Power Steering
#26
Posted 04 January 2006 - 11:48 PM
Have been tinkering away on the power steer over the holidays even if it has been a bloody million degrees celcius for the last 4 weeks in Brissy!!!
My PC is in the hottest room in the house - hence why I am a bit quiet recently.
http://www.cardomain.com/ride/480776/2
I have finally sus'd out why there is a bump steer problem with the Cortina rack that CRS could never get rid of - I may or may not be able to solve the problem.
Does anyone on the forum know anyone with the Cortina setup in an LX or have any pics? I want to confirm my suspicions on this one.
The further I get into things, the more I like the WRX rack - the testing will tell all I suppose.
M@
#27
_J&S Racing_
Posted 05 January 2006 - 07:32 AM
#28
_Hurricane_
Posted 06 January 2006 - 05:06 PM
#29
Posted 06 January 2006 - 05:15 PM
By the way, wrong section mate.
#30
_Hurricane_
Posted 09 January 2006 - 09:23 PM
Edited by Hurricane, 09 January 2006 - 09:24 PM.
#31
Posted 10 January 2006 - 05:55 PM
I though the other power steer thread had a lot more info in it but we must have lost all that on the old forum.
To sum it up - the only power steer kit anyone has put on the market for the LH/X/UC was the CRS kit which uses a TE/TF cortina power steer system (rare as rocking horse poo). You send off the x-member, steering rack, steering arms and they mod them for ??$400??? You work out the pump using HZ setup and make custom lines.
Basically they mod your drivers side engine mount, ream out the steering arms to suit the Cortina tie rods, mount the steering rack on the Torana front end (and I think they must also swap the rotary valve around and mod the hydraulic lines accordingly on the rack).
Last time someone I know checked with CRS, they were jacking up about doing the conversion because they could never cure the bumpsteer in it - they will not give any more details. They may or may not do it for you.
I now have a Cortina power rack to muck around with if you look on my cardomain page - I believe the bump steer issue is as follows.
You can't get the rack centre line to line up with the Torana's X-member centre line.
The only way I can think to fix this will end up with the cortina rack having to be widened between the inner balljoints from 620mm to about 645mm.
This being the case, the Wrx rack one is 650mm between inner balljoints and I recond I can mod one to 640mm and the racks are far more available, much lighter and they have a fair bit quicker steering ratio compared with the Cortina ones.
I am only fairly early on in this process - if you can wait a bit longer, I may have it all worked out for you - otherwise, start looking for a Cortina one and start hassling CRS.
M@
Edited by Toranamat69, 10 January 2006 - 05:58 PM.
#32
_TORANASS_
Posted 10 January 2006 - 06:42 PM
Back to the cortina rack option. If the rack is shorter that means the tie rod)NOT TIE ROD END) will start from a lower pivot point correct? By using HQ stubs doesnt the tie rod end sit lower then it would with torana stubs. Now wouldnt that bring the angle of the tie rod back to parralel with the lower controll arm. and elminate bump steer..
Just a thought.. If its dumm just tell me im stupid lol
john
#33
_Hurricane_
Posted 10 January 2006 - 08:13 PM
p.s. sorry if this is a really stupid question , whats bump steer (never heard of it before? )
p.s. 2, who's CRS
cheers Brendon
Edited by Hurricane, 10 January 2006 - 08:16 PM.
#34
Posted 10 January 2006 - 10:15 PM
#35
_Oldn64_
Posted 10 January 2006 - 11:22 PM
Talk to this guy. I am sure he might be able to help you... his work is unbelievible!!
_Hurricane_
Posted 10 January 2006 - 11:29 PM
#37
Posted 11 January 2006 - 12:54 AM
The LX Torana's inner balljoints are spaced at 625mm - this is what I was trying to get as close as possible to. You can compensate for the wider inner balljoints by raising the position of the rack. I am not sure how much clearance a 308 has to the steering rack - it would help even if you raised it 10mm. My engine sits about 9.6mm above the steering rack so I have no where to go.
The different steering arms help to fine tune the bump steer but unfortunately if you cannot get the inner balljoints right, you will never get the bumpsteer right.
The tie rod does not necessarily need to be parallel with the lower control arm. It can be but it also depends how high the rack is mounted.
M@
Edited by Toranamat69, 11 January 2006 - 12:56 AM.
#38
Posted 11 January 2006 - 06:21 PM
Cannot Find Server.www.rodsracks.com.au
_Oldn64_
Posted 11 January 2006 - 06:25 PM
_Hurricane_
Posted 11 January 2006 - 11:57 PM
#41
Posted 12 January 2006 - 01:16 PM
I'm now banned from the tool box lol
#42
_Hurricane_
Posted 12 January 2006 - 04:23 PM
#43
Posted 13 January 2006 - 10:26 AM
#44
_Oldn64_
Posted 18 January 2006 - 12:02 AM
Posted 02 February 2006 - 03:42 PM
Grant..
#46
Posted 02 February 2006 - 05:28 PM
I still have a bit of cleaning and prep work to do on the control arms before then but I still have a week at least to clean the old paint off and get them looking good.
Probably be about 2 weeks before I have some control arms to bolt back onto the subframes and start testing stuff out.
M@
#47
Posted 25 March 2006 - 02:39 PM
#48
Posted 30 March 2006 - 11:51 PM
Still here, jusy updated the cardomain again with a few more bits. almost ready to start doing some real constructive stuff.
I am now looking for a pair of HQ to HZ stub axles (even a loan would be good) so I don't have to measure the ones on my car.
Also looking for one LH or LX upper control arm.
M@
#49
Posted 31 March 2006 - 11:40 PM
Grant..
#50
_LX_SSnatch_
Posted 05 May 2006 - 09:55 PM
Very interested in this power steering artical. I and my father have atempted to fit a Cortina Power rack to my UC and found that it was a complete stuff around to get it to fit.
interested in the WRX power rack idea
TORANAMAT69-could u supply some pics of the way the WRX rack is mounted to the front end and wat problems did u encounter?
Cheers Matt
