M15 3sp all synchromesh 6 cylinder
63 replies to this topic
#51 claysummers
Posted 29 March 2022 - 09:13 AM
Car Parts Plus are told NLA obsolete on the speedo drive. Available from kingswood country etc on line. Rare Spares Adelaide had on e on the shelf $44. 288cf6f61aaf427f14af43d035f88b5d.jpg
#52 claysummers
Posted 01 April 2022 - 04:01 PM
Gregory says front and side cover bolts 22ft/lb which is 30Nm.42f2477f7965e9640d56a3e6fda93380.jpg
I should have listened to my intuition before 24Nm did this.8a6bab483137e9a04a918deeed0e8e45.jpg
#53 claysummers
Posted 13 April 2022 - 08:46 AM
Clay, the lay gear should not be tight to turn. Check the thrust washers to ensure they are seated correctly with their pressed tab located in the recess.
Thanks Dave. Thrust rings seated correctly. Seems to be turning ok but still firm.
#54 claysummers
Posted 13 April 2022 - 09:03 AM
Box back together with a coat of motor coater on the ferrous bits.108bb0e724c58e1e1b7674a703206fad.jpg2 metre cable came quick off ebay.New thrust bearing and 220mm driven plate ready.
I managed to source a 3.08 open centre Borg Warner shortened to LC width and set up for Torana drums, complete with tailshaft to suit LC for a good price. I just need to cut off the torana mounts and set up for leaf springs. So I haven't got any uni joints yet. I'm hoping the tailshaft will fit up but it is being shipped from Perth.1182dd4f0b6deb8dd5d90d459fba0376.jpg
#55 claysummers
Posted 20 May 2022 - 07:11 PM
Hydraulic clutch setup mock up635ad1bdc79ebd8668b1cdc5f28a7347.jpga mate gave me the Hadfield adapter. They aren't what I would call precisely tooled, but I've got it lining up okay.
I cut the end off the rat trap fork as it isn't needed, and clearance under an FB ute is limited. Plan was to drill a hole to hold the return spring but frOcken hard as, so welded on a half washer to catch it.
I had to bend up a bracket to catch the other end of the spring as well. Not very elegant but does the job. 13d1b25845b0da8792e55157ff7f4ff2.jpgThe Slave is just a FE to EK. They work fine and about $40 for a Protec. Hose a bit cheaper from memory, but was a substitute part which had the storeman juggling catalogues. Fully oldschool at car Parts Plus. They work well with FE to HK master, which is same as FE HR brake master. Original ones of these generally just need new rubbers and a hone to get by, so I've never bought one to know the price. The brackets are $100 or so. All up cost is in the order of $200 to $300. You need the slave rod but easy to make if you don't have one. Kits go for about $500 on eBay etc.
Edited by claysummers, 20 May 2022 - 07:13 PM.
#56 claysummers
Posted 24 May 2022 - 05:29 PM
I couldn't find any piccies of this bit:83cc46a3ee18f66dd516bcdebf57b53e.jpgI wasn't happy we ith how the sliding plate securing spring was sitting so mocked up this inelegant solution.
Any suggestions, what others do? Before I tack weld in place....
Edited by claysummers, 24 May 2022 - 05:30 PM.
#57 Bruiser
Bruiser
  • 881 posts
  • Name:Bruce
Posted 24 May 2022 - 07:00 PM
If it works, it’s perfect
It will look elegant with some black paint
#58 claysummers
Posted 24 October 2022 - 09:19 AM
Before I bolted the box up I tipped it on its side and added the specified quantity of 80w90, 20% Morey's stabiliser, with a yolk and old speedo plug in place.8b2a5dd7e19b9cdeb921f07d375a74c1.jpg
Bolted up with the engine tilted forward, there was a massive oil leak from the input shaft. I tilted it back to how it sits in the car and the leak ceased.
As recall there is no front seal, just an oil slinger arrangement, but the input shaft bearing may be supposed to be a sealed type.
I will have to revisit the manual.
#59 claysummers
Posted 24 October 2022 - 12:00 PM
Gregory’s HKTG manual confirms there is no seal on the all synchromesh 3 speed, as opposed to the 4 speeds, which do. Remind me not to park facing down hill……
#60 S pack
Posted 24 October 2022 - 12:52 PM
The M15 Aussie all syncro 3spd was revised to an oil seal input shaft at the same time as the Aussie M20 4spd in early 1974. Remember that in HK, T & G (up to the end of June 1971) the 4spd boxes were opels, Saginaws & Muncies.The Aussie M20 4spd boxes also had oil slinger input shafts until 1974.
#61 claysummers
Posted 24 October 2022 - 04:46 PM
Thanks Dave,
I did wonder at the Gregory’s. It’s not my first choice of technical reference. It describes two 4 speeds, standard and heavy duty, both with seals.
Possibly I could have matched parts from one of my spare boxes and fitted the seal that came with the kit. Undoubtably it is a fairly early one being the smooth case.
#62 S pack
Posted 24 October 2022 - 05:15 PM
Oil leakage from the front of the gearbox when the vehicle was parked nose down on a steep slope is the very reason GMH revised the 3 & 4spd boxes to have an oil seal on the input shaft.
#63 claysummers
Posted 24 October 2022 - 06:32 PM
Yer it figures. Wiser next time. Good to know it is normal. Had me worried at first.
#64 claysummers
Posted 29 November 2022 - 04:11 PM
Fitted up the box behind the 179 in the ute. The difference is marked of course. Time will tell how durable it is but at this time it is an absolute joy.
I am not overly happy with the clutch slave setup however. I am using a cast alloy Dellow adaptor to FB slave, with pushrod to inner hole in the rat trap fork. I cut the end of the fork off, deeming it superfluous. Very hard steel.
The hose inlet was touching the subframe leg seam lip and I had to grind a bit to create minimal clearence. Also the piston/rod/fork angles are less than ideal which may lead to uneven and premature wear on the slave bore, as well as stressing the bracket and bolts.
So after reading a good review on Fb I bought this resto spares one.588b03a7129816865434632ebd7e46b2.jpg
After doing so I realised it requires a change to EJ HK slave. It also runs the rod in the outer hole, making for lighter less direct pedal. At the moment although not heavy, the clutch is fully released before pedal is half way to the floor.
This is advertised as a conversion part for FE FC FB EK however I fear it may clash with the subframe leg. Will mock up on a spare housing and see.
Edited by claysummers, 29 November 2022 - 04:14 PM.
