186 rebuild, Oracle advice
#726
Posted 07 October 2024 - 02:05 PM
#727
Posted 07 October 2024 - 05:06 PM
#728
Posted 07 October 2024 - 06:32 PM
Inlet non-return valve failed.
#729
Posted 07 October 2024 - 08:06 PM
Good detective work to track that down Clay.
#730
Posted 08 October 2024 - 05:47 AM
#731
Posted 12 December 2024 - 02:30 PM
I blocked off the vacuum advance and set the static advance to 9 degrees. Timing light shows 34 degrees at 3k rpm.
Intermittent flat spot down low continued and got worse, combining with pinging and backfiring and occasionally running backwards. Eventually it would not start and appeared to have no spark. After a rest it started and ran well enough to manoeuvre it out of the way and eventually in to the shed.
This morning I replaced the ignition module with a new genuine Bosch item, not forgetting to apply fresh silicon heat transfer grease. I went for a short run up a steep hill and all seems good. I will unblock the vacuum advance and do some more driving, before advancing the timing toward 14 degrees.
Early days, but now I am speculating that it was the module all along. It is not long since I got the distributor rebuilt by scorcher. The module I removed was the original Bosch factory item. I suspect they didn’t see anything wrong with it at the time as the problem was intermittent. I wonder if there is a simple method to test these. Early days, and still a chance of the problem reoccurring yet, but fingers crossed.
#732
Posted 13 December 2024 - 03:09 PM
I spoke to Performance Ignition in Nunawading. They thought my description of the problems didn’t indicate module failure, more like coil but conceded it may have been. Weren’t keen on the coil I have installed. I will do some research but open to suggestions.
Also tested resistance from inside the cap to end terminals of leads. In the range 400-800 Ohms. Anything less than 1k is considered good and up to 4K Ohms acceptable.
Happy days
#733
Posted 13 December 2024 - 05:43 PM
Good news that you found a potential culprit
might finally get it all sorted out.
Tha rebuilding distributor page done by fuzzypumper has
a bit about testing hei modules and the target multimeter readings
coils too, I think
https://onedrive.liv...7!91687&o=OneUp
#734
Posted 13 December 2024 - 08:34 PM
#735
Posted 13 December 2024 - 08:39 PM
#736
Posted 14 December 2024 - 08:37 AM
I tested continuity on there old module but could not get any reading. All over limit.
#737
Posted 14 December 2024 - 09:25 AM
#738
Posted 18 December 2024 - 09:59 AM
You've already got the scorcher dissy, so have probably already talked to them. But when I recently called them and asked about coils, they said they were unhappy with the build quality of all coils on the market, so started having their own made. I was told they only recommend the scorcher coils and the MSD Blaster coils. Was the coil you replaced one of scorcher's?
For what its worth, I've also had huge issues with my Triple SU recently. Did the Hardass 1000 drag and drive event. Had this intermittent issue where it would backfire constantly out the carbs with next to no power, drove me absolutely nuts and still havent solved it ![]()
#739
Posted 18 December 2024 - 01:50 PM
