Show us your 15's!
80 replies to this topic
#51 makka
makka
    A møøse once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 20 March 2007 - 11:26 AM
I know its not flared, but here is one of mine with 15's
#52 _oikurtman_
_oikurtman_
Posted 20 March 2007 - 12:18 PM
so who's mags are torana pattern? i could only find mags available in HQ pattern :huh:
looks like i'll give consulmotive a call and see what the go is with engineering the big rubber. thanks for that tip guys.
keep the pics comin! :spoton:
cheers.
#53 _oikurtman_
_oikurtman_
Posted 20 March 2007 - 12:53 PM
also, could someone please explain the whole backspace thing to me?
what is the general concensus on backspacing for toranas with wide mags and flares? If i'm gonna get some new rims i might need to know about all that!
and if HQ pattern is the only option, what's involved in the conversion?
cheers.
Edited by oikurtman, 20 March 2007 - 12:54 PM.
#54 _EXLXSL_
_EXLXSL_
Posted 20 March 2007 - 04:51 PM
I forgot to add that bit.
Mine are Torana pattern (Simmons V5s) and came with the car.
#55 _levis_
_levis_
Posted 20 March 2007 - 10:03 PM
mine are also torana pattern
#56 LXCHEV
Posted 20 March 2007 - 10:46 PM
for those with wide rubber, 295 etc. how do you find traction? I have heard that wider tyres give less traction due to having less pressure on the ground.
To answer this question - this is basically correct when the road is wet (the wider tyres can aqua-plane across the top of the water).
However, in good dry conditions, the fatter the better! Lots of rubber on the road (ie. a large 'footprint', generally gives improved traction/grip). My 265's have certainly shown excellent traction... I even ran an 11.99 down the quarter on standard BFG's. But you generally get heaps more traction on a drag strip than you ever would on the street too.
#57 TerrA LX
Posted 20 March 2007 - 10:55 PM
some people prefer to use the off set which is the bolt up face location in relation to the center of the rim, problem is that off set changes with rim width, i prefer back space which is the distance from the rear rim lip to the bolt up face, ie put a straight edge across the rim and measure down to where the center would bolt to the axle. Simple and stays the same regardless of rim width.
Toranas and HQ's etc usually use 4inch but can get away with 5inch.
#58 _the gts_
_the gts_
Posted 21 March 2007 - 09:07 PM
Never had a traction problem with my old orange LH with its 285/60's, the guy a bought the car from had a picture of it with both wheels off the ground at the drags
what g/box & diff ratio and what was the motor HP?
I have 3.5's Th700 and will have approx 520@flywheel when the motor gets back together
#59 _MRNOS_
_MRNOS_
Posted 21 March 2007 - 09:13 PM
350 chev, custom solid cam to suit N20, dart heads, victor jnr, 750dp etc etc, engine made 496hp at the engine-why couldnt it get a extra 4hp!! :cry: , powerglide with transbrake, 4200 TCE convertor, 3.7 diff, ran 10.60's no gas, couldve got quicker with somemore tuning
#60 _moot_
_moot_
Posted 22 March 2007 - 07:05 AM
i'll put money on it that box will have a short life :spoton:
#61 _oikurtman_
_oikurtman_
Posted 22 March 2007 - 07:51 AM
So where are some good places to go shopping for mags in Sydney?
#62 arrimar
arrimar
  • 3,134 posts
Posted 22 March 2007 - 04:56 PM
the newsagents are quite expensive so i find the month old mags in doctors surgerys are a bit cheaper. :huh:
#63 _MRNOS_
_MRNOS_
Posted 22 March 2007 - 05:09 PM
You're a shocker Richard...
#64 A9X
Posted 22 March 2007 - 05:31 PM
:D :spoton: :clap: :D
#65 TerrA LX
Posted 22 March 2007 - 06:46 PM
LMAO
#66 _TravsUC_
_TravsUC_
Posted 22 March 2007 - 09:13 PM
ebay lol
#67 _the gts_
_the gts_
Posted 20 July 2007 - 10:49 AM
moot you might be right about the th700 but it has been built by one of the top perth g/box fellas and he recons should handle 550hp no problems.
he had one in one of the chev trucks with duel wheels at the back and a big block, used to use it to tow his drag car and do burnouts
#68 _LXBren_
_LXBren_
Posted 05 August 2007 - 03:38 AM
How many people scrub out with the 15's?
Knoath, what mags are those?
#69 _1BADSS_
_1BADSS_
Posted 05 August 2007 - 09:00 AM
Here are a few photos of my LX. 10x15 with 295's on the rear and 7x15 with 245's on the front, yes they both scrub like a mofo( front on full lock and rear when you hit bumps in the road. When I have to replace them, I will use 225's and 275's and I hope that will stop the scrubbing. Mind you I do like the look of the SS as it is.
This photo shows the width of the tires better.
This my old LH, it was mini tubbed with 8.5X15 fitted with 255's on the rear and 6X15 with 215's on the front.
#70 _stock_
_stock_
Posted 05 August 2007 - 11:52 AM
here is a pic of new car with 31*12*15 autolites.
#71 dannygtrxu1
dannygtrxu1
  • 71 posts
Posted 05 August 2007 - 06:49 PM
hi guys here are a few pics of my rims 15x8 and 15x4
https://cache.gmh-to...annysxu1024.jpg
https://cache.gmh-to...annysxu1018.jpg
Danny...
#72 _SS Hatchback_
_SS Hatchback_
Posted 07 August 2007 - 11:04 PM
Good thread this one, A heap of different combos and all looking good i might add. Im glad im not the only one scrubbing when hitting bumps 1BADSS.
#73 RIM-010
Posted 07 August 2007 - 11:08 PM
SS Hatchback, your hatch looks freakin' sweet. Well done.
#74 A9X
Posted 08 August 2007 - 11:24 AM
14 x 9 1/4 Hotwires, 255 Eager's on rear
15 x 10 Hotwires on rear, HQ pattern, 4.75"offset, Yokohama AVS 285 50 15's.
Welby
Edited by A9X, 08 August 2007 - 11:27 AM.
#75 dattoman
Posted 08 August 2007 - 12:21 PM
Top pic with the fat guy looking at the brakes are actially 265's
