SS hatch tidy up
98 replies to this topic
#51 Shiney005
Posted 23 November 2024 - 11:37 AM
I'd say the last panel beater to work on it knew what he was doing.
#52 rexy
  • 3,834 posts
Posted 26 November 2024 - 01:51 PM
The roof is coming along.
Attached File  FullSizeRender.jpeg   108.99K   14 downloads
Attached File  FullSizeRender.jpeg   149.68K   11 downloads
There are a couple of temporary braces underneath to help give it shape. Once its tacked in the finessing begins.
These turned up today
Attached File  FullSizeRender.jpeg   157.76K   7 downloads
The hinges are shagged and last time it was apart someone put bolts in to replace the worn pins. Repairable like all things made of metal but the new ones are cheap enough to not bother.
#53 rexy
  • 3,834 posts
Posted 30 November 2024 - 04:02 PM
More roof progress
Attached File  IMG_4621.jpeg   108.19K   5 downloads
Attached File  IMG_4616.jpeg   142.6K   6 downloads
Attached File  IMG_4609.jpeg   125.35K   5 downloads
Lots of adjustable braces. Slowly slowly.
#54 LCK186
LCK186
  • 412 posts
  • Car:71 CK
Posted 30 November 2024 - 07:08 PM
Rexy hi, the roof is looking fantastic, are you doing the welding yourself or is it in a panel shop, never the less it looks great, i have a friend with the same hole in his torana and would love to patch up the same way you have done.
#55 rexy
  • 3,834 posts
Posted 01 December 2024 - 09:44 AM
I have an old Croatian guy doing it. His welding is much better than mine. He also has a good eye for detail and while he's not the quickest the result will be very good.
Attached File  IMG_8466.jpeg   117.17K   5 downloads
He did this one for me a while ago.
#56 LCK186
LCK186
  • 412 posts
  • Car:71 CK
Posted 01 December 2024 - 11:50 AM
Rexy hi does he want to do another hole, the section is already in place to weld, he lives in the sunshine area thanks
#57 rexy
  • 3,834 posts
Posted 01 December 2024 - 10:37 PM
If he can get the car to Keysborough Im sure he would do the job.
#58 rexy
  • 3,834 posts
Posted 05 December 2024 - 07:44 PM
In between letting welds cool off the new rear spoiler is being fettled.
Attached File  IMG_4647.jpeg   138.82K   7 downloads
Attached File  IMG_4644.jpeg   113.02K   6 downloads
#59 hanra
Posted 05 December 2024 - 08:47 PM
Sounds like something the project binky guys would say.
#60 Heath
Posted 09 December 2024 - 03:00 PM
Looks like good progress. :)
Those spoilers can be quite a pain. Very noticeable though, so worth getting them close.
#61 rexy
  • 3,834 posts
Posted 23 February 2025 - 07:21 PM
Its funny how at times there seems to be a lot of progress and then not so much….
There has been a lot of tedious looking work involved in bare metalling the shell. Lots of small areas needing welding around the hatch area on the body. Hardly worth taking pics of.
The nosecone was a lot rougher than expected once it was stripped. It was cut and shut down the middle and I decided given the hours it would take to reuse I might as well buy a rare spares one.
Attached File  IMG_4857.jpeg   129.26K   5 downloads
The pic doesn’t show the true horror….
Attached File  IMG_5483.jpeg   131.83K   3 downloads
Not bad out of the box.
Attached File  IMG_5546.jpeg   181.14K   2 downloads
Attached File  IMG_5547.jpeg   106.75K   1 downloads
Attached File  IMG_5548.jpeg   122.28K   1 downloads
Fit is very close. It was $650 - should have bought it at the Summernats at 30% off.  Im sure I will get that back in saved labour costs.
#62 rexy
  • 3,834 posts
Posted 23 February 2025 - 07:38 PM
The hatch is pretty good although along with the rear quarters there is clear evidence of a serious crime.
Attached File  IMG_4854.jpeg   137.3K   1 downloads
It used to have a rear spoiler, now absent!
There were also odd marks on the inner upper on both sides, above the seal.
Attached File  IMG_5570.jpeg   128.17K   1 downloads
With a little digging these appeared.
Attached File  IMG_5571.jpeg   128.11K   3 downloads
I assume these are aeration ports to allow condensation out on warm days.
There is also a little bracket on one side only.
Attached File  IMG_5568.jpeg   135.96K   1 downloads
Anyone know what this is for?
#63 rexy
  • 3,834 posts
Posted 23 February 2025 - 07:55 PM
The passengers rear is the only sizeable rust repair so far.
Attached File  IMG_5317.jpeg   146.43K   1 downloads
Another $140 worth of rare spares steel added.
Attached File  IMG_5496.jpeg   157.84K   1 downloads
The fairly rough work cutting the guards has been tidied up
Attached File  IMG_5318.jpeg   142.02K   2 downloads
Attached File  IMG_5319.jpeg   177.22K   2 downloads
Lots of extra unnecessary holes from historical events welded up.
There are small screws in holes in the bottom of the sills just in front of the arch on both sides. On my other hatch the front of the rear flare is secured here so I presume they are not factory?
#64 rexy
  • 3,834 posts
Posted 23 February 2025 - 08:15 PM
And speaking of surprises…
Attached File  IMG_5495.jpeg   117.05K   4 downloads
The piece between the hinge openings didn't survive the wire wheel.
Sadly this replacement piece had to be made by hand - $5 worth of steel plus $700 labour. Ouch!
Attached File  IMG_5664.jpeg   35.07K   1 downloads
Looks good though.
#65 rexy
  • 3,834 posts
Posted 23 February 2025 - 08:27 PM
So it’s now in my favourite matte black.
Attached File  IMG_5660.jpeg   82.9K   1 downloads
Attached File  IMG_5569.jpeg   69.09K   1 downloads
Still a long way to go.
Its nice that so much of the car has original paint beneath the blue so most of the metal is being revealed for the first time in nearly 50 years.
Progressively collecting stuff for the finishing phase. Got discount mirrors and rubber kit at the Summernats. Headlining and carpets arrived.
Slowly slowly….
#66 LXCHEV
Posted 23 February 2025 - 09:57 PM
Awesome progress! That new front nosecone looks ace.
#67 76lxhatch
Posted 24 February 2025 - 03:53 AM
Light switch
#68 Shiney005
Posted 24 February 2025 - 08:12 AM
I can't be sure about the hatchbacks, but sedans don't have any screws anywhere in the bottom of the sills.  Are you putting a rear spoiler back on?
#69 SmacT
  • 1,026 posts
Posted 24 February 2025 - 10:56 AM
Nothing, nothing, nothing, then bang! Progress. Ha ha. Defo how it feels sometimes. Looks great, keep going.
#70 rexy
  • 3,834 posts
Posted 02 March 2025 - 01:16 PM
So the hatch has come up very well after final strip of the rest of the paint.
Attached File  IMG_5629.jpeg   193.32K   2 downloads
Attached File  IMG_5630.jpeg   143.54K   2 downloads
There were a couple of dents that had been filled with bog. The most impressive was in the drivers sill.
Attached File  image000001.jpeg   81.9K   2 downloads
A long way in and still digging…
Came up very nicely.
Attached File  IMG_5628.jpeg   126.29K   2 downloads
One little bit on the passengers side.
Attached File  IMG_5637.jpeg   135.87K   3 downloads
And it seems the metal work is done.
#71 rexy
  • 3,834 posts
Posted 08 March 2025 - 04:27 PM
So the wire wheel reveals all.
Attached File  IMG_5695.jpeg   168.01K   9 downloads
Attached File  IMG_5696.jpeg   112.97K   8 downloads
A little more welding required…
Smoothing started.
Attached File  IMG_5698.jpeg   130.36K   7 downloads
Attached File  IMG_5697.jpeg   132.63K   6 downloads
#72 Holdenbn74
Holdenbn74
  • 152 posts
  • Name:Brendan Nichol
  • Car:LH
Posted 12 March 2025 - 11:37 AM
Nice progress! Taking shape nicely 👌
#73 Hatchback13
Hatchback13
  • 193 posts
Posted 14 March 2025 - 09:30 PM
Enjoying the progress. Cheers
#74 rexy
  • 3,834 posts
Posted 26 May 2025 - 05:16 PM
Its been one of those boring periods where stuff happens without much wow factor.
Alignment and gaps. Stripping, sanding, epoxy. Scuffing, filling, sanding and more epoxy.
Bought new hinges from Resto Country as well as new bolts for the whole front panel work.
Attached File  IMG_6011.jpeg   142.29K   2 downloads
Attached File  IMG_6013.jpeg   119.32K   2 downloads
Attached File  IMG_5975.jpeg   160.93K   2 downloads
Then sanded again…
Attached File  IMG_6008.jpeg   123.29K   2 downloads
Back on the car for gapping with the new hinges.
Attached File  IMG_6140.jpeg   110.08K   2 downloads
#75 rexy
  • 3,834 posts
Posted 26 May 2025 - 05:21 PM
Getting there…
Attached File  IMG_6143.jpeg   120.1K   2 downloads
Attached File  IMG_6142.jpeg   129.21K   2 downloads
Attached File  IMG_6141.jpeg   160.07K   2 downloads
