The Vk Bitsa Bombadore
94 replies to this topic
#51 gtrboyy
Posted 26 May 2024 - 08:33 PM
Torana wiring is so easy compared to that lot.
Yeah old holden wiring 10 times easier & simpler.
Vk wiring one of the worst some wires same colour but different purposes is very annoying so have to trace them back to be sure wtf it is for...atleast vn they started using trace colours.
Found pdf of factory manual got it saved on phone to help reference wires & plugs,specs + hidden screws etc for dasg.
#52 yel327
Posted 27 May 2024 - 08:31 AM
The EFI wiring is simple in a Commodore, you can even use the VN-VS battery and power harness. There is only a few wires to connect up and most of it is fuel pump and tank sensor related. It gets really messy when you try and integrate it to make it nice and neat, ends up looking like the above pictures! Looks heaps better once done though.
#53 gtrboyy
Posted 29 May 2024 - 07:23 PM
Not worried about efi wiring just time consuming when want it all hidden yet easy to work on....car will also get carb'd 308 junk motor with nitrous.
Fusebox was already melted & someone been in there before bodged it up so me being sucker that will work on it it would annoy me to death not to make it neater & easier to work on...hidden wiring is from being reading too many 90's Streetmachine mag as a kid.
Although am thinking of ditching heated rear window module setup if cant find simpler way to wire it up also probably change to lpg tachiometric relay....the way factory did it going in circles hurts my head lol
Edited by gtrboyy, 29 May 2024 - 07:26 PM.
#54 gtrboyy
Posted 24 July 2024 - 03:06 AM
Struggler has junker 308 or GEM 308 as he calls together should get dyno tuned next few weeks.
Also sent pic of big banger 4 bolt bottom end
Edited by gtrboyy, 24 July 2024 - 03:07 AM.
#55 Shiney005
Posted 25 July 2024 - 11:07 AM
I would have said that was impressive, except that I saw the bottom end of a standard 1VD (Diesel V8) Landcruiser motor yesterday. This particular example had a broken in half crankshaft, and still it held together.
Attached File  Screenshot 2024-07-25 090452.png   834.98K   4 downloads
#56 Rockoz
Posted 25 July 2024 - 02:00 PM
Probably the most impressive crank failure I have seen was on a V16 Cat engine running a 1MW generator.
Well actually, the generator was running the engine.
The engine had shut down but the generator didnt disconnect, and it kept the engine, or the half that was still connected to the flywheel spinning.
From memory it ran for a couple hours after failure.
Lots of silvery stuff in the sump when they pulled it down.
#57 Bruiser
Bruiser
  • 881 posts
  • Name:Bruce
Posted 25 July 2024 - 06:17 PM
God knows how you can handle two projects of this size
I flounder with one much smaller one
You are a machine
I am digging what you’ve achieved with the commodore too
had to check your pictures against the tubs in my boot to compare what you have done.
Looks factory, alright
Which one will be on the road first??
#58 gtrboyy
Posted 25 July 2024 - 11:09 PM
You are a machine
The vk will hit the road first...if went with first planned tightarse setup of factory parts like stock 28spline vl borgwarner & efi 304/4l60e it would have been ready for rego BUT got a bit carried away with it
My cousin aka panelbeater is responsible for all the panel work on lc gtr & rust work + split tubs with vk....struggler is handling engine builds & I"ll be finishing off everything else in whenever get little bit of free time.
The builds were supposed to be spread apart at a steady pace but nothing goes to plan...better than cars sitting for years with no progress getting stuffed around by workshops which is why I was stuck for so long.
Also made a promise if I don't have one final good go at getting these cars driving again I'd sell them all off & walk away from cars
#59 gtrboyy
Posted 14 August 2024 - 03:17 PM
Update from struggler with GEM engines junker should achieve what we want especially with 150 shot.
Low 9's cr,60 thou dished casies,308ci,vt heads,chinawinder dyno'd with 650dp...smallest solid in crow cam catalogue
Reason why compression so low is I didn't want heads shaved crazy amount and bottom end 60 thou over hence budget junker theme.Attached File  image000002(11).jpg   289.53K   4 downloadsAttached File  image000001(16).jpg   220.13K   3 downloads
#60 gtrboyy
Posted 14 August 2024 - 05:11 PM
3.5k stally recommended.Attached File  561f1dbc-002a-438c-b47b-9602855a8af0.jpg   352.25K   1 downloads
#61 RallyRed
Posted 14 August 2024 - 08:08 PM
That'll do nicely
#62 gtrboyy
Posted 29 September 2024 - 05:20 PM
Mucking around with vk put 14's on for a giggle.
255/60/15 vs 215/65/14
#63 claysummers
Posted 29 September 2024 - 08:38 PM
They look perfect
#64 gtrboyy
Posted 05 November 2024 - 02:14 PM
Not much to show one of 14 inch stockies valve stem split open so slapped aero rim on to roll it out...looks weird with tiny 205 tyre when 14"s had 215/65 & chasers had 255/60/15.
Mucking around with wiring roughly routing it out atleast half wiring off the floor also reluctantly drilled first hole into vk.
#65 Shiney005
Posted 06 November 2024 - 11:04 AM
Are the 15 inch Aero's narrower than the 16 inch?
Attached File  2 VK Group A small.jpg   110.16K   9 downloads
#66 gtrboyy
Posted 06 November 2024 - 02:31 PM
Same width & 42 or 43p offset.
Easy to forget heavily modified with split tubs etc
Diff is shortened 25mm each side & set up with heaps wider tyres than standard 215/65/14 & 255/60/15 so now looks weird with 205 tyres lol
Wiring is bit tedious but will be easier to work on when finished although looks like a nightmare trying to work out how to get battery cable to starter as battery will be in boot.
#67 gtrboyy
Posted 06 December 2024 - 01:48 PM
Still mucking around with wiring & trying to keep everything hidden yet functional.
Bought some parts but progress is slow either weather or free time.
General theme of the Bay..
#68 SHEEL
SHEEL
  • 353 posts
  • Name:Daniel
Posted 09 December 2024 - 10:43 AM
Engine bay looks TIDY!!! oooofft!!
#69 SmacT
  • 1,026 posts
Posted 12 December 2024 - 01:23 PM
Wow - delating that ugly fusebox is a big change for the better in the engine bay, nice one. Keep going!
#70 gtrboyy
Posted 26 April 2025 - 12:05 AM
Not had much time for this been mucking around with vp 5ltr ute fitting it up with parts cluttering garage.
Vk got jacked up & put on jackstands fuel tank getting modified with baffles,billet intank set up & drain bolt...hopefully will get rear disc conversion sorted by time tank comes back in few weeks.
#71 Shiney005
Posted 26 April 2025 - 09:51 AM
Is the VP a Maloo???
#72 gtrboyy
Posted 27 April 2025 - 01:55 AM
8 or 9 years ago bought stock base model benchseat vp v6 t5 for $900..probably paid too much for it.
Needed ute for house renovation we were doing & being ugly duckling vp ot would get sold or sent to scrappers afterward BUT I ended up liking the crappy thing rebuilt it on footpath & dailies for few years then did v8 conversion & whole bunch of mods nobody notice as kept it looking stock & crappy on outside.
#73 gtrboyy
Posted 03 May 2025 - 08:22 PM
Slapped 15 inch Aero rims on it to clear space in garage...kind of looks OK.
Prefer executive hubcaps but need to attach to 15 inch chasers.
#74 Shiney005
Posted 06 May 2025 - 11:37 AM
The Aero's will give it street cred while still having it look grandad spec.
#75 gtrboyy
Posted 21 May 2025 - 05:22 PM
Couple days ago thought I was going to pick up the 2 modified commodore fuel tanks...not been touched dude reckons will start them this week but somehow doubt that.
Kind of put me in half arsed cbf'd bad mood to touch the cars on my week off.
Did do something rather silly took ute for drive on wet roads...less dangerous on wet road with lsd but does do weird things never know if it will hook,wheel hop or just slide out as expected.
Edited by gtrboyy, 21 May 2025 - 05:26 PM.
