Micks Racecar Project LX202 to VH308
#151
Posted 14 February 2010 - 08:36 PM
#152
_jay79_
Posted 14 February 2010 - 08:41 PM
#153
Posted 14 February 2010 - 08:49 PM
*snigger* looks like he shot his boltyou left your nuts at home after valentines morning?
#154
Posted 14 February 2010 - 09:56 PM
#155
Posted 14 February 2010 - 10:56 PM
The bolt can be seen in the pic lying in the undertraynice did the bolt come all the way out?
#156
_Brad1979UC_
Posted 14 February 2010 - 11:04 PM
#157
Posted 15 February 2010 - 04:52 PM
I came in, tightened the bolt again and did this 2 more times before the day was over.
Out of 85 cars, I came 16th. All in all not a bad day although I've got some work ahead of me.
#158
Posted 15 February 2010 - 05:07 PM
Will the crank live?
#159
Posted 15 February 2010 - 05:08 PM
#160
Posted 15 February 2010 - 06:59 PM
There is a couple of things about this motor that suggest it was used in a boat at some stage. Boats usually drive off the front of the crank, so it's a possibility (clutching at straws here)that the front of the crank has some tiny amount of wear which contributed to the problem.
I might just change the key, and fit a new balancer using the appropriate locktight and take it to the drag day and see what happens.
If I have to change the crank, it will mean rebalancing, grinding the crank and new bearings as a minimum,
I probably should change rod bolts and valve springs,
I could easily cope with more comp and a bigger cam .......... I think this is known as the snowball effect !
Edited by micklx, 15 February 2010 - 06:59 PM.
#161
Posted 24 March 2010 - 06:43 PM
No - the crank is stuffed !
With the timing gear off, there is a noticeable lip between where the balancer goes and where the gear goes.
But hey - it was fun while it lasted !!
#162
Posted 24 March 2010 - 07:24 PM
#163
Posted 25 March 2010 - 05:02 PM
#164
Posted 25 March 2010 - 07:14 PM
#165
Posted 01 April 2010 - 05:31 PM
I set my best time with my girlfriend in the car, the extra weight must have helped with traction - although I'm not sure I should have told her that....
#166
Posted 04 April 2010 - 08:34 AM
#167
Posted 05 April 2010 - 02:03 PM
Two video clips from Heathcote. My Commodore racing Heath and Matt.
When is your next circuit day Mick?
I'm waiting for you to get your extractors built and then come to Phillip Island for a sprint.
Although I need to get the motor out and fix the crank and at the moment I've got too many other jobs on the go to even start that so not really sure when it will be.
#168
Posted 02 November 2011 - 10:33 PM
Edited by micklx, 02 November 2011 - 10:33 PM.
#169
_Brad1979UC_
Posted 02 November 2011 - 10:52 PM
#170
Posted 02 November 2011 - 11:15 PM
Good under brakes!
#171
Posted 03 November 2011 - 10:23 AM
#172
Posted 15 November 2012 - 07:16 PM
#173
Posted 16 November 2012 - 07:04 AM
#174
Posted 24 November 2012 - 04:09 PM
#175
_wblje_
Posted 24 November 2012 - 05:18 PM
