77 SL Hatch to SS 5.0L Tribute
81 replies to this topic
#26 yel327
Posted 14 August 2023 - 02:45 PM
I’m not sure. It may be an R series. Not sure what the side plate is, might be for an oddball application on a 4x4 and the case has been used on a rebuild?
#27 yel327
Posted 14 August 2023 - 03:08 PM
I looked further. I reckon the case if off a G series, probably G53. They had a shifting arrangement bolted onto the side. It has had its tail housing changed to suit a traditional car.
Maybe talk to CRS and see if they can tell you what they are like.
http://tcase.rsgear....les/2001_06.pdf
https://autoparts.be...ies/PA01487079/
#28 yel327
Posted 14 August 2023 - 07:08 PM
Here is another option. Probably not what you want for a cruiser, more for a 350hp fun car. But it is straight from a Torana. You’ll never break it with a 308. Most likely an M21 box so 2.20:1 1st gear.
I can’t tell if it’s multi fit or not, but it’s drilled for both patterns up the top.
http://www.gumtree.c...&utm_source=sms
#29 kimbo
kimbo
  • 110 posts
  • Name:Kim
  • Car:LX Torana Hatch (looking 4 1)
Posted 14 August 2023 - 11:31 PM
Yep ...I think you are onto something there.  The funny little molding threw me as I could fine nothing like it.
#30 yel327
Posted 15 August 2023 - 06:18 AM
Saw this too. Not sure if priced well or expensive. If you did buy it make sure it comes with proof of who modified it as Engineer will need that most likely.
#31 rexy
  • 3,834 posts
Posted 15 August 2023 - 09:17 AM
Geez 4K for a BW second hand is a bit rich.
The W series supra boxes are good for about 300lbft of torque. They are very nice to drive compared to any of the Aussie or US boxes and fit in the LH/LX tunnel. There are multiple shifter options and most I have seen come up through the original shifter hole.
#32 Shiney005
Posted 15 August 2023 - 09:19 AM
I wouldn't mind that diff myself, but sounds expensive to me. Edit. Rexy beat me to it.
Edited by Shiney005, 15 August 2023 - 09:20 AM.
#33 yel327
Posted 15 August 2023 - 01:35 PM
I thought it was a bit dear too but read what it has.
New rotors drilled to HQ.
New billet axles.
New seals and bearings.
Refurbed calipers.
New Tru track type LSD.
Handbrake cables to suit Torana.
All that on top of the housing mods and the labour to set it up.
#34 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 15 August 2023 - 03:32 PM
New billet axles.
Refurbed calipers.
Yes I have been watching this one.  I am keen at about 4K I think
#35 rexy
  • 3,834 posts
Posted 15 August 2023 - 04:26 PM
For that sort of money I would be buying a F**D 9 inch.
#36 yel327
Posted 15 August 2023 - 04:34 PM
Whatever you buy make sure you get full details of who built it (as in who did the welding) and what the brake components are.
#37 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 15 August 2023 - 10:10 PM
It was built by Final Drive who are pretty well regarded as experts here in WA.
#38 yel327
Posted 16 August 2023 - 06:49 PM
I know this isn’t the way you are going, but if your car was an early LX it would have been a good package.
#39 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 16 August 2023 - 07:32 PM
Thanks mate :-)   Yeah not quite right but appreciate you looking out for me :-)
#40 yel327
Posted 16 August 2023 - 07:57 PM
I wasn’t! I was looking for a SBC for a mate, but that is no good for him as it is a manual that won’t fit in a HT Holden.
#41 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 21 August 2023 - 07:20 PM
I am toying about with fitting a T5 behind the 308.  I came across this on Market place.
https://www.facebook...62-449dbc786f07
Basically its out of a FG Falcon and is described as perfect working order.  I have been speaking to the owner on messenger.   Anyhow I know nothing about Fords.  Is this the type of box that folk use for Torana's?  I know that T5s out of a Holden V8 generally need to Mustang housing to fit.   Will this also need a similar housing?  Any comments greatly welcome :-)
#42 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 21 August 2023 - 07:29 PM
Actually ...the guy selling this is full of shit.  T5s weren't available in the FG.  Waiting for more info from him LOL
#43 Shiney005
Posted 26 August 2023 - 09:22 AM
FG's used the Tremec TR6060. Same box as the C7 Corvette and Dodge Challenger. It can handle a heap of torque, but might be a bit big to fit into a Torana tunnel? I'm sure there will be a thread on it in here somewhere.
#44 Heath
Posted 26 August 2023 - 09:00 PM
Plenty of T56's, T56 Magnums, and TR6060's in Toranas, but yes, they need a tunnel.
And who needs 6 gears in a Torana, anyway? A grunty V8 in a ~1,400kg car just needs four ratios for driving and an overdrive for highway use.
Go with a TKX if you don't have much luck with second hand boxes. Certainly a 6cyl Falcon T5 was the go but I don't know if they're becoming less easy to find or anything...
#45 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 04 October 2023 - 08:56 PM
So finally managed to find a T5. Lucked out as it's a fully reconned box where the owner failed to pick it up or pay for it after 2 years. Comes with warranty that doesn't kick in until the car gets regoed. Paid $1500 including the short shifter Does anyone recognise the 97DA tag as to which model Ford it came out of?Attached File  20231004_171119.jpg   108.34K   5 downloadsAttached File  20231004_124215.jpg   63.76K   5 downloadsAttached File  20231004_124151.jpg   72.05K   5 downloads
Sent from my SM-G988B using Tapatalk
#46 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 18 March 2024 - 07:48 PM
Things are moving. Panel and paint completed!!! My granddaughter said Granddads Piranah is coming today LOL
Reassembly begins :-)Attached File  20240316_175928.jpg   70.53K   5 downloadsAttached File  20240316_175910.jpg   95.56K   5 downloadsAttached File  20240316_175836.jpg   106.99K   7 downloadsAttached File  20240316_171650.jpg   122.02K   7 downloadsAttached File  20240316_175846.jpg   80.97K   6 downloads
#47 Ice
Posted 18 March 2024 - 09:58 PM
Great colour combo
#48 kimbo
kimbo
  • 110 posts
  • Name:Kim
Posted 18 March 2024 - 10:45 PM
Great colour combo
Thanks mate. I laboured over the satin black but pretty happy with it so fae :-)
#49 SmacT
  • 1,026 posts
Posted 19 March 2024 - 01:25 PM
Torana/Pirana - it works! Ha ha. Looks great.
#50 Shiney005
Posted 24 March 2024 - 11:08 AM
How percentage of flattener went into the paint?  It looks pretty well spot on.
