key came out with a decent punch on the end thanks Dave.
Not too worried about the date really but yes I’ll check end float. Not planning on pulling the caps. I’m on a bit of a deadline so I’ll probably send off to local builder. The only value is saving me another inspection if I change blocks. Otherwise have a 179 in better condition. These are both virgin bore and crank. But the 179 could get by with a rering.
#8 yel327
Posted 27 February 2021 - 09:04 AM
You could always reuse the 179 pistons if any good in a 173. Same deal with 186 pistons in a 179.
#9 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 27 February 2021 - 10:04 AM
Did you say 25 thou piston to bore?  :blink:
#10 claysummers
Posted 27 February 2021 - 02:48 PM
I could get feeler gauge down to top ring. My gauges are so old I can’t read the labels but I think so. The slugs can be rocked fore and aft, and side to side noticeably. It ran ok up to valve bounce and drove it for a few hundred ks, but was noisy at revs and used a lot of oil. Like 0.5 litres per 100km.
#11 claysummers
Posted 27 February 2021 - 02:54 PM
Yes. I won’t bore the 186 over 30 or 40. I think the 179 pistons and bores may be good as is. If both need boring then 179 out to 186 will be the path.
#12 I'm a Red Motor fiend
  • 774 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 27 February 2021 - 04:10 PM
If either of the cranks had an auto behind it use that and linish or grind.
If the 179 measures up hone and re ring but if not yeah bore the 179, it's a no brainer.
#13 yel327
Posted 27 February 2021 - 04:42 PM
There is some NOS STD 186 pistons on EBay. I saw some 179 ones recently too.
#14 claysummers
Posted 27 February 2021 - 04:50 PM
179 had no spigot bush and is early HP so would have been Hydramatic. Why is the auto crank preferable. Obviously will be a steel crank in the 179 too.
Yeh had a hunt recently saw those thanks Byron.
#15 yel327
Posted 27 February 2021 - 04:55 PM
Manuals thrust the crank a lot more than autos.
#16 yel327
Posted 28 February 2021 - 01:18 PM
Here is a cheap 186 in Victoria. Has a 3.3 or 2.85 head with it.
#17 claysummers
Posted 28 February 2021 - 03:49 PM
Don't tempt me. Already got 2 149s, 161, 179,186 oh and 3 or 4 greys. Oh and 202 blue.
early Holden nut
#18 claysummers
Posted 28 February 2021 - 03:56 PM
Casting is March 28 1967
early Holden nut
#19 claysummers
Posted 28 February 2021 - 04:11 PM
Crank 742000 not in MPC up to HR so maybe HK
early Holden nut
#20 claysummers
Posted 28 February 2021 - 04:32 PM
Although the HP is 7420005
early Holden nut
#21 yel327
Posted 28 February 2021 - 04:40 PM
HR engine. Same engine as HK though other than the body specific changes to engine dress.
Those look a lot like engine plant stamps, so maybe you are right that is was a block and piston or short engine? Who knows.
#22 claysummers
Posted 28 February 2021 - 06:01 PM
I'm going to apply for engine change shouldn't be a problem but we'll see. The 179 will get away with hone and linsh I'm betting.
early Holden nut
#23 claysummers
Posted 28 February 2021 - 06:28 PM
Both cranks are 7420005 I now realise. Can't find this number in my MPC because the index is partly missing.
Choice of block currently pending so on to heads. I want to use the water heated alloy manifold compatible head and have the choice of a stage 1 style 202 head just needing a grind and rocker arm replaced, or I have a 161 H head condition unknown. Suspected stock in need of overhaul. I don't have a 186 style low comp with adjustable tappets. Not interested in lashing out $600 on roller rockers as I don't intend running a big cam.
early Holden nut
#24 yel327
Posted 28 February 2021 - 06:58 PM
Just remember the 161 head is going to give you high 9’s or 10:1 compression, and without a decent cam it might ping on you. You shouldn’t have any dramas finding a 179 or 186 head if you want to run the bigger chamber but the older rockers.
#25 S pack
Posted 28 February 2021 - 06:59 PM
I doubt you will find 7420005 in any parts catalogues. That will simply be the part number for the raw forging. The finished auto and manual crankshafts will have their own unique part numbers.
