The Sally Report
1003 replies to this topic
#26 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 02 July 2019 - 07:48 PM
Marty,
You've got me curious about the reasoning behind replacing those springs. Was there a problem with how the mechanisms were working that indicated that they were worn out.
Sal,
Cleaning door parts etc definitely beats paint stripping and sand blasting, so don't despair about the "girly jobs ".
I was just thinking recently that we need a good build thread to follow and I'm sure that you guys will meet that need. I should probably do my own one day.
James
#27 sibhs
Posted 02 July 2019 - 10:10 PM
James, the drivers side springs break due to the extra work load.  It's a struggle to find a good drivers mechanism so I decided to try and fix it.
Check out the picture with the 3 springs, the original one is broken.
#28 sibhs
Posted 05 July 2019 - 08:59 PM
Evening all,
I planned to make a lower rust repair panel for the front guard.  Using the GM guard as a guide I welded up a frame to use as a template.  Before that could begin I made an addition to my press brake which is an interchagable tube to give round bends.
After two attemts at making this part I gave it away and decided to buy a Rare Spares version.  Since seeing the rares version I'm tempted to try one more time at getting it right.
Attached File  IMG_7942.jpeg   110.96K   29 downloads
Attached File  IMG_7944.jpg   167.79K   27 downloads
Attached File  IMG_7945.jpeg   90.47K   23 downloads
Attached File  IMG_7957.jpg   93.85K   24 downloads
Attached File  IMG_7958.jpg   280.57K   23 downloads
Attached File  IMG_7956.jpeg   119.86K   23 downloads
Attached File  IMG_8064.jpeg   356.67K   28 downloads
Not happy with this Rares Panel, the two crease lines horizontal at the top are very rounded when compared to a genuine guard and this is why I'll try and make my own.
Attached File  IMG_8063.jpeg   294.44K   43 downloads
Some of the parts from the Rares 20% off day.
Attached File  IMG_8087.jpeg   485.35K   38 downloads
Also met a young fella up in the Perth Hills who I got a big chunk of parts I needed, thank-you soo much.
#29 jpxu1
jpxu1
  • 573 posts
Posted 05 July 2019 - 11:26 PM
How's that saying go.... 'the more you spend the more you save', I think it's closer to the truth the other way around!
Gotta be happy with that lot, a long time following the rocking horse around trying to find some of that stuff. Well done.
#30 RallyRed
Posted 06 July 2019 - 06:46 AM
Hi Marty /Sal...how do you know when the 20% days are on?? ta
#31 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 06 July 2019 - 07:09 AM
https://youtu.be/7mEKuOR-93U
Hi Marty,
It might be worthwhile for you to watch this video about making panels like the bottom of the guards. This guy does some good stuff.
James D
#32 Shiney005
Posted 06 July 2019 - 10:10 AM
I must be on a mailing list as I get the notifications a couple of days beforehand by email. I doesn't help when the closest shop is 250 kilometers away.
#33 RallyRed
Posted 06 July 2019 - 12:28 PM
Yeah mate....I was actually in a store today. Apparently is seems that the Company owned stores offer the -20% from time to time. ( Melb, Syd, Perth?)
The franchised stores don't typically get involved.
Naturally, my local is a franchise......doh
#34 sibhs
Posted 11 July 2019 - 10:43 PM
Did a bit of pulling on the week-end!
Hooked up the 4wd to a hand winch which I then attached to the GTR and moved around the front end pulling and straightning.  The car is already chained down at the rear so that stopped it moving any where. Used measurements from the LJ to check.  I have since fitted up a good bonnet and guards and feel I'm pretty close to getting this right.
Attached File  IMG_8070.jpeg   133.42K   28 downloads
Attached File  IMG_8074.jpeg   155.32K   23 downloads
Had to pull the bottom forward to get the stone tray to fit.
Attached File  IMG_8076.jpeg   129.02K   25 downloads
My home made highly engineered sheet metal grabber worked a treat.
Attached File  IMG_8079.jpeg   100.51K   24 downloads
Had to heat up some sections to get them to move.
Attached File  IMG_8072.jpeg   81.13K   25 downloads
Attached File  IMG_8083.jpeg   91.73K   22 downloads
This dent popped up nicely using the stud welder dent puller.
Attached File  IMG_8081.jpeg   134.07K   22 downloads
Extra bracing required.
Removed the cowl section because it had been off before and a new one braised on.  Glad I did, the first repair had caused heat marks which is where the rust had started underneath.
Attached File  IMG_8002.jpeg   110.54K   25 downloads
Attached File  IMG_8005.jpeg   106.12K   26 downloads
Attached File  IMG_8016.jpeg   153.23K   24 downloads
Here you can see the heat marks and the effect its had on the protective paint coating.
Attached File  IMG_8018.jpeg   160.22K   23 downloads
Attached File  IMG_8020.jpeg   141.96K   23 downloads
Attached File  IMG_8006.jpeg   102.76K   26 downloads
Got to make up a few bits to go in here but without a sample its difficult. I'll have to find a car with this visible and in good shape that I can copy.
#35 sibhs
Posted 11 July 2019 - 11:07 PM
Hi Marty,
James D
Hi James,  I've been watching a few of Trev's Blog and he's really good, I hadn't watched that one before. Cheers
Hi Col,  I sort of fluked it, but if you're on their FB site they give a few days warning. My local store said they will price match so if theres 20% in QLD they will do it in Perth if you mention it.
Edited by sibhs, 11 July 2019 - 11:07 PM.
#36 RallyRed
Posted 12 July 2019 - 08:04 AM
Ta mate,
Local store here suggests that they don't get any help from HQ to do that, so struggle to do it.
Regards
#37 _LONA-CK_
_LONA-CK_
Posted 12 July 2019 - 09:18 AM
I did have a couple of sets of them that I made a few years back, I only have the paper template left now would you want me to send it up to you mate, if so msg me your postal address.
Cheers gong
#38 jd lj
jd lj
  • 2,124 posts
  • Name:James D
Posted 12 July 2019 - 09:34 AM
Marty/Sal,
Are you using the reproduction front guards. I recently saw two cars with the reproduction front guards where the door gap etc was good but the gap at the top that follows the curve of the cowl was too big.
#39 sibhs
Posted 18 July 2019 - 11:13 PM
Some pics of the lower dash fix-up after it came out of the car in two pieces.
Attached File  IMG_7996.jpg   165.67K   24 downloads
Attached File  IMG_8028.jpg   340.68K   26 downloads
Repaired broken tab areas
Attached File  IMG_8033.jpg   124.9K   23 downloads
Drilled holes through fins on back and put stainless tig rod through.
Attached File  IMG_8037.jpg   101.47K   23 downloads
Filled the area with araldite
Attached File  IMG_8057.jpg   113.05K   23 downloads
All cracks repaired and strengthened.
Attached File  IMG_8212.jpg   478.16K   24 downloads
Touched up some of the lettering
Attached File  IMG_8213.jpg   429.4K   21 downloads
Marty/Sal,
Genuine guards being used James.
Attached File  IMG_8214.jpg   420.5K   22 downloads
Autoglym Bumper and Trim applied to plastic.
Attached File  IMG_8215.jpg   392.6K   23 downloads
Chrome pen applied.
Edited by sibhs, 18 July 2019 - 11:14 PM.
#40 RallyRed
Posted 19 July 2019 - 12:40 AM
luv your work!
#41 sibhs
Posted 21 July 2019 - 09:38 PM
Evening all,  Still doing mostly internal part restoration due to the lack of daylight and warmth.  Once the season changes I hope to get more onto the panel work of the body.
This is the glovebox insert fitting of the metal side section, it's a bit tricky re-using the rivetts but worth the effort.
Attached File  IMG_8204.jpg   88.62K   25 downloads
Removing the original rivetts after breaking away the old cardboard to get leverage on rivetts.
Attached File  IMG_8208.jpg   191.57K   24 downloads
Rivetts and metal part painted and fitted.  Used tape covered dolly to re-fit rivetts with screw driver and hammer.
Attached File  IMG_8210.jpg   121.46K   24 downloads
view from behind
Attached File  IMG_8211.jpg   435.13K   22 downloads
Tools used for the job.
Had a bit of luck on Friday.  A couple of weeks ago I found a WW Carbie and air cleaner but the carbie was wrong with its numbers and jets etc. (off a 4.2 Torana).  Dropped by a carbie shop Friday and the owner had a rebuilt correct numbered WW on the shelf ready to go and he only charged me the rebuild exchange price.
Attached File  IMG_8231.jpg   103.29K   27 downloads
Also gave me a copper lined bag to protect the carbie from corrosion because I said it won't be fitted for a couple of years.
luv your work!
Cheers Col, Hope to catch-up at Torana Fest.
#42 _The Handbrake_
_The Handbrake_
Posted 21 July 2019 - 10:56 PM
So its been a while since I last got to do anything on the Torrie as M has well and truly taken over! But I managed to score the job of putting the lettering on a switch of the heater box.
Using M's homemade decals I only had to cut out the one word 'fan' - the lettering on all the other words on the box are ok - and luckily so as they are slippery little buggers and you need little nimble fingers to stick them on in precisely the right spot! Managed to do it, and to pass M's high standards.
Attached File  IMG_8217.jpg   342.58K   25 downloads
Attached File  IMG_8219.jpg   219.41K   24 downloads
Attached File  IMG_8223.jpg   242.84K   25 downloads
And then it was on to a bit of baking - the manifolds this time. And yes JD, in my meile oven of all things. Is my warranty now void? I must admit that putting the apple pie in at the same time wasn't a smart idea - goodness knows what toxic fumes the paintwork emitted.
Attached File  IMG_8272.jpg   314.6K   23 downloads
Attached File  IMG_8274.jpg   265.83K   22 downloads
But having fun so far...
Sally
#43 Ice
Posted 22 July 2019 - 12:09 AM
Nice work Sal but i hate to say it i think you over cooked the manifolds
#44 sibhs
Posted 22 July 2019 - 11:06 PM
Door pins - I had that one pin that didnt want to budge.  I tried heat, then water, CRC, Hammers and bigger hammers. The pin had snapped in the middle of the hindge which complicated things. So after six weeks of trying various techniques I gave up and cut the hinge barrel off.  Then removed pin by welding metal bar to it and working it loose.  Then I had to drill out the other piece in the barrel.
Attached File  IMG_8177.jpg   315.29K   22 downloads
Attached File  IMG_8180.jpg   545.01K   20 downloads
Attached File  IMG_8242.jpg   161.92K   20 downloads
Lining up the door before fitting barrel.
Attached File  IMG_8246.jpg   162.87K   20 downloads
Spacing out the barrel and spot welded
Got a price shock when I picked up some parts that I got stripped of chrome so that I can polish and prep before they get chromed.  So just to strip these parts was $200, I'm pissed and feel they are ripping me off, all they do is wire them up drop them in a tank of acid and give it a charge.
Attached File  IMG_8174.jpg   141.99K   22 downloads
#45 71xu1
71xu1
    Dave
  • 1,278 posts
  • Car:LC GTR XU1
Posted 23 July 2019 - 07:34 PM
Better of finding items with reasonable chrome, the pot metal does not chrome very well at all.
#46 Rockoz
Posted 24 July 2019 - 11:16 AM
Have a look at the Caswell site.
They have a dechroming kit.
You can get a few ideas on how to set it up without buying their bits and pieces though.
It isnt acid they use in the true sense of the word.
It is an acid based electrolyte.
You could probably even do it yourself without their bits and pieces, if you look at the thread here on doing your own plating.
Use the vinegar and salt to get the electrolyte going, then use the chrome bit as the anode, and any other metal as the cathode.
Should do a decent job of getting rid of the chrome in theory.
Their kit allows you to redeposit the chrome for using in plating again, recycling it.
#47 sibhs
Posted 27 July 2019 - 10:08 PM
Evening all,
Time has come to get the body on a stand so I can sand-blast the front end and fit and align the guards.  Very difficult trying to lift the body with limited room. I had to pull through the gearbox hole.
Made up a front stand and painted it with KBS Motor Coater I had left over from the LJ. It said rocket red on the tin but was a EH era colour so didnt get used on the LJ, amazingly it was still ok after 7years.  I painted it on doing the opposite of the instructions.  No prep of the metal, very cold on application, one coat only and a bit thick. If it lasts it'll be amazing.  Also drilled the tubes and flooded them with fisholene.
I decided to make it higher that others I'd seen but I think it may be too high. May have to cut it down later if required.
Attached File  IMG_8259.jpg   354.15K   22 downloads
Attached File  IMG_8253.jpg   139.62K   22 downloads
A bit of counter balance in the boot to help with the lift.
Attached File  IMG_8266.jpg   416.12K   24 downloads
Attached File  IMG_8297.jpg   423.72K   18 downloads
Attached File  IMG_8312.jpg   358.02K   19 downloads
Started lifting the rear this arvo and got the back-end out, then measured up for steel purchase on Monday.
Hi Dave, I've invested to much money and time so far so I'll get them chromed and report back on the result.
Hi Rob, I did check out this company and products after reading another post you suggested them in.  I like the look of it but I don't have the space to set-up a system, otherwise i'd give it a go.
#48 Rockoz
Posted 28 July 2019 - 12:18 PM
Hahaha
You have about 10 times the room I have Marty. lol.
Ive got a garage that is only just a single car garage.
I reckon if you actually parked a decent sized car in it you would be hard pressed to get out of the car.
But I can understand what you are saying about lack of room.
You need to have the important stuff looked after.
Unfortunately the old beast I am doing up lives outside.
And Ive just recently parked the Harley outside too.
Every time I make room to move I find something else to put in there.
#49 Potta
Posted 28 July 2019 - 11:41 PM
I knew it wouldn't be long before you started another Torana Marty.
Looking forward to seeing how this one turns out.
#50 CI 0308
CI 0308
  • 737 posts
  • Car:77 LX SS, VX SS
Posted 29 July 2019 - 09:28 AM
How's the relationship with the neighbors Marty now they have seen another project.
Sent from my SM-A520F using Tapatalk
