Gmh press release
36 replies to this topic
#1 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 08 October 2025 - 06:01 PM
Hi guys.I’m after a copy of the gmh press release of the 1971 gtr xu-1 .I’m helping a friend as he’s in the process of wanting to put an v8 into his 2 dr gtr torana.he’s down in tas and has contacted Burnett consulting and they would like to see this document as they can then hopefully  use this to allow the fitment of the v8 into the torana..
cheers maz
#2 gtrboyy
Posted 08 October 2025 - 07:02 PM
Dr Terry's Holden History book or Fiv Antonmou(sp) Gtr Xu1 book?
#3 yel327
Posted 08 October 2025 - 07:25 PM
cheers maz
I’ll have a look if I have it. What do they need from it? If it’s the weight I can copy the page from the GMH Eng Tech Specs. But what you want for NCOP compliance is the heaviest sedan equivalent, not the XU1’s weight.
#4 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 08 October 2025 - 08:26 PM
Hi Yel .I’d say the original headlining from page 1 stating it is an actual gmh press release is what they want to see.an genuine document... .I’m pretty sure on page 5 just states the weight with no headlining at top of page to say it’s actually from gmh ..just typed out.i thought the heaviest variant is the 71  lc xu-1..if the lj is heavier again ..that would b even more helpful getting it over the line..I don’t think they will allow it otherwise .
Edited by madtoranajzedded, 08 October 2025 - 08:27 PM.
#5 rodomo
Posted 08 October 2025 - 09:02 PM
There is a bloke down your way (Allan?) that may or may not have one of the factory prototypes that would have all that info I'm pretty sure.
#6 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 09 October 2025 - 01:04 AM
Im not sure if that guy exists . I don’t think he would want to talk to me through all the shit stirring he recieved yrs ago when I was only joking but he took it all too seriously lol…I think I heard on the grapevine he has a v8 in it with a chassis strengthening kit but unsure if it is registered .
Edited by madtoranajzedded, 09 October 2025 - 01:05 AM.
#7 S pack
Posted 09 October 2025 - 06:08 AM
cheers maz
Hey Maz, I can provide you a digital copy of the complete press release. Just need an email to send it to.
Dave.
#8 yel327
Posted 09 October 2025 - 06:24 AM
I found it, will try and put t up later today. No weight on the front page though, only on last page. 2430lb. But as I said you need the sedan if I read it right.
I also have the original Eng Tech Specs from 9/71 for the updated ca. 2417lb.
#9 S pack
Posted 09 October 2025 - 08:06 AM
XU1 is the heaviest LC & LJ Torana model.
#10 yel327
Posted 09 October 2025 - 08:32 AM
Yes that is a given, but the NCOP deals with the heaviest sedan in the Series so to Engineer you need the sedan’s weight. Same issue with HK coupes, the Brougham is lighter than a GTS327 but it’s the Brougham’s weight that you use.
https://www.infrastr...1jan2011_v3.pdf
Here is the text:
Attached File  NCOP sedan.jpg   38.5K   3 downloads
Edited by yel327, 09 October 2025 - 08:32 AM.
#11 Dr Terry
Dr Terry
  • 3,359 posts
Posted 09 October 2025 - 09:06 AM
It depends on what your definition of a "sedan" is. In RMS/TfNSW language, coupes, 2 door & 4-door sedans are all classified as sedans. Wagons & commercials are not.
This means that a 2-door XU1 is a sedan, well it is a 2-door sedan anyway, you do sometimes hear it incorrectly described as a coupe.
Same with HK, the GTS327 is the heaviest "sedan" at 1495 kg.
I know this to be true, I just completed a TfNSW Blue Slip (AUVIS) inspector's course.
Dr Terry
#12 yel327
Posted 09 October 2025 - 09:54 AM
Terry
That is good if that is the case, the problem is this is a National COP and that definition is State based. If it applies Nationally then it’s a win. The reason I raised it was an Engineer pointed that out to me when looking at a 427 in my HK coupe, and it worked with the GTS327’s weight but didn’t with the Brougham. With the NCOP limits are higher than under the old NSW regs.
#13 Dr Terry
Dr Terry
  • 3,359 posts
Posted 09 October 2025 - 01:35 PM
I believe the Feds & our TfNSW are on the same page with this one. They use the same abbreviation codes. All of the dats sheets are issued by the Australian Government Department of Transport & Regional Services.
All they are saying is you must not use the wagon or commercial variants in your calculations, it must be the 'passenger' version.
Dr Terry
#14 S pack
Posted 09 October 2025 - 04:58 PM
Here is the text:
LC & LJ 2dr are sedans. XU1 are 2dr sedans.
#15 yel327
Posted 09 October 2025 - 06:13 PM
Dr Terry
Its good that is the case as it was hard to rationalise the thinking otherwise.
Note that a GTS327 isn't 1495kg Tare Weight, it is 3295lb (1494.6kg) Curb Weight, which is the car full of fuel. Tare weight is the car with 10L of fuel. 26 gallons of fuel (118L) minus the 10L from the Tare Weight definition is 108L which is 87kg. So the Tare Weight of a GTS327 in standard form would be 1408kg or close to that.
The same thing would have to be done for the XU1 and its 17 gallon tank as the weights quoted are Curb Weights. Here is the Sept 1971 revision for the final LC XU1's.
Attached File  XU1 front page Eng Tech Specs.jpg   107.24K   4 downloads
Edited by yel327, 09 October 2025 - 06:14 PM.
#16 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 09 October 2025 - 08:45 PM
If the weight has been revised from the other earlier gmh document there’s no point then showing that to Burnett consulting as it’s now under ncops reccomendation of 1100kg .so it will b at the descripiancy of the engineer whether to allow or not..it’s like the majority of engineers aren’t even using the vsb 14 ncop as there’s plenty of lj getting regd without it
Edited by madtoranajzedded, 09 October 2025 - 08:46 PM.
#17 yel327
Posted 09 October 2025 - 08:55 PM
Yes, and that 2417lb is Curb, 1098kg or thereabouts. Then remove some kg for the fuel to get back to 10L. Well under 1100kg.
LJ XU1 would be closer to 1100kg but may not be over it.
#18 yel327
Posted 10 October 2025 - 05:52 AM
Yes I get that and so are HT-HQ wagons - GMH call them Station Sedans (didn't become Station Wagons until HJ). But as Dr Terry pointed out, what GMH called them doesn't matter, its how they are classified by Govt's. HJ-HZ Caprice would be an interesting test, they are technically the heaviest sedan in those Series, but they are because of what is on them (standard A/C for example), but also because they are LWB. Those NCOP rules state MODEL not SERIES, so technically if you were modifying a HJ Belmont sedan, it'd be the heaviest Belmont sedan not heaviest HJ sedan - if you followed their words.
Edited by yel327, 10 October 2025 - 05:52 AM.
#19 Dr Terry
Dr Terry
  • 3,359 posts
Posted 10 October 2025 - 06:28 AM
HQ-WB Statesman is an interesting one. As you probably know, GMH didn't market them as Holdens, they were presented as s"Statesman by GM" & that's the way TfNSW treat them. They are listed under the Statesman brand & not included as a Holden.
I believe that the heaviest Belmont could be a V8 Premier, they are both listed as HJ "Holdens".
Dr Terry
#20 yel327
Posted 10 October 2025 - 08:16 AM
Terry I reckon that is how it’d work but the NCOP wording says Model not Series, so it has an interpretation issue. Whomever wrote it didn’t think about it enough. If those words were in AS/NZS3000 and I was Engineering to them, let’s say someone was modifying a HQ Belmont sedan, MODEL 80169. The heaviest one of that model would be one optioned with 202 and auto. V8 Belmont is different Model, 80269. Yes you could go into equivalence and upgrade it to V8 Belmont, but in Regulations and underlying COP’s designed to be applied by Engineers they need to be very specific especially in COP’s. Even worse when people do the right thing and self-Engineer (as in make modifications not requiring Certification) they need to be especially clear. If your average car person was to read that, they would view a HQ Deville as a HQ Model, so would use a 350 optioned Deville as the heaviest sedan, whereas probably an XW8 auto Kingswood sedan is probably the intended car (or possibly 350 auto 81237). In the end (as an Engineer) I reckon the Statesman would be a better comparison to a Wagon for weight restricted modifications. And I fail to see how a Sedan is Engineered by GMH has relevence for a commercial in regards to for example, rear axle loading. In the end I’d be applying what I normally apply when Regulations use SHOULD. Our legal system sees should as “do what is stated or something as good as” where SHALL is far more prescriptive.
#21 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 20 October 2025 - 08:00 PM
Gee these guys down here..what was mentioned today.
Hey mate, I spoke with Josh from Burnett consulting a couple of times today, he kept referring to the maximum weight being from the sedan, I explained that they are a 2 door Sedan not a coupe, he seemed ok about that, then called back and asked where I got the document from, he now wants me to get verification for that document
, I spoke to the Birdwood museum today and their looking into it
#22 S pack
Posted 21 October 2025 - 06:24 AM
Oh FFS, if they look at the bottom of the 1st page it tells them exactly where the Press Release originated from - Public Relations Department, General Motors Holden's Pty, Limited.
#23 RallyRed
Posted 21 October 2025 - 06:39 AM
The ADR tag on a 2 door LC/LJ says 'SEDAN'....will that help the Engineer?
Edited by RallyRed, 21 October 2025 - 06:39 AM.
#24 yel327
Posted 21 October 2025 - 06:51 AM
Birdwood don’t have it as far as I know. I have copies of it all out of GMH’s archival material. The important document is the Engineering Techical Specifation which was updated for tha last run of XU1 with the heavier Aussie M20.
#25 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,907 posts
  • Name:Maz
Posted 22 October 2025 - 01:11 AM
I don’t think they believe it’s a real press release from gmh S pack .i don’t understand why they are hung over on this press release.a piece of paper is not what makes a car safe anyway..it should b whether the vehicle can handle the extra weight and horsepower.so an torsion and beam test.lane change and braking tests should confirm if it is capable.anyone would think the 304-308 Holden engine is a very powerful engine.hell an turbo 4 cyl or even a turbo 6 would go past it like it was up on blocks .
