Adam’s LJ restomod
78 replies to this topic
#51 Indy Orange
Indy Orange
  • 2,987 posts
Posted 16 September 2023 - 11:28 PM
Paint looks great Adam great effort.
#52 4dabush
4dabush
  • 241 posts
  • Name:Adam
  • Car:73 LJ S
Posted 06 November 2024 - 05:21 PM
So, it has been a LONG time between posts.... over a year. Its been busy on the personal front and Brad can probably attest that Cairns has had a wet season that has lasted about 18 months. It seems every weekend was raining and getting a painted shell out the way so I could continue doing bits and pieces was really hard.
I took a week off last week to make a dent in reassembly, and of course the first 2 days rained, and 33/34 degrees, no wind and about 90% humidity... the rest of the week was better.
Photo heavy coming up - a years worth of updates:
installing rubbers in door tops - what a sh!t of a job. Thanks to Marty and other forum members.  The inner belts need the clips stretched a little to go over the leather ( or vinyl) and THEN roll the inner felt into the clips.  Took 2 weekends to work out how to do a 20 second job, once you know. Outers was the throw the clips away and polyurethane sealer to glue them on. i did make the tool and try hard, but the Rare's clips dont play nice with the Rare's door top replacement patch panel.
Attached File  IMG_1187.JPG   287.17K   4 downloads
We have glass
Attached File  IMG_4227.JPG   337.13K   2 downloads
Sound deadened
Attached File  IMG_5445.JPG   341.58K   4 downloads
Wasnt happy with the location  of the rear retractable seat belt body so new seat belt anchors inboard by 20mm or so.
Attached File  REAR SEAT BELT ANCHORS (2).JPG   617.9K   3 downloads
#53 4dabush
4dabush
  • 241 posts
  • Name:Adam
  • Car:73 LJ S
Posted 06 November 2024 - 05:45 PM
Motor and Box.  And Air conditioning and alternator.
After struggling with the the T5 rebuild - I sent it off to Mal Wood to check my work and to properly install the steel cluster retainer that needs exactly the right shims, which I simply don't have.
A few weeks later in August, my motor arrived back from JB Automotive in Ayr.   It took a long time, but I wasnt in that much of a rush.  Sticking with the restomod theme - its still running the bunch of banana's and standard filter box and throttle body.  My engineer wouldnt let me go bigger than 304. (well, rebore was ok)
Quick Motor spec.
VS 304 block  .20 over, decked and tunnel bored
Bronze lifter bore conversion and oil gallery modded
Full balance of rotating assembly
Crane cams 888251  226/230 with 110LSA
Edelbrock heads stock out the box
10.4 compression
VT dizzy
Haltech 2500
Test fit below for the 100th time.  Now to set up alternator and AC.
Attached File  IMG_5605.JPG   413.38K   2 downloads
JB's ran it in on the dyno, so its now a bolt in.  Its a pretty healthy motor, 350hp/410lfbt  or 260kw/555Nm, nice fat flat torque curve which is what I wanted.
Attached File  GOWLETT DYNO SHEET(1)2.pdf   672.36K   4 downloads
Made my own alternator bracket to tuck in tight under the throttle body.  Couldn't use the normal drivers side one as the VS commodore AC bracket and pump fits and clears perfectly!
Attached File  IMG_5704.JPG   412.01K   3 downloads
#54 4dabush
4dabush
  • 241 posts
  • Name:Adam
  • Car:73 LJ S
Posted 06 November 2024 - 05:58 PM
Next was  doing the stainless steel trims
Had roof racks of course!
Attached File  IMG_5640.JPG   590.95K   2 downloads
Gentle dollying.  I used an old plastic breadboard as it was very close to the gutter curve, so chopped off a couple of bits to use as different shaped dollies.  I also had a hammer I had cut in half for getting inside the doors. This was perfect has it had nearly no weight.  I did spend an hour or so sanding its face dead smooth before taking it to the stainless.
Attached File  IMG_5642.JPG   592.12K   3 downloads
Finished  and fitted... not perfect, but better than many.
Attached File  IMG_5644.JPG   310.92K   2 downloads
Attached File  IMG_5645.JPG   280.61K   3 downloads
#55 4dabush
4dabush
  • 241 posts
  • Name:Adam
  • Car:73 LJ S
Posted 06 November 2024 - 06:07 PM
Heater box and Wipers
Attached File  IMG_5709.JPG   400.93K   4 downloads
Hoodlining (which is out again as it wouldn't uncrease.  Steamed and ironed and its probably in this weekend
Attached File  IMG_5739.JPG   296.34K   3 downloads
Rear parcel shelf, which was all done with the belt braces
Attached File  IMG_5741.JPG   341.03K   3 downloads
Rebuilt and painted column.  And now Peter Nash is doing ones for little Torries with V8's that look AMAZING, billet bottom bearings, better uni's ... oh well...
Attached File  IMG_5817.JPG   632.57K   2 downloads
#56 4dabush
4dabush
  • 241 posts
  • Name:Adam
  • Car:73 LJ S
Posted 06 November 2024 - 06:13 PM
Mal Wood Hydraulic Clutch in ... bit of stuffing around and filing, but got there without too much drama.
Attached File  IMG_5818.JPG   476.51K   3 downloads
Buttoning up the chassis kit properly and for the final time
Attached File  IMG_5824.JPG   599.66K   2 downloads
Handbrake brackets for VS Commodore rear discs,  Calipers are swapped to front so its a hybrid left to right swap.
Attached File  IMG_5852.JPG   526.89K   4 downloads
#57 4dabush
4dabush
  • 241 posts
  • Name:Adam
  • Car:73 LJ S
Posted 06 November 2024 - 06:20 PM
K Frame assembly with homemade spring compressor - worked a treat!
Attached File  IMG_5866.JPG   458.94K   4 downloads
Attached File  IMG_5875.JPG   483.45K   7 downloads
Wiring starting... Haltech wiring is huge...good thing I'm not looking for the concealed look! The wooden thing was to give the sparky a template for the underdash shelf I'll make ti hide everything and give him real estate for the Haltech and all the fuses and relays. It will hide the AC unit that is already tucked up in there. I'll piano hing it at the rear, pick up the original parcel shelf screw holes under the glove box and 2 screws, can drop down to access everything...and still have a working glove box.
Attached File  IMG_5869.JPG   495.42K   2 downloads
Attached File  IMG_5898.JPG   466.06K   2 downloads
#58 4dabush
4dabush
  • 241 posts
  • Name:Adam
  • Car:73 LJ S
Posted 06 November 2024 - 06:27 PM
Ok  - this is what you are all here for...
Last week has been big...
Getting exciting....
Attached File  IMG_5876.JPG   496.49K   3 downloads
more exciting...more nervous... this was all on my own, not even my wife to keep an eye on things....
Attached File  IMG_5883.JPG   474.31K   4 downloads
Edited by 4dabush, 06 November 2024 - 06:28 PM.
#59 4dabush
4dabush
  • 241 posts
  • Name:Adam
  • Car:73 LJ S
Posted 06 November 2024 - 06:32 PM
TADDA
Attached File  IMG_5894.JPG   427.28K   4 downloads
Attached File  IMG_5895.JPG   396.92K   5 downloads
Attached File  IMG_5897.JPG   360.59K   2 downloads
still a LOOONG way to go, but now it feels like there is a light at the end of the tunnel.
Wheels are 16 x 7 (28p) and 16 x 8 (15p).  Tyres are babies, 195/50/16 and 215/45/16.   Adjustable trailing arms are nearly all the way forwards, they could have had another 10mm extra forward moverment but it all clears
#60 Bruiser
Bruiser
  • 881 posts
  • Name:Bruce
Posted 06 November 2024 - 06:34 PM
Job well done
That’s gonna be magic when it’s rolling
#61 gtrboyy
Posted 06 November 2024 - 07:44 PM
Never rolled eng/trans in under baby torrie or commodore...might have to try it one day.
That Mal Woods kit looks like it gives more room for column to come over always wondered if could hide reservoir under ashtray area.
Did rear calipers hit shock absorbers hence putting them at front?
Looks nice lots of progress.
#62 4dabush
4dabush
  • 241 posts
  • Name:Adam
  • Car:73 LJ S
Posted 06 November 2024 - 08:08 PM
You’ll have to try it one day… me, 3 trolley jacks of different sizes, 2 sets of axle stands, various blocks of wood, and a million burpee’s jumping up and down to check alignments and clearances. Took about 90 minutes…would have halved that with another pair of eyes.
Mal Woods kit wouldn’t say gives more room inside, certainly not less. The single braided line to the gearbox does and meant I could cut off the clutch cable boss off the bell housing. THAT gives heaps more room.
I’ll post up the brakes on the weekend. The backing plates are deleted, but the brake hose retainer drilled out and is reused.
the axle retaining plate/cup goes left to right to bring the calipers in front of the diff. The hand brake assembly stays right on right, left on left so it pulls in the normal direction. You have to completely make a new handbrake cable retainer.  This and the brake line retainer were welded to some 3mm plate and new holes tapped into the axle retaining cup. I think I picked up 2 of the holes from the backing plate, just drilled and tapped them bigger. Swap calipers so the bleed nipple is on top still and it’s done. As the calipers are now in front of the diff, there is no clash with anything…misses the coils by 30mm or so.  Standard Commy hoses.  I’ll probably do a custom set of handbrake cables but there are some old posts on here showing the idea of the hand brake retainer and they used a commodore wagon rear cable, mated to modded Lc Lj handbrake cables at the handbrake with the Torry shorts attached to a Commy C boss thingy that centres on the cable to pull evenly.
Edited by 4dabush, 06 November 2024 - 08:16 PM.
#63 RallyRed
A credit to you mate...
#64 Ice
Posted 06 November 2024 - 08:38 PM
Looks great Adam top job mate
2 door Torana V8 injected just perfect  :)
#65 SmacT
  • 1,026 posts
Posted 07 November 2024 - 09:08 AM
That's awesome. That engine spec is perfect for your car I reckon, torquey and fun - unless you are drag racing it every week, that's plenty of grunt for the road. I laughed at the burpees reference - I wonder how many burpee equivalents we all do building these things without a hoist? Many....
Keep going!
#66 gtrboyy
Posted 07 November 2024 - 11:16 AM
Oh ok springs get in the way.
Yeah mine has whole vs ute diff narrowed down but car was mini tubbed + coilovers...used commodore cables but got shortened or new ends but did have to go with a toyota corolla handbrake as torrie touched 3 inch tailshaft when down or when on throttle cant remember.
We had dellows kit actually narrowed pedal + welded rod in it for strength just to move column over bit more even ground down block to sit flush with getrag gearbox but that Mal Wood setup looks like more room if can hide reservoir & still work fine tempted to put efi 304/getrag setup back in gtr again.
Kind of like where alternator sits looking at it again kind of hidden under engine cover/throttle body & airbox etc
#67 stevemc32
stevemc32
  • 324 posts
  • Name:Steve
  • Car:LJ 4 Door
Posted 07 November 2024 - 01:26 PM
That's certainly an update and a half.  Looks great Adam, top stuff!
#68 4dabush
4dabush
  • 241 posts
  • Name:Adam
  • Car:73 LJ S
Posted 11 November 2024 - 05:29 PM
As promised,
here are some better photos of the VS Commodore brakes in the car.
As mentioned, the caliper/axle retainer is swapped Left to Right, but handbrake stays right on the right, left on the left, handbrake still pulls forwards.
Caliper is then at the front. Calipers swap left to right to bleed nipple is still at the top.
Mines on a 7mm shorter per side than stock Torry -  9 inch.
Rear shocks in standard location.
Brake line retainer tab drilled out of backing plate and made a bracket to bolt to caliper/axle retainer  (I think they were swapped l to r to make the hoses sit nicely in the retainer)
In these photo's the brake line is not yet done up tight as I am yet to blow out the brake lines and fit pads and the brake hose retaining clips.
Just a warning, there is bugger all between the bottom of the shock and the caliper/axle retainer, so to install the shock was install the washer and 1 rubber, slide the shock on the shock bolt on diff, then maneuver it to the upright position, then fit the remaining rubber, washer and cone nut, then the top retainers, rubbers and nuts.  If you have a shock with a 1 piece rubber, (if there is such a beast) you'd have to have it on before fitting the caliper/axle retainer and buttoning up the axles...that would be a PITA.
Brake line retainer
Attached File  IMG_5903.JPG   303.89K   6 downloads
hand brake cable connected and showing bracket
Attached File  IMG_5904.JPG   319.91K   4 downloads
View from the front
Attached File  IMG_5907.JPG   318.38K   4 downloads
#69 Heath
Posted 11 November 2024 - 05:45 PM
What a fantastic update. This is getting some really nice work!
#70 4dabush
4dabush
  • 241 posts
  • Name:Adam
  • Car:73 LJ S
Posted 03 January 2025 - 01:58 PM
Still plodding along.  Been messy over Chrissy, road trip with my Daughter from Brissy to Cairns, couple of birthdays, wet or stinking hot and humid weather.  Tail-shaft is in, custom handbrake cables are in, wiring is about 2/3rds, suspension is all torqued up and dodgy stringline wheel alignment since its been sitting under weight for about 6 weeks. Ive got the back screen in (except the corner blocks) bit of fiddling to do there and letting our summer heat ooze mastic out !! Seatbelts are in and working 100% and started getting the interior together.  Sparky asked me to leave the front out for the time being - which is fair enough.
Got my NOS GTS mirrors on, and found that the drivers one is locked in place - bolt is firmly seized  - probably should have checked when i bought them in 1986 :mellow:. Luckily its 95% of the way to the highest setting.  Rad and Condenser are in and fit nice.  Decided on battery in the engine bay, so popped a side terminal Optima on the drivers site - looks ok, and will be quite balanced with the factory VS Commodore airbox on the passenger side.  Leaves some boot space too.
Question? I'm intending to leave the mirrors satin. Has anyone out there left their GTS mirrors raw? How did/do they hold up?   There are plenty of cars with plastic unpainted mirrors, so before I start covering them with Armoural and make painting harder for myself, whats the consensus?  Is raw just being slack?
The last shot i got a chance to roll it out the shed...
Attached File  IMG_6216.JPG   323.29K   8 downloads
Attached File  IMG_6217.JPG   243.58K   3 downloads
Attached File  IMG_6239.JPG   191.98K   4 downloads
Attached File  IMG_6240.JPG   337.23K   4 downloads
Attached File  IMG_6243.JPG   505.9K   3 downloads
Edited by 4dabush, 03 January 2025 - 02:00 PM.
#71 FLY_LX
FLY_LX
  • 198 posts
  • Car:LX sedan
Posted 03 January 2025 - 06:58 PM
awesome.
#72 claysummers
Posted 03 January 2025 - 10:00 PM
Wow. Smik, Adam. The mirrors seem to need to be coordinated with something else on the exterior to my eye.
#73 Ice
Posted 03 January 2025 - 10:42 PM
Looking good Adam
Imho i would paint the mirrors satin black they need something on them
Love the trim colour
#74 4dabush
4dabush
  • 241 posts
  • Name:Adam
  • Car:73 LJ S
Posted 27 December 2025 - 09:20 PM
It’s been a long year… lots of jobs done 2 or 3 times . Lots of home visits by my auto electrician …. It runs. Not happily yet but runs - first time in over 35 years…hope the video
works…the compressing software made its sound a little odd
Attached File  FullSizeRender-compressed.mov   1.53MB   30 downloadsAttached File  FullSizeRender-compressed.mov   1.53MB   30 downloads
#75 tuxedo123
tuxedo123
  • 31 posts
  • Name:Dan
  • Car:77 LX 4-door
Posted 28 December 2025 - 06:21 AM
Well done Adam, that’s a major milestone to achieve. The car looks amazing. I might have to go back through the whole thread and have a read!
