A9X Electric Fan - info / pics?
56 replies to this topic
#51 308 Sunbird
308 Sunbird
  • 976 posts
  • Name:Stuart
Posted 17 June 2022 - 09:09 PM
Yep that would be great if possible.  :spoton:
#52 Shiney005
Posted 18 June 2022 - 08:07 AM
Apart from the dipper switch and associated relay, what would the difference be between pre ADR LX and LH?
#53 hanra
Posted 18 June 2022 - 08:40 AM
When did the double terminal brake fail switch come about?
#54 Shiney005
Posted 18 June 2022 - 08:59 AM
This 9th month 1977 SL/R has it, as did all A9X's.  By 1983, the ADR had been amended to the car only needing one light again by the looks. I can't actually find if the two lights were an ADR requirement.
Attached File  Capture18.JPG   82.1K   1 downloads
Attached File  Screenshot 2022-06-18 065633.png   200.71K   0 downloads
Edited by Shiney005, 18 June 2022 - 08:59 AM.
#55 Dr Terry
Dr Terry
  • 3,359 posts
Posted 18 June 2022 - 11:15 AM
ALL LX Toranas got the column dipper switch (apart from a few prototype/mules).
The main difference between pre-ADR27a & ADR27a LXs is the under bonnet wiring for the various added anti-pollution devices, as well as the Tri-matic kickdown. In Garth's diagram you can see this in the box on the left hand side. Having 2 different circuit diagrams (one for early & one for late) would make it simpler.
This plus the ADR31 brake fail change (3/77), makes the early LX very much different to later 77 models.
Dr Terry
#56 Shiney005
Posted 18 June 2022 - 02:14 PM
What I was getting at, was wouldn't the pre ADR27A LX be very similar to the LH diagram?
#57 Dr Terry
Dr Terry
  • 3,359 posts
Posted 18 June 2022 - 06:30 PM
Sorry, but I misread your post.
You're basically correct, in that there are more differences between early & late LX, then there is between LH & early LX.
Having said that, it is a bit more than just a switch. The 5-pin relay is in the engine bay, while the single switch itself is at the top of the steering column, meaning quite a few changes to the harness layout.
Dr Terry
