Goldie The SL/R 5000
57 replies to this topic
#51 kudu
kudu
  • 1,479 posts
  • Car:LH SL/R 5000
Posted 25 October 2025 - 04:44 PM
Well I just clicked the other day that I hadn't posted anything on here for a while about Goldie. So since my last post a lot has happened. The panel beating has been done. The engine has been rebuilt and it is now at the painters.
I have a lot more photos of the build... But they are all a lot higher resolution than the sure will allow to upload. So I'll have to figure that one out. I've been making lots of videos and putting them in tik tok.
So here are a couple of the engine and when I said goodbye as it left for the painters.
Attached File  IMG_20241202_193117.jpg   114.97K   3 downloads
Attached File  IMG_20241202_071428.jpg   124.71K   1 downloads
Attached File  IMG_20251024_093504.jpg   134.58K   1 downloads
#52 Shiney005
  • 9,970 posts
Posted 26 October 2025 - 10:44 AM
I think if you send a photo to yourself in Messenger it will reduce the resolution???
#53 Rockoz
  • 4,074 posts
Posted 26 October 2025 - 11:37 AM
I have found Facebook the simplest way to resize pics to post here.
I make a post to myself only with the original pic, then save that image to use here.
Nobody on Facebook but you will see the post.
I then delete the post anyway.
Takes all of about 10 seconds to do.
#54 kudu
kudu
  • 1,479 posts
  • Car:LH SL/R 5000
Posted 26 October 2025 - 04:47 PM
Thanks to the previous tips... Here she is with all the metal work done and I'm a coat of epoxy.
Attached File  received_4356716431213912.jpeg   129.04K   0 downloads
Attached File  received_1592151328581588.jpeg   92.8K   0 downloads
Attached File  received_823764153345118.jpeg   154.7K   0 downloads
Attached File  received_1496651381603299.jpeg   145K   0 downloads
Attached File  received_1035507792002171.jpeg   105.15K   0 downloads
#55 kudu
kudu
  • 1,479 posts
  • Car:LH SL/R 5000
Posted 26 October 2025 - 04:55 PM
And here are a few engine pictures. It's the original engine. I could have stick it under the bench and used a Modern engine. But I thought where is the fun in that.
So it got the full check and work over to make sure there were no issues. Then she got stuffed full of nice new parts. Roller rockers, screw in studs, heads ported, nice cam etc etc etc. I'm really keen to see it on the dyno!
Attached File  received_704061916044889.jpeg   59.97K   0 downloads
Attached File  received_1573065150243583.jpeg   49.54K   0 downloads
Attached File  received_803371132317508.jpeg   113.01K   1 downloads
Attached File  received_2191202531287204.jpeg   140.36K   0 downloads
Attached File  received_1860834254551508.jpeg   61.12K   0 downloads
#56 Shiney005
  • 9,970 posts
Posted 28 October 2025 - 12:47 PM
Was the engine number machined off?
#57 kudu
kudu
  • 1,479 posts
  • Car:LH SL/R 5000
Posted 28 October 2025 - 03:22 PM
LOL.... No!.. I was most worried about that. I even went into the machine shop when the work was being done just to stress the importance of this. So they set up the heads offset in the machine so the edge of the planer did not touch the number. Although the main important bit was I didn't want them to touch was the HT part of the stamp, because as you may or may not know over here the engine numbers are not recorded against the car like in OZ, so the number itself does not really mean to much. Unlike in OZ where the numbers are recorded and important. I only learnt this recently as I asked someone why you guys in OZ kept covering the engine numbers in photos etc.
Edited by kudu, 28 October 2025 - 03:23 PM.
#58 kudu
kudu
  • 1,479 posts
  • Car:LH SL/R 5000
Posted 07 November 2025 - 02:54 PM
Checked in on the old girl at the workshop... She's coming along nicely. And I'm told I'll have it back before Christmas!... I can't wait!
Attached File  Messenger_creation_A467D53D-00BD-4632-964B-27A7DE3F1A83.jpeg   150.17K   1 downloads
