Hole for reverse cabling to gearbox
LC GTR gearbox reverse wiring
10 replies to this topic
#1 dacastle
dacastle
  • 112 posts
  • Car:LC gtr
Posted 02 August 2025 - 04:32 PM
Can anyone help me as to where approx the hole was drilled for the wiring to the reverse switch on gearbox - I was thinking on side of transmission tunnel opposite switch location.
Things are moving at glacial pace but hopefully will start to pick up a bit. Thanks in advance
#2 yel327
  • 13,939 posts
Posted 02 August 2025 - 04:57 PM
This is what a Holden W body looks like (HQ-WB). Not sure if the Nuns had it in the same place though.
Attached File  HZ reverse switch wiring.jpg   166.62K   5 downloads
#3 sibhs
Posted 03 August 2025 - 02:25 PM
What Gearbox Dave? Two different positions for Opel and Aussie
#4 sibhs
Posted 03 August 2025 - 02:49 PM
Unpainted pic is for the Opel and Painted is Aussie
Attached File  IMG_2582.jpeg   72.88K   4 downloads
Attached File  IMG_2579.jpg   274.18K   8 downloads
#5 dacastle
dacastle
  • 112 posts
  • Car:LC gtr
Posted 03 August 2025 - 05:38 PM
It is an Aussie 4 speed - was originally an opel - are you able to give me approx. diameter of hole - guys who did paint and panel filled in lots of holes including some that didnt need to be filled
#6 rodomo
  • 18,080 posts
Posted 04 August 2025 - 08:59 PM
This is an LJ S. The hole size varies from 14-15mm? Maybe drilled on production line?
#7 yel327
  • 13,939 posts
Posted 05 August 2025 - 07:22 AM
Is it drilled or punched? I'd say it was possibly done in the body plant after electrostatic primer or early in the assembly plant. Same time the hole was cut for the shifter. If Pagewood and Dandenong look different to Acacia Ridge and Elizabeth that will give the answer. Is the shifter hole oxy cut like a W body?
It might be 9/16" regardless.
#8 sibhs
Posted 05 August 2025 - 08:42 PM
I got my measurements of this forum. Probably from RODOMO as above.
#9 rodomo
  • 18,080 posts
Posted 05 August 2025 - 09:13 PM
At a guess I'd say it was drilled but the drill bit bit in and stalled the drill (if that males sense?)  Car is a Brisbane build. Gear shift hole is pretty rough.
Edited by rodomo, 05 August 2025 - 09:13 PM.
#10 S pack
  • 15,795 posts
Posted 05 August 2025 - 09:52 PM
I lean towards the holes for LC& LJ console shift and reverse light harness were punched.
#11 dacastle
dacastle
  • 112 posts
  • Car:LC gtr
Posted 06 August 2025 - 05:12 PM
Thanks - perfect - that should do the trick
Also tagged with one or more of these keywords: LC GTR, gearbox reverse, wiring
